j'ai une carte TNTSAT en local sur le vu+, et l'astlas avec la carte 18
j'ai ce type d'erreur :
- Code: Tout sélectionner
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1811 ECM_PID: 0175 PROVID: 003315
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1811 ECM_PID: 0176 PROVID: 003317
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 1812 ECM_PID: 0174 PROVID: 00A825
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 1811 ECM_PID: 0177 PROVID: 00A821
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0500 ECM_PID: 0182 PROVID: 040F40
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 5 CAID: 0500 ECM_PID: 0184 PROVID: 032830
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 6 CAID: 0500 ECM_PID: 0185 PROVID: 043330
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 7 CAID: 0500 ECM_PID: 0188 PROVID: 030B00
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 8 CAID: 0500 ECM_PID: 0183 PROVID: 032940
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 9 CAID: 1863 ECM_PID: 017D PROVID: 003342
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 10 CAID: 1863 ECM_PID: 017E PROVID: 003343
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 11 CAID: 0100 ECM_PID: 0177 PROVID: 00A821
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 12 CAID: 0100 ECM_PID: 0174 PROVID: 00A825
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 13 CAID: 0100 ECM_PID: 0176 PROVID: 003317
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 ecmpid 14 CAID: 0100 ECM_PID: 0175 PROVID: 003315
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 skipped stream CAID: 0100 ECM_PID: 0177 PROVID: 00A821 (Same as ECMPID 11)
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 skipped stream CAID: 0100 ECM_PID: 0174 PROVID: 00A825 (Same as ECMPID 12)
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 skipped stream CAID: 0100 ECM_PID: 0176 PROVID: 003317 (Same as ECMPID 13)
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 skipped stream CAID: 0100 ECM_PID: 0175 PROVID: 003315 (Same as ECMPID 14)
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 found 15 ECMpids and 12 STREAMpids in PMT
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 serving srvid 200B (1811@003315:200B unknown) on adapter 0000 camask 0001 index 0000 pmtpid 012C
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 trying to descramble PID 7 CAID 0500 PROVID 030B00 ECMPID 0188 ANY CHID PMTPID 012C VPID 0136
2015/06/25 13:28:56 00572468 c (ecm) localuser (0500&030B00/150D/0188/200B/C4): not found (147 ms) by tntsat - Canal+ Cinema (Unknown ECM type)
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 trying to descramble PID 14 CAID 0100 PROVID 003315 ECMPID 0175 ANY CHID PMTPID 012C VPID 0136
2015/06/25 13:28:56 00572468 c (ecm) localuser (0100&003315/5C00/0175/200B/64): rejected caid (2 ms) (invalid caid 0x0100)
2015/06/25 13:28:56 00572468 c (ecm) localuser (0100&003315/5C00/0175/200B/64): rejected caid (1 ms) (invalid caid 0x0100)
2015/06/25 13:28:56 00572468 c (dvbapi) Demuxer 0 restarting decodingrequests after 16 ms with 2 enabled and 13 disabled ecmpids!
2015/06/25 13:28:57 00572468 c (ecm) localuser (0500&030B00/150D/0188/200B/C4): not found (1 ms) by tntsat - Canal+ Cinema
2015/06/25 13:28:57 00572468 c (dvbapi) Demuxer 0 trying to descramble PID 14 CAID 0100 PROVID 003315 ECMPID 0175 ANY CHID PMTPID 012C VPID 0136
2015/06/25 13:28:57 00572468 c (ecm) localuser (0100&003315/5C00/0175/200B/64): rejected caid (1 ms) (invalid caid 0x0100)
2015/06/25 13:28:57 00572468 c (ecm) localuser (0100&003315/5C00/0175/200B/64): rejected caid (0 ms) (invalid caid 0x0100)
2015/06/25 13:28:57 00572468 c (dvbapi) Demuxer 0 restarting decodingrequests after 12 ms with 2 enabled and 13 disabled ecmpids!
2015/06/25 13:28:57 00572468 c (dvbapi) Demuxer 0 trying to descramble PID 7 CAID 0500 PROVID 030B00 ECMPID 0188 ANY CHID PMTPID 012C VPID 0136
2015/06/25 13:28:58 00572468 c (ecm) localuser (0500&030B00/150D/0188/200B/C4): not found (2 ms) by tntsat - Canal+ Cinema
2015/06/25 13:28:58 00572468 c (dvbapi) Demuxer 0 trying to descramble PID 14 CAID 0100 PROVID 003315 ECMPID 0175 ANY CHID PMTPID 012C VPID 0136
2015/06/25 13:28:58 00572468 c (ecm) localuser (0100&003315/5C00/0175/200B/64): rejected caid (0 ms) (invalid caid 0x0100)
2015/06/25 13:28:58 00572468 c (-) -- Skipped 1 duplicated log lines --
