La bonne nouvelle c'est que j'ai tout : le caisson et l'anti-mode
Modérateurs: Modération Forum Haute-Fidélité, Modération Forum Univers Casques, Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: david_35, pinou123 et 28 invités
If you have a 2.1 or 2.2 system (main speakers with one or two subwoofers) with existing cross-over, connect Dual Core before the cross-over. Your system is then seen as a 2.0 full-range system by the Dual Core and both your main speakers and subwoofer(s) will be corrected.
It is also possible to connect speakers and subwoofer(s) in parallel. In this case the combined response is measured and corrected by Dual Core. The subwoofer level and phase must be adjusted before calibration. You can use the Measurement tool to find the best settings.
