Release: 2012
Height of about a width of about 46mm × 172mm × Depth 268.5mm (excluding protrusions)
The new controller is 6.2 inches, 16:9 button controller that combines what is familiar and the touch screen, slide the two pads is attached.
This rechargeable controller power button, HOME button, arrow pad, A / B / X / Y Buttons, L / R buttons, ZL / ZR is attached to the button. In addition, accelerometers, gyroscopes, vibration function, camera, microphone, speakers, sensor unit is equipped with a stylus.
Wii Remote (or Wii Remote +) can simultaneously connect up to 4. Classic Controller and Nunchuk, Classic Controller PRO, and Wii Balance Board, or any input device that corresponds to the Wii controller.
New hardware for high-density optical and 12cm, Wii can play for a 12cm self-loading optical disc (disc type will automatically draw) with a single drive.
1080p, 1080i, 720p, 480p, 480i compatible. HDMI, Component, D terminal, S-terminal, corresponding to each of the composite cable.
AV Multi-output and output from the HDMI output terminal supports 6CH PCM linear.
In addition to the internal flash memory, SD memory card or external USB can be extended by using the hard drive capacity.
Multicore-based IBM Power ®
4 USB 2.0 has a single pin.
The new hardware backwards compatible Wii games.
Continue reading on Examiner.com Nintendo Wii U: Nintendo shares official specs - National Video Game | Examiner.com
http://www.examiner.com/video-game-in-n ... z1OcANLsfh
