ça y est, enfin, "il" est la et je pense qu'il va faire mal a la concurrence, qui "il" ? je parle bien entendu du nouvel ampli a/v de chez cambridge audio, le 551R...
http://www.cambridgeaudio.com/assets/do ... remote.jpg
http://www.cambridgeaudio.com/assets/do ... k-rear.jpg
551R 7.1 HDMI AV Receiver
Audio:
Puissance de sortie:
All Channels : 110 watts rms per channel, 6 ohms (two channels driven)
All Channels : 90 watts rms per channel, 8 ohms (two channels driven)
All Channels : 60 watts rms per channel, 8 ohms (all 7 channels driven)
Distorsio harmonique totale: <0.006% @1kHz
Diaphonie: <-60dB @ 1kHz
Réponse en fréquence: 10Hz - 20kHz -1dB
Rapport de signal-bruit: >90dB 'A' weighted
Audio input impedance/sensitivity 47kOhms / 175mV or greater
Impedance d’entrée digitale: 75 ohms (Coaxial/S/P DIF)
Correcteur de tonalité: Bass: +/-10dB @ 100Hz Treble: +/-10dB @ 10kHz
Tuner: FM mode: 87.5-108MHz, 75 ohm coaxial aerial, AM mode: 522-1629kHz, 300 ohm loop aerial
Video:
Video levels/impedance - Composite (CVBS): 1Vp-p / 75 ohm
- S-Video (S-VHS): Y 1Vp-p / 75 ohm
C 0.286 Vp-p / 75 ohm
Component: Y 1Vp-p / 75 ohm
Cb/Cr 0.75Vp-p / 75 ohm
Pb/Pr 0.75Vp-p / 75 ohm
HDMI HDMI 1.4
EIA/CEA - 861D
HDCP 1.1
All audio modes supported except reception of native Direct Stream Digital (DSD).
ARC and 3D-TV/deep colour pass through supported.
CEC and HEC not supported.
General
Architecture Cirrus Logic CS43122 24 Bit 192kHz capable DAC for Front Left & Right
Cirrus Logic CS52526 24 Bit 192kHz capable CODEC for surround channels + 24 Bit 2 channel A/D conversion
Cirrus Logic CS497004 dual 32 bit DSP
Faroudja FLI2310 scaler
Entrées Audio: 6 Line Level Analogue
Tuner (FM/AM)
7.1 Analogue Input
4 Digital Co-axial, 4 Digital Optical
Entrées Video 2 Composite, 2 S-Video,
2 Component Video, 4 HDMI
Sorties Audio: 7 Amplified Speaker Outputs
7.1 Preamp outputs
Video output 1 HDMI
Enregistrement Sorties Audio: 1 Line Level Analogue
1 Digital Co-Axial, 1 Digital Optical
Other Connections 1 1/4" / 6.35mm Headphone Outpu (32 To 600 ohms recommended)
1 IR Emitter In
1 RS232C
1 IEC type mains inlet
Consommation en mode Standbye: <1w
Consommation en veille: <70w
Consommation Max: 700w
Dimensions ( H x L x P ): 110 x 430 x 340mm (4.3 x 16.9 x 13.3’’)
Poids: 10kg (22lbs)
4 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Anthoflush 2, Birdy85, dragornard, jesus33, Jeyaan, lorand94, Luc021, pat00272, polyarnyy, sergeh, This Is It, yardbird et 396 invités
ampli a/v 7.1 slim CAMBRIDGE AUDIO 551R
- bretzellikid
- Inscription Forum: 07 Juin 2010 9:32
....en espérant que Cambridge ait résolu les petits bugs du 650R sur ce petit frère
- Scudabear
- Modérateur Œuvres & Multimédia
- Inscription Forum: 10 Mar 2009 21:11
salut,
il existe deja un post sur ce nouvel ampli,quand a faire mal a la concurrence
viewtopic.php?f=1024&t=29974795&hilit=cambridge+551
- agame
- Inscription Forum: 02 Mar 2004 22:00
Une plus petite alim. Pour le même prix. super...
LS12k • DTS X Pro 11.2.4 • AVC-X6800H
Patrick57s - Membre HCFR
- Inscription Forum: 27 Déc 2009 15:43
4 messages
