Je te l'ai réécrit à partir du mien (qui fonctionne)
S'il y a toujours une erreur lors de la mise à jour du pilote du moniteur, ça viendra sans doute de Vista64
Par contre, je ne peux pas le joindre ici (c'est nouveau !? )
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: BuXy87 et 118 invités
Radeon HD4xxx : activer le son par l'HDMI
- Christophe Elecson KLS
- Inscription Forum: 23 Sep 2000 2:00
pour le rawdata j'ai pour le Denon
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,11,EE,0B,00,01,01,01,01,00,11,01,03,80,50,2D,78,0A,0D,C9,A0,57,47,98,27,
......................... 12,48,4C,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1D,80,18,71,1C,16,20,58,2C,
......................... 25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,C4,8E,21,00,00,9E,00,00,00,FC,00,44,
......................... 45,4E,4F,4E,2D,41,56,41,4D,50,0A,20,00,00,00,FD,00,31,3D,0F,44,0F,00,0A,20,20,20,20,20,20,01,90,
......................... 02,03,24,71,50,85,14,04,13,02,03,11,12,10,1F,20,06,07,15,16,01,23,09,07,01,83,5F,00,00,66,03,0C,
......................... 00,12,00,00,01,1D,00,72,51,D0,1E,20,6E,28,55,00,C4,8E,21,00,00,1E,01,1D,00,BC,52,D0,1E,20,B8,28,
......................... 55,40,C4,8E,21,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,C4,8E,21,00,00,18,8C,0A,D0,90,20,40,
......................... 31,20,0C,40,55,00,C4,8E,21,00,00,18,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,FF
dans le fichier ca donne ca :
le toshiba en 0 et le Denon en 1 :
HKR,EDID_OVERRIDE,"0",0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x52,0x62,0x05,0x01,0x00,0x00,0x00,0x00,0x00,0x11,0x01,0x03,0x80,0x69,0x3B,0x78,0x0A,0x0D,0xC9,0xA0,0x57,0x47,0x98,0x27,0x12,0x48,0x4C,0x20,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0xD0,0x72,0x38,0x2D,0x40,0x10,0x2C,0x45,0x80,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x8C,0x0A,0xD0,0x90,0x20,0x40,0x31,0x20,0x0C,0x40,0x55,0x00,0xC4,0x8E,0x21,0x00,0x00,0x18,0x00,0x00,0x00,0xFC,0x00,0x54,0x4F,0x53,0x48,0x49,0x42,0x41,0x2D,0x54,0x56,0x0A,0x20,0x20,0x00,0x00,0x00,0xFD,0x00,0x17,0x3D,0x0F,0x44,0x0F,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0x3B,0x02,0x03,0x2C,0x76,0x52,0x9F,0x14,0x13,0x12,0x16,0x11,0x15,0x10,0x05,0x04,0x03,0x07,0x02,0x06,0x01,0x20,0x21,0x22,0x23,0x09,0x07,0x07,0x6C,0x03,0x0C,0x00,0x20,0x00,0x38,0x2D,0xC0,0x29,0x29,0x33,0x33,0xE3,0x05,0x03,0x01,0x01,0x1D,0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25,0x80,0xC4,0x8E,0x21,0x00,0x00,0x9E,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x40,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0xC4,0x8E,0x21,0x00,0x00,0x9E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xEB
HKR,EDID_OVERRIDE,"1",0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x11,0xEE,0x0B,0x00,0x01,0x01,0x01,0x01,0x00,0x11,0x01,0x03,0x80,0x69,0x3B,0x78,0x0A,0x0D,0xC9,0xA0,0x57,0x47,0x98,0x27,0x12,0x48,0x4C,0x20,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0xD0,0x72,0x38,0x2D,0x40,0x10,0x2C,0x45,0x80,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x8C,0x0A,0xD0,0x90,0x20,0x40,0x31,0x20,0x0C,0x40,0x55,0x00,0xC4,0x8E,0x21,0x00,0x00,0x18,0x00,0x00,0x00,0xFC,0x00,0x44,0x45,0x4E,0x4F,0x4E,0x2D,0x41,0x56,0x41,0x4D,0x50,0x0A,0x20,0x00,0x00,0x00,0xFD,0x00,0x17,0x3D,0x0F,0x44,0x0F,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0xD2,0x02,0x03,0x51,0x74,0x5E,0x9F,0x14,0x13,0x12,0x16,0x11,0x15,0x10,0x05,0x04,0x03,0x07,0x02,0x06,0x01,0x20,0x21,0x22,0x0E,0x23,0x0F,0x24,0x1D,0x25,0x1E,0x26,0x0A,0x0B,0x19,0x1A,0x38,0x0F,0x7F,0x07,0x3D,0x1E,0xC0,0x15,0x07,0x50,0x5F,0x7E,0x01,0x57,0x06,0x00,0x65,0x7E,0x00,0x67,0x1E,0x00,0x4D,0x02,0x00,0x83,0x5F,0x00,0x00,0xE3,0x05,0x03,0x01,0x6C,0x03,0x0C,0x00,0x12,0x00,0xB8,0x2D,0xC0,0x29,0x29,0x33,0x33,0x01,0x1D,0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25,0x80,0xC4,0x8E,0x21,0x00,0x00,0x9E,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x40,0xC4,0x8E,0x21,0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xA1
- ipsos2048
- Inscription Forum: 04 Oct 2002 14:16
ipsos2048 a écrit:a quel endroit il doit y avoir inscrit HDMI pour le Denon ?
Je reviens sur ce message, pas sûr que tout soit clair pour tout le monde.
HDMI doit figurer dans le Centre de Contrôle Catalyst (ccc) dans la liste de droite, au niveau des propriètés du moniteur
pour le son marche lorsque je branche la CG sur le LCD Toshiba !
Donc pas de problèmes au niveau écran, c'est bien le Denon qui bloque
par contre je viens de verifier à nouveau : je peux activer le son via HDMI dans les options 'son', alors qu'avant il etait marqué comme déconnecté !
Ca, ça veut dire que le driver est bien installé, c'est exactement ce qu'il faut obtenir!
probleme l'ampli ne voie toujours pas de signal audio !!! les barres vertes sont en activité !!!! c'est bon signe !
Si ampli branché et entrée pc active sur l'ampli, tu as bien l'Ati HDMI audio actif dans les options "son", ce n'est pas le pc qui fonctionne mal, c'est l'ampli! As-tu bien activé la lecture du son par la hdmi sur ton entrée pc?
en passtrougth de l'ampli vers le LCD -> pas de son non plus
ca marche que quand c'est branché en direct !!
Je ne sais pas si ton ampli supporte le passtrough mais vois de son côté, il y a un truc à son niveau ...
jai aseiller la manip sous vista64 , toujours dtv dvi dans le ccc , doit seulment fonctionner sous vista32
- fooko
- Inscription Forum: 10 Déc 2008 19:25
Bonjour.
Existe-t-il une astuce similaire pour windows xp pro ?
- alex_t
- Membre HCFR Contributeur
- Inscription Forum: 29 Oct 2005 23:04
Non, c'est même pour cette raison que j'ai installé Vista sur mon pchc, jusque là sous XP ...
Karu Kéra a écrit:Non, c'est même pour cette raison que j'ai installé Vista sur mon pchc, jusque là sous XP ...
Ok, merci pour l'info.
Je suis sous XP et dans le CCC je vois en général DVI et parfois HDMI alors que mon équipement est bien HDMI. C'est donc bien un pb lié à l'échange EDID entre l'équipement et la carte graphique ATI. Je vais voir un peu sur le net si je trouve quelques info ...
- alex_t
Nous sommes un paquet à avoir ce problème, reconnu par AMD ATI mais toujours pas résolu, même avec les derniers drivers ...
Ceci dit, ce n'est pas le seul, il y a aussi la gestion des adaptateurs dvi/hdmi qui n'est pas claire.
Bref, ça ne semble pas encore au point, la gestion du son par la carte vidéo ...
Personnellement, je tiens une solution qui fonctionne en l'état et je ne touche plus à rien
Karu Kéra a écrit:Nous sommes un paquet à avoir ce problème, reconnu par AMD ATI mais toujours pas résolu, même avec les derniers drivers ...
Tu as bien raison. Quand ça fonctionne il ne faut rien changer.
Me concernant j'ai une alternative au problème vu que je n'utilise que l'audio SD classique ( DD 640 kb/s et DTS 1.5 Mb/s ), je passe donc le son par le SPDIF. Tout comme toi je ne vais donc rien changer à ma conf actuelle surtout qu'elle est stable.
Espérons que ATI nous ponde un correctif efficace d'ici quelques semaines.
- alex_t
Sympa l'astuce c'est bête que ma CG 8800 GTS ne gère pas le son via l'hdmi...(DVI vers HDMI pour le cable)
- mister_sam
- Inscription Forum: 23 Nov 2008 10:44
Fonctionne pas sous vista 64 du moins chez moi... de toute facon ATI devrait se bouger le c.. pour regler le probleme car c'est pas normal d'avoir a bidouiller.
- misterz83
- Inscription Forum: 24 Avr 2004 19:05
Merci !!
2 jours que je bataillais pour avoir le son sur une télé philips avec une mobility radeon 3400. Voilà qui est fait !
Encore merci
Encore merci
- franckyg
- Inscription Forum: 21 Déc 2008 12:27
Une journée à essayer, une journée de perdu....
Ati 3850 avec sortie dvi+adap ATi hdmi relié a un DENON 3808 sur vista64 !
J'ai mis ca
8-12_vista64_dd_ccc_wdm_enu_72276 derniers drivers ATI
Vista_R212 drivers vista Realteck
HDMI_R209 Hmi realteck
ATI Radeon HDMI @ ATI Radeon HD 38xx - High Definition Audio Controller PCI
Dans gestionnaire de son, j'ai une icône de tv avec indiqué:
Périphérique de sortie numérique HDMI
2 - Périphérique Hight définition Audio
Traitement en cours et par défaut
Les barres sont tjs grises lors de la lecture d'une source sonore, pas d'activité, pas bon signe ça !!!
Si je branche sur la tv, j'ai le son en 2.0 via la prise hdmi (super trop bien, c'est l'éclate totale ...)
Si je branche sur mon ampli, j'ai pas de son du tout, tout essayer.
Le contenu de mon fichier Override:
1 ligne: Samusung LE40M86BDX
2 ligne: Denon AVR-3808
Rien n'y fait, ça me soule grave...
Une idée du problème ?
J'ai mis ca
- Code: Tout sélectionner
[MS_EDID_OVERRIDE-1_AddReg]
HKR,EDID_OVERRIDE,"0",0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x4C,0x2D,0x9F,0x02,0x00,0x00,0x00,0x00,0x2D,0x10,0x01,0x03,0x80,0x10,0x09,0x78,0x0A,0xAE,0xA5,0xA6,0x54,0x4C,0x99,0x26,0x14,0x50,0x54,0xA1,0x08,0x00,0x81,0x80,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFC,0x00,0x53,0x41,0x4D,0x53,0x55,0x4E,0x47,0x0A,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFD,0x00,0x31,0x47,0x0F,0x46,0x17,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0x9B,0x02,0x03,0x27,0xF1,0x4B,0x90,0x1F,0x04,0x13,0x05,0x14,0x03,0x12,0x20,0x21,0x22,0x23,0x09,0x07,0x07,0x83,0x01,0x00,0x00,0xE2,0x00,0x0F,0xE3,0x05,0x03,0x01,0x67,0x03,0x0C,0x00,0x20,0x00,0xB8,0x2D,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x40,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x01,0x1D,0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25,0x80,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0xA0,0x5A,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xDC
HKR,EDID_OVERRIDE,"1",0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x11,0xEE,0x0C,0x00,0x01,0x01,0x01,0x01,0x00,0x11,0x01,0x03,0x80,0x10,0x09,0x78,0x0A,0xAE,0xA5,0xA6,0x54,0x4C,0x99,0x26,0x14,0x50,0x54,0x20,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x3A,0x80,0x18,0x71,0x38,0x2D,0x40,0x58,0x2C,0x45,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x01,0x1D,0x00,0x72,0x51,0xD0,0x1E,0x20,0x6E,0x28,0x55,0x00,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,0xFC,0x00,0x44,0x45,0x4E,0x4F,0x4E,0x2D,0x41,0x56,0x41,0x4D,0x50,0x0A,0x20,0x00,0x00,0x00,0xFD,0x00,0x31,0x3D,0x0F,0x44,0x17,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0xEE,0x02,0x03,0x3D,0x71,0x4F,0x90,0x1F,0x04,0x13,0x05,0x14,0x03,0x12,0x20,0x21,0x22,0x0F,0x24,0x1E,0x26,0x38,0x0F,0x7F,0x07,0x3D,0x1E,0xC0,0x15,0x07,0x50,0x5F,0x7E,0x01,0x57,0x06,0x00,0x65,0x7E,0x00,0x67,0x1E,0x00,0x4D,0x02,0x00,0x83,0x5F,0x00,0x00,0xE3,0x05,0x03,0x01,0x67,0x03,0x0C,0x00,0x11,0x00,0xB8,0x2D,0x01,0x1D,0x00,0xBC,0x52,0xD0,0x1E,0x20,0xB8,0x28,0x55,0x40,0xA0,0x5A,0x00,0x00,0x00,0x1E,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x01,0x1D,0x80,0xD0,0x72,0x1C,0x16,0x20,0x10,0x2C,0x25,0x80,0xA0,0x5A,0x00,0x00,0x00,0x9E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x84
- zuckbin
- Inscription Forum: 20 Avr 2008 1:03
J'ai remplacer ma 3850 par une 4850 et vous savez quoi, ca fonctionne toujours pas !
Du coup j'ai acheter une Terratec Aureon 5.1 et la ca fonctionne impec, mais c pas pareil
Super LoL
Y'a t'il une personne sur ce forum qui as reussi a passer ce son vers un Denon 3808 ?
Super LoL
- zuckbin
idem, si quelqu'un a reussi sur un z7
Salon: Jvc NZ7, Xtrem 1.1gen2, Lg 77g3, chambre samy 65s95b, Lg 55cs chambre enfant/ source: pana ub9000 +pchc+chinoppo+z1000pro/ 3 Arendal monitor 1723S, 4 Divatech diva18 sur et back, 6 Svs prime elevation atmos/ Denon Avc-a1h/ 2sub arendal 1723 1S
- david555
- Superviseur Forum Univers TV & Contributeur HCFR
- Inscription Forum: 02 Oct 2005 18:13
