Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Farade, fourD, mroboto, plhjunior et 67 invités
SHM CD
Message » 24 Avr 2010 11:21
musicard a écrit:"I have been a Recording and Broadcast technical Engineer since the 1980s. I was instrumental in the introduction of Digital Recording systems into the UK Recording Industry, and was a CD mastering engineer for several years.
This is pure marketing hype!
OK so Sony can now make better Glass Masters, which will probably make the glass master last longer & produce less manufacturing failures.
But it will make no difference to the sound as heard by the punter, no matter how good their equipment is.
A CD has 16 bits, and samples at 44.1khz, thus giving a theoretical dynamic range of 96dB & 0-20kHz frequency range.
Servo jitter is caused by keeping the laser following the pits as the disk spins, its not the sharpness of the edge that casues most of this jitter, but the eccentricity of the spiral of pits, the blue laser will not improve this. If the player's electronics is designed properly all jitter, and any errors in disk reproduction will be corrected, note error correction is mathematically 100% accurate, digital data has only 2 values 1 & 0, if the laser reads a 0 & the correction system knows its the wrong value, then it changes it to a 1, i.e. the original value! It is not possible to hear error correction, because correction results in the original data. Its only when the data loss is so bad that error correction cannot cope, and concealment is used, that it becomes audible.
As to jitter, all digital systems have jitter, its intrinsic in how the electronics works, jitter is only a problem when the data is converted from one form to another, i.e. when the microphone signal is digitised, or when the CD signal is converted into analogue so it can be heard. Any jitter in the signal being read from the CD is removed by reading the data into a buffer (memory) at the jittering rate, then reading it out again under the control of a very low jitter master clock.
What makes a difference to the sound of a CD player, is not the transport & disk laser system, but the accuracy of the Digital to Analogue conversion, the 'quality' of the low pass filtering (to remove all audio above 20kHz), and the prevention of cross-talk from the digital electronics getting into the analogue electronic circuits (noise induced on the power supplies, radiation etc).
As John Watkinson commented when referring to digital interconnect leads, if the sound is changed by the replacing of a cable, its because the equipment has not been designed properly, not the quality of the cable. The same goes for these Blu-Spec CDs, if they sound better than ordinary CDs on your CD player, then the CD player was not very well designed. Or perhaps more care was taken at the mastering stage that produced the digital master tape used to make the CD Glass master, but that would make an ordinary CD sound just as good.
Anyone who pays out hard earned cash for a Blu-spec CD wants their head seeing to.
As to SACD, this is a vastly superior delivery format, and despite what was stated above, it is very clearly audible, even to un-trained ears, providing the material justifies it, much modern ‘pop’ music has its dynamic range squashed to death, so that it sounds loud on the radio, and the production standards are often very low. Whereas some artists have made use of the wide frequency response and large dynamic range SACD offers resulting in stunning recordings. The old adage GIGO springs to mind, ‘Garbage In Garbage Out'.
Hybrid SACDs will play on any normal CD player, and it is possible to have a stereo CD mix, a stereo SACD mix and an SACD surround mix, all on the one disk. Thus providing a single inventory, one disk that plays on all players. Sony should put their efforts in promoting SACD not this Blu-Spec CD rubbish.
And don’t get me started on MP3 and other data compressed formats."
Et voilà. Tout est dit. ;)
And the right will prevail, all our troubles shall be resolved
We have faith in the Lord, unless there's money or sex involved
(Frail Grasp On The Big Picture)
Themisto
Inscription Forum: 16 Mai 2008 14:02
Message » 24 Avr 2010 12:08
Je pense que plutôt que de parler du format en lui-même on devrait évoquer le mastering, car dans le cas de Magma, j'ai du mal à comprendre comment les Japonais arrivent à repartir des bandes d'origine alors que les CD originaux édités par la Maison de Disque du groupe (Seventh Records) sont de qualité déplorable?
ludovico69
Inscription Forum: 01 Mai 2009 10:53
Message » 05 Mai 2010 2:39
Pour répondre à ta question, il est probable que le label japonais a acheté une licence d'exploitation à Seventh Records pour un tirage de par exemple 3000 copies par albums. Dans le cadre de cette licence, le label japonais s'est fait remettre une copie des masters qu'il a retravaillé dans ses propres studio. Ou, inversement, l'initiative vient peut-être de Seventh Records vers le label japonais.
Le fait est que ce qui change le son est la remasterisation, pas le format SHM. Le truc utilisé par Universal propriétaire de la technologie "SHM" est d'omettre de dire que le CD a été remasterisé et de simplement mentionner "SHM". Ainsi, les gens attribuent à la technologie des propriétés qu'elle n'a pas, à savoir améliorer le son d'un CD. Et, partant, cela permet de faire acheter aux consommateurs des CD SHM les yeux fermés, ce qui permet à Universal de glisser dans sa liste de SHM remasterisés, des SHM non-remasterisés qui sont l'équivalent sonore du CD standard sorti il y a dix ans et de les vendre au plein prix. J'ai fait un compte-rendu plus détaillé sur les CD japonais ici:
viewtopic.php?f=1032&t=29940071
musicardie
Inscription Forum: 05 Mai 2010 2:10
Retourner vers Câbles
