Dirty Vincent a écrit:-"You can go anywhere. Seriously. Those mountains in the background, you can climb them.
In other words, it's ALL GEOMETRY.
Obviously, there are some building structures and such that will block your path, and overall, planets have an ultimate boundary (so it's basically a very large square sandbox) although it'll take you a long time to get from one end to the other.
The feeling of "discovery" is definitely here."
-"The lighting and atmosphere in this game is off the fucking hook. Every planet has its own look, and from what I've seen so far, there are a ton of planets. Not all will allow you to land (for instance, planets which are gas giants or nothing but oceans of sulfuric acid), but I've poked around 1 system and have already found 2 really big random worlds."
C'étais pas ce type de jeu inenvisageable sur 360 du fait de son support old gen "DVD inside" et de l'absence de disque dur ??
Comme le dit Ohm Ciné, quand les développeurs veulent bien se sortir les mains du slip on a droit à du grandiose même sur une 360 dont la puissance est déjà mise à terre par les dernières superproduction
