Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: bab1c, banjo65, bon1410, coucouse, Deniss31, Franckt, Francois10, gigxy, Goby92, gwendal55, Hehe, Kevin26, Kristo13, magneto, Miky10, mirak, moulinos, olivierdo, Patbon21500, Poune, silvain24, Stade81 et 156 invités
Dune HD Duo
List of changes: (applies to all models of receivers)
A. Implemented functions to hide channels and cancel channels to hide.
Two. Reproduction of closed channels are not automatically restored (instead, it runs the first channel in the
list).
Three. In the case of the end of the subscription or other problems with the subscription, the player immediately
has a button to quickly enter a new login / password.
4. Implemented reset the date to the current date when you switch to another channel in the EPG-menu.
Five. Kartina Micro HD: Enabled mechanism of IP-player control (remote-application support for iOS / Android
etc).
6. Added two new ZOOM-mode.
7. Improved reset: you can select the "full" and "soft" reset.
Eight. Improvements in initial setup wizard video mode: with HDMI-connected automatically offers the best video
mode according to information from the EDID-TV.
9. Dune HD TV-301: Better rendering of fonts in a web browser and flash applications.
10. Fixes for Wi-Fi.
11. Fixed problem with false alarms remote control in some cases.
12. Fix: formatting function not working HDD; other improvements in formatting functions.
13. Fixed a problem with the inability to play the files with some USB HDD volume over 2TB
list).
etc).
- costaud
- Contributeur HCFR 2019
- Inscription Forum: 05 Oct 2004 20:51
Merci l'ami, voici la traduction Google :
Liste des changements: (s'applique à tous les modèles de récepteurs)
A. Mise en œuvre des fonctions pour cacher les chaînes et d'annuler les canaux pour se cacher.
Deux. La reproduction de canaux fermés ne sont pas automatiquement restauré (au lieu, il court le premier canal de la
la liste).
Trois. Dans le cas de la fin des problèmes d'abonnement ou autre avec l'abonnement, le joueur immédiatement
dispose d'un bouton pour accéder rapidement à un nouveau login / mot de passe.
4. Mise en œuvre réinitialiser la date à la date actuelle lorsque vous passez à un autre canal dans l'EPG-menu.
Cinq. Kartina Micro HD: mécanisme a permis d'IP-joueur de contrôle (à distance demande de soutien pour iOS / Android
etc).
6. Ajout de deux nouvelles ZOOM-mode.
7. Amélioration de la réinitialiser: vous pouvez sélectionner le «plein» et «douce» remis à zéro.
Huit. Améliorations dans le mode de configuration vidéo initiale assistant: avec HDMI-connecté propose automatiquement la meilleure vidéo
Mode selon les informations de l'EDID-TV.
9. Dune HD TV-301: un meilleur rendu des polices dans un navigateur Web et d'applications flash.
10. Corrections pour Wi-Fi.
11. Correction d'un problème avec le contrôle à distance des alarmes fausses dans certains cas.
12. Correction: la fonction de formatage du disque dur ne fonctionne pas; d'autres améliorations dans les fonctions de formatage.
13. Correction d'un problème avec l'incapacité de lire les fichiers avec un peu de volume disque dur USB de plus de 2To...
la liste).
etc).
DIFFUSEUR LG 77G3 / LG 65C9 SOURCE PANASONIC 820 / ZIDOO Z9X PRO et Z9X / APPLE TV 4K AMPLI SMYTH REALISER A16 TELECOMMANDE IPAD AIR VIBREUR EARTHQUAKE Q10B CASQUE DENON AH - D 9200 / FOSTEX TH 610 / SONY MDR 700 ECLAIRAGE PHILIPS HUE
- patriceonkyo
- Inscription Forum: 17 Nov 2005 13:26
Salut
Y a t'il possibilité de lire les ISO blu ray 3D sur la duo sans passer par les menus.
J'ai fait des essais sur plusieur iso 3D mais certain ne passe pas et les autre faut se taper tout les menus avant de pouvoir lancer le film.
Donc si quelqu'un a une solution pour voir directement le film je suis preneur car même lire en direct le fichier m2ts ne marche pas.
Meci pour vos futur réponce.
- lobys
- Inscription Forum: 18 Avr 2011 16:23
Étrange, je m’apprêtais a faire la toute dernière mise a jour sur mes 2 Duo, et elles ne figurent pas en lecture depuis la Dune...
Patrice
Patrice
- patriceonkyo
patriceonkyo a écrit:Étrange, je m’apprêtais a faire la toute dernière mise a jour sur mes 2 Duo, et elles ne figurent pas en lecture depuis la Dune...
Patrice
Idem pour moi
- anfi43
- Inscription Forum: 05 Nov 2004 16:05
Petite question les amis :
Actuellement j'utilise mon lecteur Oppo 93 de base branché en Coaxial pour lire mes fichiers flac via un DD Externe.
Seulement mon petit DD commence à déborder donc plutôt que d'acheter un DD Externe d'1 To je pensais me prendre un HD DUO.
Mais niveau qualité audio pure en stéréo Analogique ou Coaxial vais-je retrouver la même qualité que via l'Oppo ?
- TheRedDevil7
- Inscription Forum: 26 Jan 2009 18:15
Bonsoir à tous,
J'ai craqué il y a plus d'1 an pour une HDMax (dans la salle de ciné) puis une HDDuo (salon), c'est dire si je suis content des produits HDi.
J'ai un petit problème : je n'arrive pas à lire les fichiers multimédia à partir d'un disque de 3To (disque int et USB). Les fichiers apparaissent à l'écran pourtant.
Est ce normal? Y a t-il une manoeuvre spéciale?
Mon firmware actuel sur mes 2 platines est le 120202 1544 béta.
J'ai vu sur la page précédente un lien pour un autre qui est le 120329 2012. S'agit-il d'un firmware officiel? Je ne l'ai pas trouvé sur le site de HDi.....Peut-on également l'installer sur le HDMax?
Merci de votre aide
Merci de votre aide
- iboudoc
- Inscription Forum: 07 Déc 2008 19:12
Bonsoir
Il me semble que pour les 3to il Faut les formater sous Windows.
Christophe Cherel en parle dans le forum d'HDLand.
- cricri88
C'est pourtant ce que j'ai fait. Formatage avec W7 en NTFS.
Je vais aller jeter un coup d'oeil sur le forum de HDLand...
Merci en tout cas.
Merci en tout cas.
- iboudoc
TheRedDevil7 a écrit:Petite question les amis :
Un avis les amis ?
- TheRedDevil7
Nouveau firmware: http://dune-hd.com/firmware/
Attention beaucoup de changements, pas tout testé, donc là c'est vraiment du beta, à tester donc pour ceux qui veulent, en cas de problèmes retour à l'ancien
- costaud
J'ai installé le firmware 120202 1544 béta (j'attends des retours AV d'installer le dernier) et mon problème a été résolu .
Je peux enfin lire les fichiers qui sont sur mon disque de 3 To (WD elements Desktop USB 2).
Merci à tous...
Merci à tous...
- iboudoc
Nouvelle Beta dispo ce jour ...
Patrice
Patrice
- patriceonkyo
Sur la site de HDI Dune Firmware on trouver dernière version beta "120531_2200_beta" et mon Dune Duo trouver encore plus recente firmware 120608_1420_beta"
vous aussi ?
Rien sur site official.
vous aussi ?
- Alpheratz13
- Inscription Forum: 22 Mar 2009 12:29
Alpheratz13 a écrit:Bonjour,
vous aussi ?
Tiens j'ai pas fait attention, je vais voir ça sur mes DUNE
Edit: Je confirme dispo aussi pour ma smart, téléchargement en cour , merci pour l'info
- costaud
