J'ai modifier mon playercorfactory pour que tous les fichiers a l’exception des iso.3d s'ouvrent avec mpc-be.
Les iso.3d s'ouvrent avec powerdvd.
J'aimerais de nouveau le modifier pour que les fichiers .iso ( pas iso.3d) s'ouvre avec mpc-be mais je n'y arrive pas.
Y a t'il une âme charitable qui pourrais me filer un coup de main
<?xml version="1.0" encoding="iso-8859-1"?>
<playercorefactory>
<players>
<player name="MPC-KODI" type="ExternalPlayer" audio="false" video="true">
<filename>C:\MPC-KODI\MPC-KODI.exe</filename>
<args>/fullscreen /close "{1}"</args>
<hidexbmc>true</hidexbmc>
<hideconsole>true</hideconsole>
<warpcursor>none</warpcursor>
</player>
<player name="POWERDVD" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\CyberLink\PowerDVD16\PowerDVD.exe</filename>
<args>/fullscreen_mode_on "{1}"</args>
</player>
</players>
<rules action="prepend">
<rule filetypes="mkv|avi|bdmv|mp4|wmv|mpg|ifo|ts|m2ts" player="MPC-KODI" />
<rule filetypes="mp3|flac|wav|wma" player="PAPlayer" />
<rule name="htsp/pvr" protocols="htsp|pvr" filetypes="pvr" player="DVDPlayer" />
<rule name="https" protocols="https" player="DVDPlayer" />
</rules>
<rules name="system rules">
<rule filetypes="iso" filename="*3D.ISO" player="POWERDVD"/>
<!-- DVDs -->
<rule name="DVD" DVD="true" player="MPC-KODI" />
<rule name="dvdfile" dvdfile="true" player="MPC-KODI" />
<!-- dvdplayer can play standard rtsp streams -->
<rule name="rtsp" protocols="rtsp" filetypes="!(rm|ra)" player="PAPlayer" />
<!-- Internet streams -->
<rule name="streams" internetstream="true"/>
<rule name="flv/aacp/sdp" mimetypes="video/x-flv|video-flv|audio/aacp|application/sdp" player="DVDPlayer" />
<rule name="mp2" mimetypes="application/octet-stream" filetypes="mp2" player="PAPlayer" />
<!-- Others -->
<rule name="rtv" protocols="rtv" player="DVDPlayer" />
<rule name="hdhomerun/myth/rtmp/mms/udp" protocols="hdhomerun|myth|cmyth|rtmp|mms|mmsh|udp" player="DVDPlayer" />
<rule name="lastfm/shout" protocols="lastfm|shout" player="PAPlayer" />
</rules>
</playercorefactory>
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: BangoO, imotep27000, stef44 et 123 invités
[Synthèse] Kodi (alias XBMC, SMPC, ZDMC...)
- Thebadboy
- Inscription Forum: 04 Déc 2011 8:59
weyb a écrit:bjr,Dialhot a écrit:Juste pour info, je n'ai que des MP3 et j'ajoute les vignettes directement à CHAQUE morceau avec tagscanner. Kodi les lit tres bien.
Il me semble que ca fonctionne aussi avec des flac...
oui je confirme tagscanner (très bon outil, très complet) marche aussi avec les flac.fanvw a écrit:Je pensais qu'il existait un addon ... qui soit capable de balayer la totalité des mp3/flac et de leur associer la bonne pochette...
un outil qui fasse tout le boulot tout seul sans se tromper sur les homonymies et tout le toutim ?
aucun n'en est capable, c'est le souhait de tout le monde mais soit les outils bossent tout seul et il y a forcément des erreurs, soit faut faire le boulot à la main, pour les musiques comme pour les videos...
il n'y a pas de produit miracle...
cordt
Polopretress a écrit:Quand tu as posé la question, je voulais répondre exactement la meme chose que Dialhot.
A savoir, test quand meme un dossier par album et le <span class="skimlinks-unlinked">cover.jpg</span> avec ce dossier.
Je vais essayé mais je souhaite vraiment mettre la bonne pochette en fonction de chaque titre et non album
téachix a écrit:Bien le bonjour, je sais pas si le sujet a déjà été abordé concernant les intro de film type "Jean Mineur Mediavision" alors je pose la question
Est-il possible de faire passer cette intro "automatiquement" avant chaque film ?
Ça peut paraître idiot, mais ce que j'adore quand je vais au ciné, c'est de voir ce petit mineur avant la séance.
Je pense que ce lien va t'intéressé, pas encore eu le temps de regarder, mais on peut tout faire . . .
Si tu as réussi n'hésite pas à partager
multimedia-logiciels-media-player-pchc/lanceur-de-videos-zm-media-launcher-v-2-0-0-t30087781.html
Caribbean's Space 62
weyb a écrit:Dialhot a écrit:Non tu n'es pas le seul, la dernière creator update l'a tueR
Je suis passé à filebot du coup.
bsr,
j'ai 8j de retard (mais sur d'autres sujets, c'est pire...), mais je tenais à remettre ici un autre post de Dialhot :Dialhot a écrit:...
Les versions précédentes sont encore en DL ici: https://filehippo.com/download_filebot/
Après, si qq pouvait me dire comment faire pour que filebot renomme aussi le dossier où se trouve le fichier...
cordt
En fait c'est tout bête: si tu mets un "/" dans le format de sortie, tout ce qui est avant est considéré comme un nom de folder.
Par exemple:
- Code: Tout sélectionner
{n}/{'Season '+s}/{s00e00} - {t}
générera un renomage du style:
Titre série/Season xx/sxxeyy - Titre épisode
Ca crée les répertoires à la volée et déplace les fichiers dedans.
Note: j'ai juste eu à lire l'aide fournie sur l'écran "Edit format"
Edit: par contre je viens de me rendre compte d'un truc bien ch..., filebot change la date des fichiers en le renommant
Edit2: pour régler le problème il faut lancer "filebot.platform.launcher.exe" et pas "filebot.launcher.exe". Le second ne semble pas tenir compte de l'OS et n'utilise donc pas l'API standard de windows pour faire les copies malgré le paramètre dans le fichier l4j.ini.
J'en ai profité pour rajouter "-Dapplication.update=skip" dans ledit fichier ini pour arrêter d'être prévenu de la nouvelle version.
(désolé de parler chinois; bienvenu dans le joyeux monde de java)
Thebadboy a écrit:Bonjour,
<playercorefactory>
<players>
</player>
</player>
</players>
</rules>
<!-- DVDs -->
<!-- Others -->
</rules>
personne pour tenter de m'aider
- Thebadboy
Si tu appelles 3D.iso tes fichier 3D pour appeler PowerDVD, comment veux tu que les .iso puissent appeler MPC Kodi puisque l'extension est la meme. Cela doit générer un conflit dans le PlayerCorefactory....
As tu essayé de renommer tes fichiers 2D Iso en "....2D.iso" et en rajoutant la ligne
<rule filetypes="iso" filename="*2D.ISO" player="MPC-KODI"/>
Tu as ajouté une exception pour les noms "3D.iso" sur les extensions ".iso" et pour lecteur "POWERDVD"
Le nom il faut je crois utiliser ".*xxxx.*" mais je ne me souvient plus du nommage...
- Donc de voir à bien renommer le nom 3D dans le filename !!!
Ajouter l'extension "iso" au MPC-KODI (MPC-BE).
Puis l'exception sur les "iso" comprenant les noms ".*3D.*" ayant pour lecteur "POWERDVD".
<rule filetypes="mkv|avi|bdmv|mp4|wmv|mpg|ifo|ts|m2ts|iso" player="MPC-KODI" />
<rule filetypes="iso" filename=".*3D.*" player="POWERDVD" />
</rules>
3D.iso c'est le nom utilisé, ou le nom + l’extension... ?
Un nom c'est toujours mieux comme cela 3D-ISO etc.
édit: désolé Polopretress pas vu ton com, j'ai laissé en attente le temps de manger
</rules>
- Poilut66
- Contributeur HCFR 2020
- Inscription Forum: 27 Déc 2015 16:35
aucun souci. De toute facon, j'ai testé ma proposition et cela ne fonctionne pas.
Il faut mettre effectivement ce contenu dans la section <rules action="prepend">. Pour la condition, je ne sais pas.
effectivement...
édit: A la relecture je en suis plus trop sur de ce que tu veux dire, au pire il teste les deux.
Comme celle du haut:
ou avec la condition dans "<rules name="system rules">":
<playercorefactory>
<players>
</player>
</player>
</players>
<rule filetypes="iso" filename=".*3D.*" player="PowerDVD" />
</rules>
<!-- DVDs -->
<!-- Others -->
</rules>
<playercorefactory>
<players>
</player>
</player>
</players>
</rules>
<!-- DVDs -->
<!-- Others -->
</rules>
- Poilut66
Je n'ai pas testé les tiennes mais j'en ai une qui fonctionne aussi
En fait si on rajoute |iso, cela va toujours appeler MPC-KODI.
Le ".*.*" va permettre de lancer avec MPC-KODI tous les films donc le nom ne comporte pas "3D"
EDIT : Pour chez moi, tes 2 propositions ne fonctionnent pas. MPC-KODI est systématiquement lancé. C'est lié au |iso qui devient prioritaire sur MPC-KODI
<rule filetypes="iso" filename=".*.*" player="MPC-KODI" />
</rules>
C'est pour cela qu'il faut peut-être l'ajouter à "system rules".
L'essentiel c'est que ça fonctionne, donc le nommage est bon.
édit: ok c'est le "iso" qui pose souci...
edit2: on a édité en même temps je pense
- Poilut66
Le principal , c'est d'avoir trouvé la solution
On attend ton retour Thebadboy pour savoir si c'est ok maintenant chez toi.
et je confirme que l'ordre est important :
Exemple qui ne marche pas (appel systématique a MPC-KODI)
Exemple qui marche :
On peut donc en déduire que celle ci marche aussi.
Et vu qu'elle est plus courte, c'est la meilleure
Et, bien sur, faut virer la partie <rule filetypes="iso" filename="*3D.ISO" player="POWERDVD"/> dans la section <rules name="system rules">
@Thebadboy
Y a un probleme a lire des iso 3D avec MPC-BE ?
</rules>
</rules>
</rules>
@Thebadboy
Dialhot a écrit:En fait c'est tout bête: si tu mets un "/" dans le format de sortie, tout ce qui est avant est considéré comme un nom de folder.
bsr,
alors je dis "BRAVO !!!"
j'avais bien vu ces options, mais j'y avais rien compris
j'y avais p-e pas mis toute mon attention à l'époque, certes... et avec vos explications, c'est gagné !
j'ai mis aussi le skip dans filebot.launcher.l4j.ini (car dans filebot.l4j.ini, ça n'a pas eu l'air d'être efficace...)
NOTA : comme je renomme juste après avoir encodé, le souci de changement de date ne me "concerne" pas trop - mais merci qd même pour l'info !!!
bien cordt !!!
- weyb
- Inscription Forum: 09 Jan 2012 19:16
merci a vous deux, çà fonctionne impeccable ,
pour mpc be + kaz en 3d je n'arrive pas a lire le film en 3d, il passe en 2d et je ne trouve pas comment faire.
si tu as une idée je suis preneur, cela me permettrais de virer power dvd.
- Thebadboy
OK. C'est déjà ca.
Je pense que c'est possible mais pas eut le temps de me pencher sur la lecture des 3D que ce soit en SBS ou en framepacking ou en iso full BR....
Un truc dans ma "todo list" mais pas prio pour l'instant !
Mais y a peut etre une histoire de licence derrière...mais en tout cas, y a de la conf a faire dans madVR et dans le driver Nvidia. Et un seul diffuseur doit etre connecté a la prise HDMI du PCHC car si tu as un monitor PC non compatible 3D, Nvidia ne te permettra certainement pas le choix de la conf 3D.
Un article qui peut etre intéressant :
https://www.avforums.com/threads/guide-playing-frame-packed-3d-with-madvr.2030649/
Thebadboy a écrit:merci a vous deux, çà fonctionne impeccable ,
Vas dans les options de Kodi à lecteur puis disque et à mode de lecture tu choisis "lire le film".
Cela peut résoudre ce genre de souci, suivant le lecteur et config...
- Poilut66
