Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: bab1c, banjo65, Bidib, gallak, gamerone2008, Gaël, guillaumodore, gwendal55, jcre17, ludo3159, mirak, papounay, Patbon21500, Patoche21, patriceonkyo, Pilou57, rere130, rezoli, subsonic, sylvain-best, Tommyknockerz99, tony51, Wend, Yvounet et 227 invités
Himedia Q5/Q10 PRO (4K60/HDR/3D ISO/Android 7.0)
Le fw 1.0.8 apporte quelles améliorations ?
Vidéoprojecteur SONY 4K XW5000ES; Zidoo Z9X; PCHC Config Kaz9; Ampli AV Marantz sr6015; sonde EyeOne Display3 pro, Light Illusion; ColorHCFR.
- phil30
- Inscription Forum: 11 Sep 2004 11:28
phil30 a écrit:Le fw 1.0.8 apporte quelles améliorations ?
Je n'ai pas vu d'info sur le site officiel, il faut deviner ...
- tetar
- Inscription Forum: 14 Aoû 2005 10:14
selon une source du forum Russe 4pda
"Firmware Changelog 1.0.8:
1.Fasten the loading of the Blue-ray Player movie
2.HDR-source video playback type optimized, flick the conditions of some Certain video sources the fixed
3.Playback the HDR-source in the mode auto and IT WAS not issue the fixed function
4. Media player type optimized the Local, Including the default font sized and some modified Certain subtitles the which the display Unable to issue the fixed
5.Unable to Attain the F1, the F2, the F3, and the F4 buttons bmp issue the fixed
6.Media scan That CAN not the read the files is the Audio & the Video of a USB storage device issue fixed
7. Setting malfunction under some certain conditions issue fixed
8. SAMBA, NFS support shortcut name change function
9. The Media Center Optimized, Homepage and the ensure better and smoother the Operations
10.System type optimized to the run more smooth and reliable "
il devrait etre dispo aujourd'hui sur le forum Futeko.
A bientot
A bientot
- OlivierQC
- Contributeur HCFR 2018
- Inscription Forum: 23 Avr 2003 14:01
lien de download pour le FW 1.0.8 :
Q5 PRO FIRMWARE. 1.0.8-FUTEKO-EN. HMD-1.0.8 2016-10-17.104357
This is the official HiMedia European/International 1.0.8 firmware repackaged by us to include installation instructions and changelog.
Internal build number: HMD-1.0.8 2016-10-17.104357
IMPORTANT! THIS FIRMWARE IS FOR INTERNATIONAL/EUROPEAN Q5 PRO ONLY.
DO NOT TRY AND FLASH IT TO CHINESE HARDWARE Q5 PRO OR OR PREVIOUS GENERATION Q5 4K3D.
Installation Instructions:
1. Extract update.zip from the download archive to the root of a USB pen drive. (the USB pen drive should contain a single file called 'update.zip').
2. Insert the USB pen drive into any USB port of Q5 Pro.
3. With Q5 Pro turned off, use a paper clip or pen to press and hold the the pinhole RESTORE button on the back of Q5 Pro (next to the power port).
4. While keeping the RESTORE button pressed, turn on the Q5 Pro.
5. Q5 Pro will show an Android droid logo and proceed to upgrade the firmware.
6. When you see the Android droid logo, you can release the restore button.
7. The box will auto-reboot when finished.
8. First boot will take 3-5 minutes. Wait for the Android home screen to be displayed.
Changelog (preliminary - more details to come):
1. Fasten the loading of the Blue-ray Player movie
2. HDR-source video playback type optimized, flick the conditions of some Certain video sources the fixed
3. Playback the HDR-source in the mode auto and IT WAS not issue the fixed function
5. Unable to Attain the F1, the F2, the F3, and the F4 buttons bmp issue the fixed
6. Media scan That CAN not the read the files is the Audio & the Video of a USB storage device issue fixed
10. System type optimized to the run more smooth and reliable.
Download link:
http://www.mediafire.com/file/xd0b02pyf ... 104357.zip
Q10 PRO FIRMWARE. 1.0.8-FUTEKO-EN. HMD-1.0.8 2016-10-12.193826
Internal build number: HMD-1.0.8 2016-10-12.193826
IMPORTANT! THIS FIRMWARE IS FOR INTERNATIONAL/EUROPEAN Q10 PRO ONLY.
DO NOT TRY AND FLASH IT TO CHINESE HARDWARE Q10 PRO OR OR PREVIOUS GENERATION Q10 4K3D.
2. Insert the USB pen drive into any USB port of Q10 Pro.
3. With Q10 Pro turned off, use a paper clip or pen to press and hold the the pinhole UPGRADE button on the back of Q10 Pro (next to the power port).
4. While keeping the UPGRADE button pressed, turn on the Q10 Pro.
5. Q10 Pro will show an Android droid logo and proceed to upgrade the firmware.
Download link:
http://www.mediafire.com/file/mt7ljom7i ... 193826.zip
Download link:
Download link:
- OlivierQC
Merci olivierQC, j'ai posé la question entre-temps sur le forum futeko ^^
- tetar
quelqu'un pourrait me dire si dans les infos devices il est bien en 1.0.8 parce que moi je suis toujours en 1.0.7 après la mise à jours même en mode hard upgrade (bouton reset).
- droiter
- Inscription Forum: 19 Aoû 2016 19:27
oui en 1.0.8
juste a tout hasard tu a bien decompressé le fichier pour avoir le update.zip.
- OlivierQC
olivierQC a écrit:selon une source du forum Russe 4pda
A bientot
A priori, toujours rien pour que l'expressX engine 2 soit fonctionnel.... Pourtant OlivierQC leurs avait signalé, C'est bien Dommage.
Je vais recevoir le Q10 Pro aujourd'hui.
- phil30
Beaucoup de déception avec ce nouveau firmware à priori.
Pas grand chose de corrigé d'après les personnes sur le forum Futeko.
- Vogador
- Inscription Forum: 24 Juin 2003 9:34
Non comme tu dis Vogador, c'est plus un FW pour faire patienter en attendant celui de fin novembre avec Android Nougat...normalement,
On espere qu'avec le nouveau SDK de nougat il y aura des bugs de corrigés et pas trop de nouveau bugs.
- OlivierQC
Bonjour a tous,
Bon ca a commencé a chauffé sur le forum Kodi quand hdmkv a posté mon info sur le framerate iso 3D qui ne serait pas corriger avec le FW1.08, ensuite ca a chauffé un peu plus (beaucoup) avec les ecrit de wrxtasy (moderateur du forum Kodi) quand ils ont commencé a mettre en doute la compatibilité de la serie Q pro avec le 192Khz 24bit LPCM multi channel (5.1/7.1) FLAC alors que c'est indique sur le site futeko, l'administrateur du site futeko vient de s'expliquer sur le forum et la il vient de donner une infos (a verifier), je vous copie son message :
And..
I'm not going to get sucked into arguing on this forum so you won't get any more posts here from me for a while.
If you want to talk about the HiMedia products please use our forum or email us.
The new Q5/Q10 Pro Android 7 firmware is scheduled for November 7th.
a premiere vu le nouveau FW avec android Nougat est prevue pour le 7 novembre ( je sais pas si c'est la version pour le public ou une beta pour les testeurs) on va voir.
bon je retourne sur Kodi, c'est pas mal gratiné
http://forum.kodi.tv/showthread.php?tid=265888&page=80
a bientot
And..
a bientot
- OlivierQC
Bonjour a tous,
J'ai ecris a himedia pour en savoir plus sur ce FW nougat debut novembre, je vous tiens au courant si j'ai des nouvelles.
- OlivierQC
Effectivement ça chauffe pas mal. Maintenant faut prendre son mal en patience.
Je pense que Himedia se concentre sur le FW Nougat et que ce firmware 1.0.8 est juste un
Amuse-gueule. Mais vu le peu d'innovation avec celui-ci ils auraient pu largement s'en passer.
- Vogador
olivierQC a écrit:Bonjour a tous,
And..
a bientot
haha j"ai suivi l'affaire aussi . Ca chauffe oui . A voir sur la suite . Je pense qu'en effet Himedia se concentre pour début novembre avec nougat sans trop balancer de bug . Ils sont attendu au tournant de toute facon visiblement sur futeko et forum kodi
- MrT
- Inscription Forum: 14 Juin 2009 20:09
Bon, je me doute que la réponse est "non", mais allons-y quand même!..
je dispose depuis peu d'une box android, elle a Google, je me dis que c'est trop bête de ne pas pouvoir charger une page web que j'ai fabriquée pour mon site, elle est dans un dossier qui contient les fichiers du diaporama qu'elle génère, ça pourrait être de l'audio ou des vidéos . Résultat de courses :
-ça marche nickel sur mon smartphone (2560x1280pix) avec Edge (ou sans doute autre)
MAJ
on devrait se tenir au courant ... ce truc devrait me permettre de faire tout ça, du MHL ça s'appelle :
http://paradisdiscount.com/microsoft-lu ... 50-xl.html
MAJ
- Mpeg
- Inscription Forum: 15 Avr 2005 13:47
