Test HCFR : Lyngdorf MP-60, processeur 16 canaux
LYNGDORF MP60 Spécificités et Caractéristiques officielles :
  • Decoding: Dolby Atmos®, Dolby Digital, EX & Plus, Dolby TrueHD, DTS:X PRO, DTS ES Discrete 6.1, DTS ES Matrix 6.1, DTS 96/24, DTS-HD High Res. Audio, DTS-HD Master Audio, AURO 3D®, 16 native channels
  • Post processing options: Dolby Surround, AURO-MATIC®, DTS Virtual:X, DTS Neural:X
  • Audio inputs: 8 x HDMI™ (≤192kHz/24bit), 1 x AES/EBU S/P-DIF input (≤192kHz/24bit), 3 x S/P-DIF coaxial inputs (≤192kHz/24bit), 4 x S/P-DIF optical inputs (≤96Hz/24bit), 1 x USB audio input (≤192kHz/32bit), 1 x microphone input (XLR) for RoomPerfect™
  • Audio outputs: 16 x XLR analog outputs (5.0 Vrms), 1 x SPDIF coax digital ZONE output (Fix 96kHz/24bit)
  • Audio specifications: Frequency response: ±0,5dB from 20 to 20,000 Hz, Total harmonic distortion: 0.005% max from 20 to 20,000 Hz
  • EQ: RoomPerfect™, Subwoofer level assistant, 32 x adjustable voicings holding ≤8 shelving, high/low pass or parametric filters with adjustable gain and Q
  • Media player: Internet radio (vTuner), Airplay, Spotify Connect, Roon Endpoint (awaiting certification), DLNA Support of FAT32 based media storage
  • Video inputs: 8 x HDMI™ (2.0b – HDCP 2.2), accepts 3D 30Hz, 4K 60Hz (18 Gbps), accepts HDR, Dolby Vision and HLG
  • Video outputs: 2 x HDMI™ (HDCP 2.2), 1 x HDBaseT™
  • Video scaling: Upscaling of all video to 4K ultra high definition, no downscaling of 4K video
  • Control interfaces: 1 x DB9 RS232 connector, 2 x IR sensor inputs, 1 x IR output (loop from one of the sensor inputs), 1 x trigger input, 4 x trigger outputs, 1 x RJ45 ethernet LAN connector, 2 x USB A connectors, 1 x SD card slot , (Backup – storage for system software and settings)
  • Accessories included: RoomPerfect™ microphone, Microphone stand, Microphone cable, RF remote control
  • Optional module: 16 channel DCI-compliant digital AES/EBU input for movie servers (≤192kHz/32bit) / DB25), 16 channel digital AES/EBU speaker output
    channels (Fix 97,565kHz/24bit / DB25), 16 channel AES67 digital AES/EBU speaker output channels (Fix 48kHz/24bit / RJ45)
  • Placement options: Rack mount and freestanding
  • Dimensions (H x W x D): 14.7 x 45.0 x 37.0 cm, 5.8 x 17.7 x 14.6 in
  • Weight: 9 kg / 19 lbs
RoomPerfect, video de présentation officielle :
Prix : 14400€
– lien vers le sujet HCFR dédié au processeur Lyngdorf MP-60 : https://www.homecinema-fr.com/forum/son-audio-preamplificateurs-decodeurs-homecinema/lyngdorf-mp-60-proc-16-canaux-atmos-dts-x-pro-auro-t30102197.html
Partager :
