Merci à olivierQC pour l'info qui suit :
Nouvelle version de HT 2.0 (avec la possibilité, entre autre, de profiter dorénavant des bandes annonces. )
Changelog Home Theater 2.0 (v2.9.28)
1. Increase the viewing history of recently, added forced time reverse display
2. Optimize the title recognition, compatible with the "season x. Episode xx" video
3. When adding to the collection, focus control of the collection list
4. Solve the problem of possible crash when scanning occasionally
5. Automatically categorized collection movies, adding "Remove Collection" function
6. Optimized movie added to the collection function
7. Movie category added to the left column of the home page
8. The movie details interface adds a trailer function (can be turned off in the settings)
9. Optimize the display of the new collection of personalized pictures
10. Solve the problem that the pictures of Douban matching movies are not clear
11.Optimize the function of getting local pictures automatically if the movie has no poster when the priority local picture switch is turned off
12. Rematch and add poster preview function
13. Solve the problem that the details entered by NFO will occasionally crash
14. When the child lock password protection is turned off, the main interface will no longer display the lock icon
15. Solve the problem that movies with the same title in different years will be matched into the same movie
16. Added CLEARLOGO function in the detail interface
17. Increase the function of Pop-up button of remote control
18. Solve the problem that "scanning" is always displayed when adding devices
19. Solve the problem that the change of poster language does not take effect
20. Optimized sorting function
21. Priority search for TMDb during smart search
22. Optimize child lock function
http://forum.zidoo.tv/index.php?threads ... 99/page-15
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: alj92, bab1c, badgero, coucouse, Hehe, Jerjoval57, Jigsaw, Kristo13, kristof59, Neo_77, papounay, pyro57, Stade81, stanis384, yoann2004 et 103 invités
Zidoo UHD2000 4k HiFi (màj)
HC: JVC NP5 -Giec G5800 -Oppo 205 -Zidoo UHD3000 -AppleTV4K -Arcam(AV860+P7+P429)
-B&W(3xHTM4D2 6xDS3 2xDS6 1xDB1)
Salon HiFi : Panasonic 55LZ2000 -Panasonic UB820 -Technics SLG700M2 -Oppo 203 -B&W 804D2 -Advance(XPREAMP+XA160) -Zidoo NEO X
mirak - Membre d'Honneur
- Inscription Forum: 25 Déc 2006 0:09
Bonjour Mirak,
Je me suis permis de placer votre test du UHD2000 sur le forum Zidoo hier soir, Nice Monkey a répondu :
Nice review with a lot of benchmarking/comparing audio and video in high end setups. Job well done. Only remark here is that the used equipment is a bit dated here and there with lack of actual advanced audio/video standards.
No surprises, their experiences are mostly identical to mine. Some noticeable experiences:
- Upscaling 1080P to 4K is probably best left to your projector/TV
- Conversion HDR => SDR is not the strongest feature with RTD1296
- Don't ignore the Digital Filter choices with the DAC they are subtle but definitely audible
- The most convenient way to switch between HDMI audio and DAC audio is using Zidoo Controller setup. Also applies to choosing Digital Filters
Et voilà le lien si quelqu’un veut engager la discution :
Zidoo UHD 2000 - Test Homecinema-fr.com
A bientot
A bientot
- OlivierQC
- Contributeur HCFR 2018
- Inscription Forum: 23 Avr 2003 14:01
Bonjour olivierQC
Merci infiniment pour ton initiative
Je n'avais personnellement pas osé le faire car je suis un grand timide.
un beau test comme celui-ci, c'est normal qu'il soit afficher sur le maximum de site web.
je pense aussi le mettre sur le forum cinemamaisonquebec.
qu'en pense tu rickavmaniac
EDIT: c'est fait
EDIT: c'est fait
- OlivierQC
Bonne initiative
Cela montre aussi à Zidoo l'intéret des passionnés francophones d'HCFR... et également pour le suivi et l'amélioration de leur produit (comme la récente upgrade du Poster Wall)
- DTSman
- Contributeur HCFR 2022
Oui bonne idéeolivierQC a écrit:un beau test comme celui-ci, c'est normal qu'il soit afficher sur le maximum de site web.
EDIT: c'est fait
- rickavmaniac
- Inscription Forum: 28 Déc 2012 20:49
DTSman a écrit:Bonne initiative
oui je le fait en partie pour cela et on sait jamais peut etre auront il le gout de vous envoyez un sample du zidoo X le moment venue pour test sur le site homecinema-fr
A bientot
- OlivierQC
rickavmaniac a écrit:Oui bonne idéeolivierQC a écrit:un beau test comme celui-ci, c'est normal qu'il soit afficher sur le maximum de site web.
EDIT: c'est fait
c'est fait Rick
et je vois que le membre vampat a commandé le Zappiti Pro 4K HDR Audiocom
https://cinemamaisonquebec.proboards.co ... do-uhd2000
- OlivierQC
Creation d'un fil de discussion sur le forum Zidoo sur le comparatif : Zidoo UHD2000 vs Zappiti Pro 4K HDR Version ''Authentic Cinema''
A bientot
A bientot
- OlivierQC
J'y pense en allumant ma Zidoo mais une fonctionnalité qui serait topissime dans HT serait de pouvoir afficher l'interface au format 2.35. ça, ça serait top
- DTSman
mais il y aurait des bande noir en haut et en bas, ou tu parle d'une option activable pour les videoprojecteur
- OlivierQC
Effectivement avoir des bandes noires en haut et en bas et faire rentrer l'interface entre ces deux bandes.
Le but étant que l'image ne soit pas croppée quand on utilise une toile 2.35.
Exemple sur la photo ci-dessous quand je zoom en 2.35 je perds les infos du haut et bas de l'image.
- DTSman
- OlivierQC
Ben voilà
Il suffit d'installer l' APK Photoshop
- DTSman
