Pour XE/XS/mini
Production 071713- Fix for A bug only in previous release (071613) caused incorrect video colors after exiting test patterns.
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 12 invités
Production 073113- Cleaned up the output trigger options settings and a couple of small bugs associated with them and added an output trigger option for rs232 only.
Adhara a écrit:Alex, Jacko, vous n'êtes plus membre du staff ?
Aurais je loupé un événement ? Possible car pas mal absent ces 3 derniers mois.
Production 081913- Small improvement in accuracy for extrapolating 3D color gamut from video min/max to digital min/max. A couple other small rs232 additions/fixes.
Production 090313- Fixes problem that was in last several updates which prevents the config utility from downloading a configuration from the unit.
Production 091013- Fixes 480p and 576p reinterlacing and may clean up other video mode detection issues ( broken from 0618-0903. )
Production 092113- Fixes issue for some DVI displays not working in 041613-091013 firmware. Small improvement to the report generated by the rs232 input mode change command under Other: I/O Setup/RS-232 Setup.
Production 100113- Fixes issue causing slow or no detection of hdmi sources using negative polarity (fairly unusual). Several audio issues fixed.
Retourner vers Processeurs Vidéo
