Modérateurs: Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: retour1984, tagapass et 87 invités
Salle dédiée HC en sous sol de kbil69
Message » 10 Mai 2015 17:46
Black-Dragon a écrit:Pour Windows va faire un tour ici en mettant comme ip celle de ton mac
et pour mac un tour en mettant comme ip celle de ton PC
Ping en boucle sur mon iMac:
PING 127.0.0.1 (127.0.0.1): 56 data bytes
64 bytes from 127.0.0.1: icmp_seq=0 ttl=64 time=0.075 ms
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.068 ms
64 bytes from 127.0.0.1: icmp_seq=2 ttl=64 time=0.069 ms
64 bytes from 127.0.0.1: icmp_seq=3 ttl=64 time=0.059 ms
64 bytes from 127.0.0.1: icmp_seq=4 ttl=64 time=0.070 ms
64 bytes from 127.0.0.1: icmp_seq=5 ttl=64 time=0.071 ms
64 bytes from 127.0.0.1: icmp_seq=6 ttl=64 time=0.069 ms
64 bytes from 127.0.0.1: icmp_seq=7 ttl=64 time=0.069 ms
--- 127.0.0.1 ping statistics ---
8 packets transmitted, 8 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.059/0.069/0.075/0.004 ms
Ping iMac avec IP PCHC:
IMAC-DE-****:~ ********$ ping 169.254.32.103
PING 169.254.32.103 (169.254.32.103): 56 data bytes
64 bytes from 169.254.32.103: icmp_seq=0 ttl=128 time=0.495 ms
64 bytes from 169.254.32.103: icmp_seq=1 ttl=128 time=0.331 ms
64 bytes from 169.254.32.103: icmp_seq=2 ttl=128 time=0.402 ms
64 bytes from 169.254.32.103: icmp_seq=3 ttl=128 time=0.434 ms
64 bytes from 169.254.32.103: icmp_seq=4 ttl=128 time=0.368 ms
64 bytes from 169.254.32.103: icmp_seq=5 ttl=128 time=0.327 ms
64 bytes from 169.254.32.103: icmp_seq=6 ttl=128 time=0.232 ms
64 bytes from 169.254.32.103: icmp_seq=7 ttl=128 time=0.378 ms
64 bytes from 169.254.32.103: icmp_seq=8 ttl=128 time=0.356 ms
64 bytes from 169.254.32.103: icmp_seq=9 ttl=128 time=0.326 ms
64 bytes from 169.254.32.103: icmp_seq=10 ttl=128 time=0.329 ms
64 bytes from 169.254.32.103: icmp_seq=11 ttl=128 time=0.406 ms
Ping PCHC en boucle:
Ping PCHC avec IP Imac:
IP config /all sur le PCHC:
Différents Ping énumérés sur ton lien:
Ps; s'il y a des infos à ne pas mettre en ligne, merci de me prévenir :ko:
kbil69
Message » 10 Mai 2015 17:47
Je vais essayer de voir une vidéo en 1080p en direct entre l'iMac et le PC via le câble cat6a RJ45, je vais tester ça et je vous dit ...
kbil69
Message » 10 Mai 2015 17:57
Ca y est, le test de lecture d'un fichiers 1080p de 11Go en direct s'est mal passé, idem, lecture normal durant 1 à 2 minute puis écran figé, lag, ... :zen:
Si je fais pause ou avance c'est encore pire.
kbil69
Message » 10 Mai 2015 18:08
kbil69 a écrit:Ca y est, le test de lecture d'un fichiers 1080p de 11Go en direct s'est mal passé, idem, lecture normal durant 1 à 2 minute puis écran figé, lag, ... :zen:
Et si tu met ce film sur le PC et que tu le lit, t'as pas de soucis ?
Black-Dragon
Inscription Forum: 11 Mar 2011 0:04
Message » 10 Mai 2015 18:09
Bein non, aucun, c'est comme ça que je fais.
J'en ai essayé plusieurs ...
kbil69
Message » 10 Mai 2015 19:20
Et tu es toujours connecté en direct entre mac et pc ?
VaTeK
Inscription Forum: 02 Oct 2013 14:56
Message » 10 Mai 2015 19:56
Comme je suis pas fan des produits à la pomme, je ne connait pas du tout.
Mais ca parrait incompréhensible.
Black-Dragon
Message » 10 Mai 2015 20:20
VaTeK a écrit:Et tu es toujours connecté en direct entre mac et pc ?
Non, c'était pour tester si le switch RJ45 et/ou la box NC créaient des soucis, en direct je n'ai plus internet car il n'y a qu'une entrée RJ45 sur mon iMac.
kbil69
Message » 10 Mai 2015 20:24
je vais peut être poser une question bête mais tu as un rj45 relié entre ton mac et ton pc ? Si oui est il croise ou droit ?
Caribbean's Space 62
fanvw
Modérateur Installations
Message » 10 Mai 2015 20:26
Black-Dragon a écrit:Comme je suis pas fan des produits à la pomme, je ne connait pas du tout.
Incompréhensible, et en analysant les tests ping cela donne quoi ?
Ps: je suis en IPV4, pas en 6.
Un truc qui peut apporter sa pierre à l'édifice:
- si j'essaye d'accéder à mon PCHC depuis l'iMac il n'y arrive pas (pourtant je vois le PCHC dans les périphériques partagés dans le FINDER), en faisant des recherches il faut à priori un mot de passe pour la session que j'utilise (unique) sur le PCHC, sinon MacOs n'apprécie pas, là en cliquant sur CONNEXION sous l'iMac je tape le bon utilisateur PERSONNEL et je ne rentre pas de mot de passe, il ne se connecte pas.
Mais je n'ai pas envi de devoir taper un mot de passe à chaque fois que j'allume mon PCHC :evil:
- en sens inverse, PCHC -> iMac cela fonctionne, c'est comme ça que je transfert mes fichiers.
kbil69
Message » 10 Mai 2015 20:32
fanvw a écrit:je vais peut être poser une question bête mais tu as un rj45 relié entre ton mac et ton pc ? Si oui est il croise ou droit ?
Aucune idée :wtf:
http://www.touslescables.com/z.php?txli ... ose&a=Z3J0
Mais droit à priori en cliquant sur MEME CATEGORIE ET BLINDAGE:
Ce câble droit de Cat6a est blindé SFTP, c'est-à-dire que chaque paire est blindée par un écran, et en plus la gaine extérieure est blindée par une tresse. Ce blindage est le meilleur possible.
kbil69
Message » 10 Mai 2015 20:39
kbil69 a écrit:Mais je n'ai pas envi de devoir taper un mot de passe à chaque fois que j'allume mon PCHC :evil:
As-tu un moyen de supprimer ce mot de passe, pour être le plus "direct" possible ?
Rif hi-fi
Inscription Forum: 25 Jan 2008 0:39
Message » 10 Mai 2015 20:41
Je dois mal m'exprimé, je n'ai pas de mot de passe sur mon PCHC, j'allume et j'arrive directement sur le bureau de win7.
Mais d'après mes lectures pour passer de l'iMac au PC il faut une session avec mot de passe, chose que je n'ai pas pour les raisons évoquées.
kbil69
Message » 10 Mai 2015 21:28
Pour le Ping Test vu qu'il n'y a pas de perte de paquets tous à l'aire bon.
Pour ton histoire de mots de passe je ne voit pas trop pourquoi la lecture serait bonne pendant trois minutes et saccade après.
Mais bon tu peu toujours essayé en mettant un MDP sur ton PC.
Ensuite pour ne pas à avoir à le taper à chaque ouverture de session tu fait
touche windows+R, à l'invite de commande tu tape "control userpasswords2" sans les guillemet.
Tu arrives sur les priorités du compte utilisateur et tu décoche " les utilisateurd doivent ........ ".
Il va te demander de confirmer en tapant ton MDP.
A partir de maintenant, pour rentré dans ta session pas de MDP, par contre depuis un accès réseau il te demandera
le nom d'utilisateur et le MDP.
Reste plus qu'à enregister ces info sur le mac.
Black-Dragon
Message » 10 Mai 2015 21:56
Ca cela me plait comme réponse :P
Merci, j'essaye de tester cela demain :wink:
kbil69
