Yes le BOSS et de retour
Content de ton retour OLIVIER
En espérant que cela s'arrange coté santé.
Sinon R.A.S LE BESTIO HEU la chti boîte marche bien par rapport à d'autre marque héhé.
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: albator91, AlexDarkness, alfachris, chris25, cohelfer, coucouse, Cyberdom, djmx, Hubu, jmiforum, kalifept, Kris Tof, Madmax, NoBiluS, Patbon21500, roosvelt, scramix, Stade81, tony51 et 163 invités
Egreat A5/A10 (Control4/HDR/ISO 3D/BD menu)
- roucasse (rie)
- Inscription Forum: 14 Oct 2005 17:39
salut roucasse (rie),
oui, le Egreat fonctionne super bien pour moi aussi.
nouveau FW dispo pour le A5, le A10 va suivre :
New A5BD_EN_Firmware_20170616_v1.2.1.5.rar (2017-06-16 v1.2.1.5)
DownloadLink:
http://data.egreatworld.com/A5BD_EN/fir ... .2.1.5.rar
Changelog
l: Aded Collection and Series classification
Posterwall: Added direct delete file funcion in the poster wall
Posterwall: Added film suit editing function
Posterwall: The poster wall and File Browser Integration
Posterwall: Support subfolders to join the library
Posterwall: There is no need to search repeatedly when adding network locations
Posterwall: Fix the problem of an invalid path
Posterwall: After fixing the upgrade, posters may appear without picture problems
Player: Exclusive support 4KUHD blu-ray full menu
Player: Added multichannel LPCM audiotrack RAW passthough
Player: Fixed the problem that online app could not play after playing HDR video
Player: Subtitles time offset deviation set to +-200 seconds
Player: Always display 3D options when playing
Player: Fixed the audio stream displayed as 0Kbps
Player: Fixed the color space will change the problem
Player: Fixed the LPCM audio track caton problems on full menu mode playback
UI: Volume adjustment level added to 100
UI: Added six background pictures
UI: Added homepage shortcut bar can be customized function
UI: Added the first screen is still for 30 seconds to automatically reduce brightness
UI: LED display indicates the new marquee screen saver
UI: Optimized screen saver(now completely shut down video output)
UI: Added TRANSMISSION function switch in the general menu
UI: Optimized "UHD" will be changed to "4K UHD" in the resolution menu
Settings: Added acceptable beta version update function
System: Update transimmison to version 2.92
System: Built-in applications now allowed to uninstall
System: Eliminate redundant built-in applications
System: Fixed some machines that do not enter standby problems after power on
System: Fixed will automatically switch off after the problem
System: Fixed the problem that the third-party app display some chinese
A bientot
DownloadLink:
Changelog
A bientot
- OlivierQC
- Contributeur HCFR 2018
- Inscription Forum: 23 Avr 2003 14:01
Merci. Pas de trace du flag visuel sur les fichiers déjà visionnés on dirait.
- Crrispy
- Inscription Forum: 24 Mai 2003 19:36
salut Crrispy,
je sais pas du tout,
Petit imprevue, le sujet sur le nouveau FW du A5 a ete retiré du forum, il sera dispo demain dans la matinée.
Par contre il est dispo (le FW) en OTA des a present
- OlivierQC
le lien est a present disponible sur leur site et je met aussi celui de E_CS :
mega.nz mirror:
https://mega.nz/#!AV9w2CwR!O41ByJ1vs2Tn ... vnkhCiTW_k
a bientot
mega.nz mirror:
a bientot
- OlivierQC
salut ,
petite question , j'ai regardé 20 pages , et par 2 fois , olivier dit
-> Demo UHD et UHD HDR passent sans problèmes en mettant les paramètres manuellement comme avec le zidoo ou le himedia.
heuuu quelqu'un pourrait m'expliquer cette histoire de mettre des paramètre en manuel ? j’espère que c'est pas ce que je pense , en gros faudrait aller dans des menus pour pourvoir lire en HDR ?? wtf
merci de m'éclairer
merci de m'éclairer
- piou
- Inscription Forum: 05 Sep 2006 20:15
Bizarre, ici même si je tente de forcer une mise à jour OTA il me dit que j'ai la dernière version alors que je suis en 1.2.1.0 .
- Crrispy
BONNE NOUVELLE
SCRAP EN FRANCAIS DEPUIS LE DERNIER FW (1.2.1.5)
- HD68
- Inscription Forum: 23 Jan 2009 21:28
Crrispy a écrit:Bizarre, ici même si je tente de forcer une mise à jour OTA il me dit que j'ai la dernière version alors que je suis en 1.2.1.0 .
Parfois les serveurs ont qq jours de retard sur la mise à disposition de la dernière version, d'où l'intérêt de passer par maj via clé usb.
- jpnn80
- Inscription Forum: 14 Déc 2006 18:44
piou a écrit:salut ,
merci de m'éclairer
les box sous android OS ne bascule pas automatiquement du 1080p au 2160p ou vice versa, il faut aller dans les parametres de resolution et le changer manuellement.
je dis ca car moi je laisse la resolution tout le temps en 1080p (ma videotheque est a 99% en 1080p) mon egreat pour que la tv fasse le upscaling que je trouve meilleur et quand je regarde des demo uhd je passe la resolution du boitier en 2160p.
desolé si je m'explique pas bien
- OlivierQC
HD68 a écrit:BONNE NOUVELLE
Bonne nouvelles, Merci HD68
- OlivierQC
olivierQC a écrit:piou a écrit:salut ,
merci de m'éclairer
j'ai parfaitement compris , merci olivier .
par contre malheureusement , j'ai compris que les sources en 4k hdr , il y avait un prob , ça me gonfle sérieux
http://en.egreatworld.com/comunity/inde ... blems.482/
le zappiti lui fait des coupures ou je ne sais quoi, il me manque des renseignements , et le prix on en parle même pas , faut pas se planter...
sérieux y a que la shield qui arrive a passer des 4k hdr sans aucun prob ???
- piou
Encore une fois à cause d'un encodage fait en chaussettes, en retirant les bandes noires. Le jour où les gens comprendront qu'elles ne consomment rien...
Dialhot a écrit:Encore une fois à cause d'un encodage fait en chaussettes, en retirant les bandes noires. Le jour où les gens comprendront qu'elles ne consomment rien...
25 000 messages , le 25 aout , 2**5
- piou
Bien vu
