Modérateurs: Modération Forum Installations, Modération Forum DIY, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 5 invités
Tweak XINDAK DAC 5
Message » 15 Juin 2008 15:50
Bon ça y est je me lance, le fer à dessouder est commandé...
J'ai prévu de changer en premier les AOP BB2604 par des burson qui semblent faire l'unanimité.
Après je ne sais pas trop quoi changer, certains condos, diodes, ajouter des plaques de bitume... ??
J'espères que les spécialistes du tweak auront quelques suggestions !
Le DAC à 3 sorties :
- XLR
- RCA à tube
- RCA sans tube
si j'ai tout compris :
- BB2604 + BB134P pour la sortie XLR
- BB2604 pour la sortie RCA
- BB2604 + 1 tube e88cc pour la deuxième sortie RCA.
The analog filter circuit adopts the low-noise non-inductive resistor and the operational amplifier IC 0PA2604 from BB company. The analog output is divided into tube output and operational amplifier output, the former one is RCA single-ended output, and the latter is balanced output. The basic structure of electronic circuit is classical, it can up-sampling the digital signal recorded in common CD player and PCM format to achieve higher D/A converting precision and highly improve the sound performance on dynamics, frequency extension and solution. Except that, DAC-5 also has its own characteristics on processing of the electronic circuit, such as ¡°adopting the patent technology of avoiding dynamic invalidation of capacitors¡±. In the introduction, it is said that technology could decrease the distortion of the high frequency and improve the sound performance. Though there is no more detailed introduction on that, but one point is confirmed that capacitors could influence the sound of Hi-Fi products, no matter under dynamic invalidation or static invalidation. On such invalidation, it is meaningful to control and prevent timely. It is well known about the advantages of adopting two separate transformers supply the power to different channel. This DAC-5 adopts two separate toroidal transformers for right and left channel separately. In addition, there are 6 groups independent positive voltage regulators for power supply and there are 5 piece of high precision integrating regulator IC in total. That could assure the purity and steady of the power supply, which is also useful for block and converting electronic circuit, in order to further ensure the good quality of sound. The tube output adopts E88CC(6922EH), and the balance output adopts operational amplifier IC OPAl34PA.
les photos arrivent...
Paulkouhan
Inscription Forum: 24 Déc 2004 17:54
Paulkouhan
Message » 21 Juin 2008 20:01
Les bursons sont en place, le bitume aussi !
Y'a plus qu'a roder tout ça...
en attendant tout est déjà mieux, ça promet :wink:
J'ai fait quelques photos :
1 - Démontage -------------------------------------------------------------------------------------------------------------------------
pas de problèmes particuliers ; il suffit de laisser la carte fixée à la partie arrière du chassis
2 - Dépose de bitume dans le fond---------------------------------------------------------------------------------------------------
du 4mm :o
3 - Gros plan des AOP à changer (les deux du haut) : BB 2604 -------------------------------------------------------------------
4 - Vue de dessous --------------------------------------------------------------------------------------------------------------------
les soudures des AOP sont les 2 groupes de 8 pins situés à gauche et à droite des deux condos du milieu.
c'est là que ça se gâte... :evil:
5 - Une vraie boucherie ---------------------------------------------------------------------------------------------------------------
ça veut pas sortir... fer à déssouder, tresse à dessouder ....
:evil: => les grands moyens ... pince coupante... les pauvres burr brown, ils ne méritaient quand même pas ça :cry:
6 - C'est presque bon ---------------------------------------------------------------------------------------------------------------
Les pins sortent alors sans problème, mais il reste de la soudure dans les trous...
re - tresse, mais ça n'enlève pas tout :evil:
7 - Les grands moyens ---------------------------------------------------------------------------------------------------------------
il est 8H (vendredi soir) , je décide de retourner au boulot :o ... chercher une fraise en carbure :wink: .
j'habite à 5 minutes de mon boulot et on fait ... des outils coupants !
A cette heure là, le stock d'outils finis est fermé, mon choix était restreint aux outils en cours de fabrication.
j'ai eu de la chance... une belle fraise à affûtage hémisphérique diamètre 0.5 :
ça marche !
8 - Plantage de tulipes ---------------------------------------------------------------------------------------------------------------
Le plus facile... mise en place des supports tulipe et soudure...
9 - Mise en place des Burson----------------------------------------------------------------------------------------------------------
4 capacités sont sur leur chemin, je les avait vu.
En les poussant un peu, ça passe.
+ soudure du fil blanc à la masse
10 - Pose de bitume sur le capot -----------------------------------------------------------------------------------------------------------------
Paulkouhan
Message » 21 Juin 2008 20:05
Je rebranche pour tester :-?
Evidement pas de son....
Je bouge un peu les burson, les capacités que j'ai déplacé...
Je teste la squeezebox en direct sur l'ampli , bruit blanc.. :lol:
Je redémarre le squeezebox, et la ça fonctionne en direct sur l'ampli.
En bougeant le cable numérique, la squeezebox s'était coupée et à peut être mal redémarré, le problème venait probablement de là.
Je rebranche le DAC et ouf, tout fonctionne.. :mdr:
Pour mon premier tweak, je suis très content !
Mais ça reste compliqué de dessouder un AOP et de mettre un support tulipe à la place.
Paulkouhan
Message » 22 Juin 2008 12:35
8) Faut être méticuleux et prendre son temps ! Mais bravo pour ton premier touick et ton "reportage". :)
breizheau
Inscription Forum: 23 Oct 2005 12:30
Message » 22 Juin 2008 13:23
Salut Paulkouhan,
Je suis tenté par un DAC et je lorgne sur le Xindak mais vu le boulot pour changer les AOP et le prix des bursons (55€ pièce !)...Est ce que le jeu en vaut la chandelle ? Le changement de tube avait il déja amené un plus ?
Merci !
superjoker
Inscription Forum: 22 Sep 2006 20:45
Message » 22 Juin 2008 14:43
Les bursons sont loins d'être rôdés (il faut 200H à priori), mais même non rôdés ils apportent un plus indéniable.
Le Xidak DAC 5 propose une sortie "transistor" sans l'étage à tubes et une sortie "tube".
Jusqu'à présent, avec un bon tube, la sortie à tubes était ma préférée.
Avec les burson la sortie sans le tube me paraît meilleure... Mais c'est une première impression, je vais attendre la fin du rôdage pour faire des tests plus poussés !
Paulkouhan
Message » 28 Juin 2008 6:49
joli travail , quelle patience !
maintenant tu pourais changer les codos de sortie , du mundorf silver oil par exemple , tu as deux sortie et 4 condos , inutile de changer les 4 , mais change au moins les deux qui concernent la sortie que tu utilises habituellement.
les mundorf sonts gros tu pouras pas les mettres a la place des originaux , mais ton boitier est spacieux , tu peux les mettres a coté de la carte en tirant des fils
josselin_baumont
Inscription Forum: 11 Juil 2001 2:00
Message » 28 Juin 2008 11:49
Merci !
c'est la prochain tweak que j'envisageais de faire...
en creusant un peu, j'ai l'impression que les 4 gros condos servent à la sortie tube et les 4 plus petits à la sortie transistor
qu'en pensent les experts ??
(photo avec symétrie...)
Paulkouhan
Message » 28 Juin 2008 11:58
Ce sont des régulateurs que j'ai entouré en rouge ?
Ca vaudrait peut-être la peine de leur ajouter des dissipateurs...
Metaxas44
Inscription Forum: 10 Avr 2006 17:18
Message » 28 Juin 2008 13:32
si tu ne changes pas la valeur des condos qui sonts devant , inutile de les refroidires d'avantage , ils sonts concus pour .
pour les condos de sorties je saurais pas te dire , tu as trois sorties et 8 condos , je pense qu'il y en a 4 pour le tube rca et 4 pour le XLR
encore un detail , si tu changes ta lampe , tu pouras aussi changer la valeur UF de tes condos de sortie de maniere qu'elle soit adaptée , mais je laisse le soin aux experts pour te donner cette valeur de condo suivant la lampe que tu veux mettre.
sinon une autre astuce , les AOP zenitude sonts bitumés , ca sans doute son utilitée que tu pourais reproduire sur les burson , fais quand meme gaffe de ne pas utiliser de chaterton ou autre trucs qui fondent car les AOP ca chauffe dur , voila une photo de ma platine avec les AOP zenitude , ca peu te donner de l'idée:
josselin_baumont
Message » 20 Juil 2008 14:36
Je continue mon tweak.
1) ajout de 2 condensateurs 0.1µF sur les pins 4 et 8 des burson
2) remplacement des condensateurs 4.7µF WIMA MKP10 par des Mundorf MCAP
Alors que j'étais branché sur la sortie "transistor" depuis que j'avais mis les Burson, c'est maintenant la sortie "Tube" qui donne les meilleurs résultats (de peu)... :-? (scène sonore, basses...)
Je n'ai plus qu'a remplacer les 8 condensateurs WIMA 0.1µF (il y en a 4 autres sous la carte !)
J'ai commandé des Mundorf MCap ZN 630V, ils ne sont pas trop gros (11x24mm), je n'ai pas beaucoup de place !
Paulkouhan
Message » 20 Juil 2008 19:46
bien ton montage des mcap , du silveroil aurais ete mieux mais bien plus cher .
tu as lu mon message ou je te propose de recouvrir tes burson avec du bitume? ( ca reduit les resonances )
maintenant je te propose de remplacer tes diodes de recouvrement par un model ultra rapide : cout 2€ pour les 8 pieces
josselin_baumont
Message » 20 Juil 2008 20:40
Du Silver oil aurait couté presque aussi cher que le DAC !! :mdr:
Sinon, pour le bitume, ça risque de faire sauter la garantie, non ?
Tu as des références pour les diodes ?
Merci pour tes conseils !
Paulkouhan
Message » 20 Juil 2008 22:27
Il parait que les Bursons sont en fait d'origine chinoise !... Est-ce-que quelqu'un en sait davantage sur le sujet ?
ondesx
Inscription Forum: 03 Mai 2003 9:28
