Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: Patounette et 18 invités
Tout ce qui concerne les lecteur Blu-ray UHD
PIONEER UDP-LX800 (màj)
Message » 23 Sep 2018 15:13
ES 9026 pro pour le dac??? A ce prix là ce n'est pas extraordinaire.
Le AK4493 DAC du Panasonic 9000 semble meilleur sur le papier.
Le AK4490EQ du Pioneer LX500 n'a pas l'air loin non plus.
Extrait du sujet sur blu-ray.com (https://forum.blu-ray.com/showthread.php?t=307880&page=9):
Comparisons to competition - DACS used
The Oppo UDP-205 is considered best in its class for audiophiles. It's equipped with two ESS Technology ES9038PRO DACs for both stereo and 7.1 channel analog audio. The ES9038PRO is the flagship of the ESS PRO series. It sets a new benchmark for audio excellence with its best-in-class 140 dB of dynamic range, total harmonic distortion plus noise (THD+N) at -122dB in a 32-bit, 8-channel DAC.
The Panasonic UB9000 model is using the AK4493 DAC - Dynamic range, S/N: 123dB, THD+N: -113dB
The Pioneer UDP-LX500 will be using the AK4490EQ DAC - Dynamic range, S/N 120 db, THD+N -112 db
The Sony x1000 model is using some high performance 32 bit DAC (DSD 11.2 MHz, LPCM 192kHz capable) are the only details I find.
The Pioneer UDP-LX800 will be using the ES9026PRO DAC - Dynamic range, S/N 124 db, THD+N -110 db
So Pioneer for the $2200 did absolutely nothing in stepping up their DAC quality compared to the previous ES9018 used in the BDP-LX88 which offered dynamic range 129 dB and -120 dB THD.
About the only thing that might be a advantage is that the ES9026PRO might decode MQA only, otherwise it's a universal format tank player with so so DAC's.
oliviergregoire
Inscription Forum: 07 Mar 2003 18:25
Message » 24 Sep 2018 18:57
Mon Oppo 103D venant de rendre l'âme :evil: Ca peut être un choix possible, mais avec 1300 € d'écart avec la Pana :o , il y a intérêt a y avoir une plus value très visible et très audible…
Vivement un bon test comparatif.
Find In Your Mind the Accuphase Sound!
GuileZ_
Inscription Forum: 15 Mar 2007 22:26
Message » 25 Sep 2018 15:15
Test Pioneer UDP-LX800 dans les Années Laser d'Octobre !
Cyrano222
Inscription Forum: 02 Sep 2008 13:31
Message » 25 Sep 2018 19:00
Cyrano222 a écrit:Test (publi-informationnel) Pioneer UDP-LX800 dans les Années Laser d'Octobre !
:siffle:
GuileZ_
Message » 25 Sep 2018 20:31
tu l'as lu ?
misterme
Inscription Forum: 06 Sep 2007 13:20
Message » 26 Sep 2018 8:20
Effectivement dans LAL, il est dit que c'est une belle machine, très bonne en audio, menus un peu passés et non compatible HDR10+ :roll:
Préamp YAMAHA CX-A5200|Amps PARASOUND A21&A23 & INTEGRA DTA70.1|Subs JBL ARRAY1500/KLIPSCH KA1000+2 KW-120THX|Enceintes JBLTI10K RC64mk3 KS525 RP502S RB81mk2|CD Yamha CDS2100|BluRay PANA UB9000|VP SONY VW270ES|OLED PANA 55Z95AEG|
Inscription Forum: 02 Mar 2008 17:38
Message » 26 Sep 2018 17:07
777 a écrit: et non compatible HDR10+ :roll:
Selon cet article, il pourrait le devenir via une MAJ...
Pioneer dévoile son nouveau lecteur BD UDP-LX800 UHD
http://www.cdrinfo.com/Sections/News/De ... wsId=70553
https://translate.google.com/translate? ... Id%3D70553
The new player also supports Dolby Vision (Dolby Vision) HDR. Pioneer says that support for HDR10 + is also possible through a firmware update.
phill59
Inscription Forum: 08 Mai 2014 23:10
Message » 26 Sep 2018 18:09
Si l'on suit LAL, le LX800 obtient les notes suivantes : Fonctions/équipement : 9.5 - Ergonomie : 7 - Performances : 9 pour 2300 € (Lecture SACD/DVD-A incluse, sortie 7.1 exclue)
Et toujours selon LAL, le Pana 9000 obtient : Fonctions/équipement : 9.5 - Ergonomie : 8 - Performances : 9.5 pour 1200 € (Lecture SACD/DVD-A exclue, sortie 7.1 inclue)
L' Oppo 205 propose toutes les fonctionnalités (SACD/DVD-A + sorties analogiques 7.1) + des perfs de hautes volées qui peuvent encore être améliorées grâce aux tweaks, le tout pour 1800 €.
Je pense que Oppo n'est pas encore réellement remplacé !
SYLEX
Membre HCFR Contributeur
Message » 26 Sep 2018 19:43
SYLEX le retour :roll: :mdr:
yanikus
Inscription Forum: 22 Nov 2005 19:42
Message » 27 Sep 2018 11:41
les concurrentes de cette lx800 sont donc bien la pana9000 et l'oppo 205. Espérons que la marque ne réitère pas certains déboires. J'irai lire le test de LAL ce we. J'avoue avoir un faible teinté de nostalgie pour pioneer. Je suis donc content et curieux de voir la marque investir l'uhd par le Hdg...
Hifi-Homecinéphilement vôtre...
Roseaux
Modérateur Home-Cinéma
Inscription Forum: 09 Mar 2010 14:32
Message » 27 Sep 2018 12:36
+ 100
Cyrano222
Message » 27 Sep 2018 13:41
yanikus a écrit:SYLEX le retour :roll: :mdr:
En lisant ça, je m'aperçois que je viens de passer les 20 000 posts. :oldy: :ko:
SYLEX
Message » 27 Sep 2018 14:51
SYLEX a écrit:Si l'on suit LAL, le LX800 obtient les notes suivantes : Fonctions/équipement : 9.5 - Ergonomie : 7 - Performances : 9 pour 2300 € (Lecture SACD/DVD-A incluse, sortie 7.1 exclue)
Le 205 avait obtenu les notes suivantes : Fonctions/équipement : 10 - Ergonomie : 10 - Performances : 8.5 pour 1800 € (Lecture SACD/DVD-A incluse, sortie 7.1 incluse)
SYLEX
Message » 27 Sep 2018 16:07
SYLEX a écrit:Nous sommes bien d'accord : les tests LAL manquent cruellement de rigueur, aucune mesures n'est effectuée, pas de référence donc, les notes sont subjectives et les comparaisons forcément faussées par le délai entre chaque test. Ils sont à prendre avec des pincettes..
Personnellement, je trouve les Pioneer beaucoup plus beaux que les Oppo. Et c'est comme pour les voitures, où un tas de critères techniques sont à prendre en considération, et où finalement on les achète pour l'esthétique, l'image de la marque, etc. :lol:
Sylex, l'éternel recommencement, de l'âge de pierre, à l'âge de pierre ! :wink:
Je l'ai déjà signalé précédemment ici même, mais il est HORS de question que ce topic parte en sucette comme celui du LX88 !
À bon entendeur...........
Cyrano222
Message » 27 Sep 2018 16:12
Ce qui signifie qu'il est interdit de comparer un Pioneer à un autre modèle d'une autre marque ?
Sincèrement, je suis peut être un vieux c.n comme tu sembles l'insinuer gentiment, mais je ne comprends pas le sens de ton intervention. Je ne fais aucun commentaire, je ne lance aucun débat, je me contente de reporter des notes d'un même magazine sur 3 produits similaires. Et effectivement, les "tests" de LAL manquent de mesures objectives.
SYLEX
