Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: audiolow, colectorboy2, felixalbert, Greghifi, Kinoorgelspieler, raph04, Renarddu25, Tkunc, viking44rb et 470 invités
Jolida JD801S... Un super ampli !?
Message » 27 Juil 2007 15:41
Plusieurs personne sur PDM ce sont séparé du classic 16.0 a cause d un grave , sois disant, insufisant
In triode mode maybe, otherwise it has very good bass, at least as good as the Cayin A-88T...
Maybe the original small tubes are not that good, I got it already with EH 6SN7 instead of the bad original 6N8P, and Siemens E81CC instead of the Chinese 12AT7, wich the seller says are reasonable...
Lowrider
Inscription Forum: 27 Avr 2007 19:28
Message » 27 Juil 2007 15:52
By the way, I never heard the 16.6, so all I say is regarding the 16.0, wich I would not buy if I needed an integrated amplifier, because it doesnt have remote...
I think it is safe to assume that they have very similar sound and quality, both look not very nice, IMHO, mine too... :roll:
Except for France and the far east, I dont find many references to Classic, Jolida is a better know brand, wich is obviously important, pick the nicest or the cheapest... :wink:
Lowrider
Message » 27 Juil 2007 16:13
Lowrider a écrit:In triode mode maybe, otherwise it has very good bass, at least as good as the Cayin A-88T...
I've never heard a Classic 16, so I won't say anything about the bass
I'v owned a Jolida and in my experience, with the original 6550 tube, the Jolida's having not so good bass : very "boomy"... Changing the 6550 for KT90 is a huge improvement : the bass are deeper and faster !
NB: in short : la qualité des graves du jolida dépend beaucoup des tubes dont il est equipé !
ogobert
Fondateur et Membre d'Honneur
Message » 27 Juil 2007 18:21
Petite question à propos des tubes justement... :)
Par rapport aux EL34 auxquels je suis habitué, le passage aux KT88, de la JD801S et du 16.6, sera-t-il pour moi une révolution sonore ou bien les différences sont-elles négligeables ?...
supersound
Inscription Forum: 11 Oct 2003 17:53
Message » 27 Juil 2007 18:25
Je ne connais pas assez le tube EL34, par contre il me semble que ce soit le seul tube specialement concu pour la hifi ( mais a verifier, si je ne dis pas de bétise )
ce qui est sur, c est que tu as un gain en puissance
la crevette
Pro-Divers
Pro-Divers
Inscription Forum: 08 Mai 2006 21:38
Message » 27 Juil 2007 18:29
Quand tu dis Hifi c'est flatteur ou péjoratif ?... :wink:
La puissance oui ok à condition que ce ne soit pas au détriment de la musicalité...
supersound
Message » 27 Juil 2007 18:40
Lowrider a écrit:Michel K,
Did you try no feedback at all, theorecticaly I would prefer to try no feedback, wich resistences did you change ?
To eliminate feedback what shall I do, are their any dangers to the amplifier ?
J'ai biensur essayé le C16 sans contre-réaction. La dynamique était très importante mais le rendu manquait de maitrise, surtout dans le grave. Les timbres perdaient de justesse.
Pour supprimer la contre-réaction, il suffit de déssouder les 2 résistances R6 et les 2 condensateurs C3. Sans contre-réaction, le niveau sonore augmente beaucoup ; il faut donc nettement diminuer le réglage du bouton du volume de l'ampli.
Pour des Cabasses, je conseille au contraire d'augmenter la contre-réaction en remplacant les 2 résistances R4 de 82ohm par des 270ohm : les basses sont plus présentes et mieux tenues ; les timbres sont plus justes. Sur d'autres marques d'enceintes comme les Aurum Cantus à plus bas rendement, le rendu d'origine du C16 me paraissait parfaitement adapté : on aurait peut-être même pu, à l'inverse des Cabasses, diminuer la contre-réaction.
J'espère que tu as saisi l'essentiel de mon message en français. Si nécessaire, je peux te traduire ça en anglais par mp.
Michel :wink:
Michel K
Inscription Forum: 04 Déc 2002 12:11
Message » 27 Juil 2007 18:59
supersound a écrit:
Michel K a écrit:Son mode pseudo-triode (2x20W) a ma préférence au mode ultra-linéaire (2x40W) ; le rendu est plus fluide et la scène sonore plus sensuelle.
Ca ressemblerait bien à ce que je recherche... :lol:
Michel K a écrit:Quelle taille fait ta pièce actuelle? Qu'utilises-tu comme ampli? Quel est le rendu actuel dans les basses?
Edit : ma pièce actuelle fait 18m² environ...
J'utilise actuellement un ampli Audio Institute VR110 pour remplacer provisoirement le Prologue One que je vient de revendre... Sa sonorité est chaude, les voix et les instruments à vent magnifiques mais très mou dans les basses malgré la Music Van en source.
Michel K a écrit:Si le fer à souder ne te fait pas peur, je te conseillerais une petite modif sans frais (le changement de deux résistances) qui augmente la contre-réaction de l'ampli pour une meilleure maitrise des Cabasses et des timbres plus justes.
Je ne suis pas spécialiste du fer à souder mais il y a un début à tout... :wink:
Le C16, dans 18m2, devrait donc être à l'aise, même en mode pseudo-triode (2x20W).
L'idéal serait que tu fasses une comparaison, à domicile, des différents prétendants. Si tu as l'occasion de passer sur Lyon, tu es biensur le bienvenu pour une écoute du C16 sur mes Iroise .
Michel :wink:
Michel K
Message » 27 Juil 2007 19:14
Michel :wink:
Merci Michel pour tes conseils et l'invitation à Lyon... je suis sûr que l'association C16/Iroise vaut son pesant d'émotions :wink:
Je ne pourrai que difficilement faire toutes ces écoutes... mais entre ces 2 amplis je ne pense pas prendre beaucoup de risque.
Pour définitivement faire mon choix il me manque juste l'avis de quelqu'un ayant comparé l'écoute du C16.0 et du C16.6... Si la sonorité est bien la même, cela validera la compatibilité itou entre le C16.6 et les Bali... J'y crois pas trop vu que les tubes du C16 sont des EL34 et ceux du C16.6 des KT88... :-?
supersound
Message » 27 Juil 2007 20:14
Michel K,
Merci beaucoup, jai compris trés bien ton message, mes enceintes sont trés sensibles, 96db, alors je nait pas besoin de plus de puissance, ce que je veux cest encore plus realism, et je crois que pas de feedback theoriquement cest mieux... :roll:
Quand tu as essaier, pas de probleme ? Je suis temptée... :evil:
Supersound,
On ma dit que les EL34 sont mieux, mais autres mon dit que les KT88 sont mieux, mon experience cest que ca depend de chaques lampe et chaque ampli plus que de modele...
Lowrider
Message » 27 Juil 2007 20:48
Michel K,
Do you mean this, do I replace with wire or just remove ?
Lowrider
Message » 27 Juil 2007 20:51
Lowrider a écrit:Supersound,
On ma dit que les EL34 sont mieux, mais autres mon dit que les KT88 sont mieux, mon experience cest que ca depend de chaques lampe plus que de modele...
En fait le son produit par l'EL34 est apparemment plus coloré que le son du KT88 plus neutre...
Faut vraiment que je passe à l'écoute de KT88 pour me faire une idée :wink:
supersound
Message » 27 Juil 2007 20:53
Tous sont coloré, il faut choisir le plus beau coloration...
Mais la verité cest que le son pas "coloris" des transistors cest trés fatigant...
Lowrider
Message » 27 Juil 2007 20:56
Now that I made a fool of myself writing in French... :oops:
What I mean is that I found more differences between different EL34 than between EL34 and KT88... :idee:
Lowrider
Message » 27 Juil 2007 21:01
You must juste remove.
NOT REPLACE WITH WIRE!!!
Michel :wink:
Michel K
