Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 21 invités
Lecteurs et platines vidéo (lecteurs DVD, HD-DVD, Dvdscopes, Laserdiscs, etc.)
[Topic Unique] le BBK DV971H
Message » 23 Déc 2005 11:06
** BBK NEWS & FAQ ** Mise a jour : 07/12/06 **© Jean-Max
LAST NEWS
INTRO
LES BUNDLES
VPC
LES FIRMWARES
LES TELECOMMANDES
FAQ BBK
SETUP LECTEUR
DIVERS
NEWS (Historique)
_______________________________________________________________________________
** LAST NEWS **
28/11/06
    Dernier Firmware 0919_4 pour le BBK OPDV971H-E avec téléc Black-blueish usa style
    Info:
    http://www.livingcinema.nl/phpBB2/viewtopic.php?t=114
    Dwnld:
    http://www.livingcinema.nl/public/bbk/2 ... 0919_4.iso
    Modifs:
    all improvements from last firmware:
    1. Improved handling of "forced subtitle" for DVD discs
    2. Improved disc compatibility
    3. Improved audio/video synchronization (previously included in the F-0316 beta firmware)
    4. Eliminated Chroma Up-sampling Error (CUE) for component output
    5. Improved resume play function
    6. Improved DivX video playback functions
    7. Output resolution display
    8. Enhanced front panel dimmer control
    9. Skip function for digital music files
    It seems subtitle sync to frame is a little better.
    Problème:
    .. zoomindicator does not go away
22/09/06
    Petite relase de Fw de OppoDigital :
    MVer: 05.00.01.07 Batch: 11-0830, 11-0830B and 10-0821B
    Release Date: September 22, 2006
    Summary of Changes in This Release:
    * This release addresses a rare occurrence of no center audio channel output through the 5.1ch analog audio output. It also includes all new features and improvements from the 10-0720 major release version.
    * The above three batch numbers are equivalent firmware releases used at different stages of production.
    Fil sur Oppodigital:
    http://www.oppodigital.com/opdv971h_firmware_0830.html
    Download:
    http://www.oppodigital.com/Download/Fir ... 1-0830.iso
26/08/06
28/07/06
    Oppo Digital USA a sorti un Fw 0720
    (Telec Black blue-ish et Silver)
    (Cf section Firmwares)
    Info Oppo:
** INTRO **
Le fabriquant chinois BBK a sorti fin 2005 2 produits :
    BBK DV971-H pour l'europe
    Oppo OPDV971-H pour les US
Le BBK, à la différence de l'Oppo US, dispose:
    D'une télécommande différente (dans son look ses touches, son firmware et ses codes)
    D'une prise SCART supplémentaire sortant au choix, soit du RVBS soit de l'YUV
    D'un frmware adapté à sa télécommande et à sa sortie SCART (même si les moins récents des Fw. Oppo, sont OK)
    D'une prise d'alim au normes CEE
    D'un bundle différent (câbles DVI )
    ATTENTION :
    Depuis Mars 2006, les Oppo Cee (Ex BBK) sont désormais dénommés OPDV971-H-E et livrés par Living Cinema Hollande, avec la même télécommande Black Blue-ish que les Oppo livrés par Oppo Digital USA
** Les BUNDLES livrés avec le lecteur **
LC Hollande 30/04/06 (Merci à cricri49 et à gbaya)
    1 câble DVI/DVI de 1m50 environ
    1 câble Vidéo composite (rca)
    1 câble Audio stéréo analogique (rca)
    1 Télécommande modèle "black blue-ish" ou "black fat" selon les packages
    2 piles AAA
    1 manuel utilisateur Anglais/Hollandais
    nb1: Fiche d'alim. du lecteur : 2 pôles, norme Cee
    nb2: Alimentation 110/220 auto
    nb3: Firmware 0302 ou plus ancien (à upgrader) , selon les packages
Oppo Digital US (Merci à Jose Hidalgo )
    1 câble DVI/HDMI de 1m50 environ
    2 piles AAA
    nb1: Fiche d'alim. du lecteur : US (prévoir un simple adaptateur US/EU à
    1,50€ chez Bricomerlin)
    nb3: Firmware US OP971-F-0302
** Les BBK / Oppo en VPC **
France
Pas de VPC ni de revendeur officiel
Hollande : Living Cinema
http://www.livingcinema.nl/catalog/prod ... cts_id/168
UK : CRTprojectors
http://www.crtprojectors.co.uk/dvd_players.htm
Suede : BBK (Importateur central pour la Cee)
http://www.bbkes.se/
Allemagne : Pipro
http://pipro.de/oppo_opdv971h.htm
Finlande : Mareks
http://www.mareks.fi/?p=productsMore&iProduct=41
USA : Oppo Digital
USA : Extreme Phono
http://www.extremephono.com/Oppo_DV971.htm
USA : HKFlix
http://www.hkflix.com/hardware/xq/asp/p ... etails.htm
** Les FIRMWARES du BBK **
Les Firmwares OFFICIELS
Nb: Les télécommandes sont livrées avec le paramétrage "New RC"
La Manoeuvre de passage New RC -> Old RC (Changer la table de codage IR de la télécommande) est décrite plus bas, au chapitre "FAQ BBK"
Oppo Digital USA. http://www.oppodigital.com
_________________________________________________________________________________
Living Cinema Hollande. http://www.livingcinema.nl/
Forum des upgrades des Fw:
http://www.livingcinema.dnsalias.com/ph ... a225dbbc5c
AVERTISSEMENT : LC conseille fortement aux utilisateurs de BBK et de Oppo-E commandés chez eux, de n'utiliser que le Fw publiés par LC et ceci, pour éviter des problèmes
PIPRO Allemagne. http://pipro.de/oppo_opdv971h.htm
AVERTISSEMENT : Ces Fw sont, d'après LC, des copies issues des FW de LC et sont à réserver aux Oppo-E commandés chez Pipro
MAREKS Finlande www.mareks.fi/oppofirmware
Les Firmwares NON OFFICIELS
Certains ont hacké les firmwares officiels de BBK/OPPO et proposent leur version
Il va sans dire que cela est sous aucune garantie
    Les Russes
    http://bbk985s.narod.ru/oppo971.html
    http://www.bbk985s.com/
    Avertissement (Source : AVS)
    http://www.avsforum.com/avs-vb/showthre ... e=82&pp=30
    Extrait:
    [color=darkblue]Some russians made modded firmware for oppo 971h.
    I just found it at bbk985s.narod.ru
    Now I am upgrading my player.
    I hope it'll work!
    Firmware updates based on OP971-D-1022
    OPPO971 v.9
    They have no stance, though it does void your warrenty (however, this does not mean that they will not service your unit).
    Officially, none of these changes have ever been implimented in official beta firmware.
    The only real problem with using the European or hacked firmware is the risk of a bad installation.
    If the installation fails at any time, you will not beable to use your OPDV971H anymore until OPPO services it.
    Another problem is if the Russian model is using the standard BBK remote, or the one that shipped with the US model.
    Why I note this is that BBK uses an entirely different IR Code for their remotes.
    If the hacked firmware is using this remote code, you are still out of luck.
    One thing I had completely forgot about is missing features. If the MTK hack changed any nodes that are associated with the Faroudja chipset, say by by to your DVI output.
    Fw pour le oppo DV971H basés sur le Fw officiel OP971-D-1022
    Version ISO OPPO971 v9
    Infos:
    + Changed ugly file icons
    + Removed UOPs (prohibited user operations)
    + Pan&Scan mode works for all anamorphic DVD
    + Full width file list browser
    + Changed Audio Setup: Equalizer moved to new page, added Super bass, Bass boost, Treble boost settings
    + Extended SPDIF setup
    + Buttons "|<<" & ">>|" jumps to previous, next mp3.
    + Saves volume level after power off.
    download:
    http://bbk985s.narod.ru/firmwares/oppo9 ... 971.v9.zip
    Version NERO digital OPPO971 vc
    Infos:
    + Nero Digital (*.mp4) with chapters and embedded subtitles support.
    Download:
    http://bbk985s.narod.ru/firmwares/oppo9 ... 971.vC.zip
** Les TELECOMMANDES **
BBK OPDV971H-E silver remote
Oppo (US) OPDV971H Black remote
BBK OPDV971H-E black fat remote
ZOOM (217k):
http://montaleigne.free.fr/BBK/PHOTOS/T ... %20BIG.jpg
Oppo US & Oppo Cee (BBK) OPDV971H-E black blue-ish usa style remote
ZOOM (194k):
http://montaleigne.free.fr/BBK/PHOTOS/T ... sh_BIG.jpg
Note: Ceci est la dernière télécommande livrée avec les Oppo Cee de LC et aussi, avec les
télécommandes vendues par Oppo Digital US
Compte tenu que les nouveaux Fw issus des US (Oppo Digital) et de Cee (LC Hollande) sont tous compatibles avec la téléc Black blue-ish, il peut être judicieux de la commander aux US :
Il suffit d'envoyer à OPPO Digital le N° de série de vore Oppo ou BBK et vous recevrez pour 9 € ttc (prix du port) cette télécommande depuis les USA (Paiement par carte Visa ou Paypal)
C'est ici :
http://www.oppodigital.com/proddetail.a ... =971Remote
** FAQ BBK **
FAQ officielles (sur le Oppo-US, mais compatibles BBK)
FAQ de AVS Forum +++
FORUMS
Francophones sur le BBK
Anglophones sur l' Oppo US
Trouver le Firmware de votre BBK
    [Setup] sur la télécommande
    tapez 9210 sur la télécommande
    Apparition d'un Menu où est écrit la version du Fw
    [Setup] pour sortir
Upgrader son Firmware
Faut il installer un nouveau Firmware si on n'a pas de problème ?
    L'Admin. de LC m'a confimé une sage attitude :
    I am getting more people with upgrade dead machines.
    If it is working DO NOT FIX IT.
Donc: N'upgrader un Fw. que si c'est nécessaire: dans 3 cas:
    - Troubles constatés (et s'assurer que l'upgrade est bien prévue pour corriger ces troubles là)
    - Changement de télécommande
    - Release importante recommandée par le constructeur
Procédure de mise à jour
    http://www.livingcinema.nl/public/bbk/U ... 0steps.doc
    (non specif à la version du Fw.)
    http://www.oppodigital.com/opdv971h_fir ... nload.html
    La procédure de mise à jour, étape par étape
      1. Graver le Fw sur un CD R ou CD RW (Pas un DVD) vide et neuf, avec NERO ou un autre soft de gravure
      (Cf plus bas, la procédure avec Nero)
      2. Allumer le lecteur DVD (BBK/Oppo) et sortez le tiroir
      3. Mettre le CD du nouveau Firmware et fermez le tiroir
      4. Attendez, un message sur l'écran va vous demander de presser la touche PLAY, une fois, aussi, presser la touche "PLAY"
      5. Un message d'aide sur l'écran va afficher "FILE COPY”
      6. Après la fin de la copie (10 secondes environ), le tiroir s'ouvre tout seul. Sortez immédiatement le CD, ne fermez pas le tiroir, l'OSD va afficher "Waiting, Update…….”
      Note: A ce moment là, la mise à jour dure un moment .
      N'éteignez pas le lecteur et ne pressez aucune autre touche .
      Ne faites rien jusqu'à ce que le tiroir rentre
      nb : si vous avez oublié d'enlever le CD, un 2e flashage du Fw se produit; pas grave , mais retour à l'étape 5
      7. Attendez, quand la mise à jour est finie, le lecteur DVD va faire un Reset automatique, le tiroir rentre, et après qq instants, l'image réapparait.
      NOTE: Durant la mise à jour, n'éteignez pas le lecteur et ne faites aucune autre opération sur le lecteur jusqu'à la fin de la mise à jour.
      Si cela prend plus de 15 minutes pour que la mise à jour se finisse .... :evil: vous pouvez appeler Houston et dire "Houston, we have a problem.."[/color]
    ** Précautions à prendre **
      Assurez vous que la version soit compatible avec votre lecteur et votre...télécommande
      Gravure du fichier Fw. XXX.bin :
      Mode "ISO 9660" dans le soft de gravure (Nero par ex.) et non "Joliet" ou "Data"
      CD mono session
      Clôture du CD
      Vérification des données après gravure
    Si on débute, graver sur un CD-RW, vérifier si le fichier "XXX.bin" existe bien sur le CD gravé finalisé et verifier par le soft de gravure si le CD finalisé est bien en ISO 9660
    ** ATTENTION **
    Livingcinema NL m'a signalé qq. retours en SAV de Oppo/BBK morts car erreurs faites lors de l'upgrade de Fw : Alors, suivez la procédure pas à pas !!
    LC rappelle de ne pas modifier un Fw qui marche
    Toute fausse manoeuvre pouvant bloquer le lecteur et necessitant alors le retour en SAV du lecteur... et ceci n'est pas couvert par la garantie
    Source :
    http://www.livingcinema.dnsalias.com/ph ... c.php?t=38
    NB: Un onduleur de sécurité est conseillé:
    Toute coupure de courant durant le process, et ... Game OVER -> retour en SAV !
Procédure pas à pas de gravure du FW avec Nero 6.x
    Mettre un CD-R ou mieux, un CD-RW dans le graveur (réutilisation possible pour d'autres Fw)
    NB : n'utilisez pas un DVD-R ou un DVD-RW : cela ne semble pas fonctionner
    Ouvrir NERO 6.x
    [CD]
    [Copier et Sauvegarder]
    [Graver une image sur disque]
    Choisir le fichier Firmware que vous avez téléchargé : xxxx.iso
    [Ouvrir]
    Onglet [Burn]
      Cocher [Write], [Finalize CD], et [Buffer underrun protection]
      Choisir pour [Write speed] : le plus lent possible
      Choisir pour [Write method] : Track-at-once
    [Burn]
    Dans la fenêtre de copie en cours :
      Verifier : "Writing file CD-ROm Mode 1 Iso 9660"
      Cocher : [Verify written data]
    Allez jusqu'à la fin de la procédure de gravure puis de vérification
    Quittez Nero
    Lire le CD RW : un seul fichier visible : xxx.bin
Essayer de ressusciter un Lect. DVD "mort" après une MAJ ratée de Fw
Dézonner en toutes zones (zone 0)
    entrez "0" au code région pour mettre le lecteur en toutes zones
    [Setup] pour sortir
( Manoeuvre Old RC -> New RC et New RC -> Old RC )
But : Codes de la télécommande en cours -> Codes de la télécommande ancienne Oppo/BBK et réciproquement
exemples :
Black US -> Silver
Black blue-ish -> Black fat
etc..
    1. Allumer le lecteur et l'écran
    2. Fermer le tiroir (vide)
    3. Attendre le msg "No Disc" en haut à gauche de l'écran
    4. Appuyer et maintenir très fermement la bouton STOP du panneau avant du lecteur (pas celui de la télécommande), durant 5 secondes puis relachez.
    5. Un msg "Old RC" apparaît brièvement en haut à gauche de l'écran
    5bis. Si vous repêtez la manip, vous revenez alors à l'état initial :
    Un msg "New RC" apparaît alors brièvement en haut à gauche de l'écran
** Setup pour la lecture de DVD **
(Merci pour tout complèment ou correction)
-(1)- Setup en fichier Word, recommandé par le forum US AVS
-(2)- Regroupement en tableau Excel des setups de divers utilisateurs FR
-(3)- Setup perso (pas finalisé)
Setups : La plupart ne sont possibles qu'en mode [STOP]
[XX] : touche XX de la télécommande
-(3a)- [Setup] General Setup
    TV Display (Normal, Letter Box, Wide) : Wide
    OSD lang : French
    ScreenSaver (ON, OFF): ON
    SCART (YCbCr, RVB): Y Cb Cr (permet en même temps, aussi d'activer les 3 RCA de sortie YUV)
    LED Control (On, Off): On
    Spectrum : OFF
-(3b)- [Setup] Speaker Setup Page
-(3c)- [Setup] Audio Setup Page
-(3d)- [Setup] Video Setup Page
    Sharpness (High, Medium, Low, none) : Low
    Brightness (00+) : 00 (Conseil AVS = -3) mais .. selon le Firmware qui a décalé ou pas la référence du 0 de Brightness..
    Contrast (00+) : 00
    Saturation : +5
    (CSS) : off
    TrueLife (DCDI) : off
-(3e)- [Setup] Preference Page
    TV Type (PAL, NTSC, Auto) : PAL (permet aussi d'avoir les menus en 50Hz)
    PBC (ON, OFF) : off
    Audio : French
    Subtitle (On, Off): Off
    Disc Menu : French
    Parental (On, Off) : Off
    Password
    Default
[Setup]
    Video Mode (Video 1, Video2) : Video2 si DVD PAL (Z2 en général), Video 1 si DVD NTSC (Z1)
    Noise reduction (On, Off) : Off
Touches de Setup sur la télécommande
    [DVI] (576p, 540p, 720p, 1080i) : 720p
    [P/N] (PAL, NTSC, Auto) : Auto (ou PAL pour Z2 Pal, Ntsc pour Z1 Ntsc)
    [Audio] (Langages dispo sur le DVD) : French
-(4)- Setups d'utilisateurs
Misologue 26/05/06
    Oppo : OPDV971H.
    Firmware : 0302
    DVI 720p
    Diffuseur : Rétro DLP Thomson 50DLW616
    - Sharpness : low
    - Luminosité : -4
    - Contraste : +2
    - Saturation : 0
    - True life : OFF
    - CCS : OFF
    - Noise reduction : OFF
** DIVERS **
MANUELS pour le BBK (en pdf)
Testez votre BBK
VIDEO
DVD de tests VIDEO (DVD de tests dont on peut télécharger puis graver l'image ISO)
AUDIO
Le BBK pouvant projeter des diaporamas, un setup par mires couleur peut être judicieux
** NEWS ** (Ordre chronologique inversé)
28/07/06
    Info Oppo:
18.04/06
    Oppo Digital US a sorti le Fw 0316
    (Telec Black blue-ish & Silver)
    (Cf Section Firmwares)
    Info Oppo:
    Comparing to the official F-0302 release, the improvement included in this version is:
    1. Improvement to audio/video synchronization.
    2. Improvement to DVI output timing
    3. Longer audio delay option.
    4. Picture settings applied for PAL mode.
    5. Longer file name display in file browsing mode.
    6. Proper "Skip Prev" function for CD playback.
    7. Support for DivX Video-On-Demand activation.
09/04/06
    LC vient de sortir le Fw. 0315, (2e évolution du 0302 US)
    Il est en 3 versions pour les téléc Silver, Black FAT et Black Blue-ish
    Il est compatible Péritel ; Menus possibles en Français
    Nb : le logo '720p' manque lors du choix des résolutions de la sortie DVI (mais la résolution 720p est OK)
    Info LC:
    The 0315 firmware has been tested and is now release to the user.
    There is no official release text, but you can assume that all oppo fixes like pal synching on varuious displays has been improved in this release just like version 0302 from oppo usa.
    Your player will show 0315 when you check the firmware number. But you can not see from the OSD which remote you are using, look at your remote
10/03/06
    LC a sorti le Fw. 0302_3 pour la téléc Black FAT Cee mais compatible aussi avec la Black blue-ish
    Info LC:
    This firmware also works with the latest bluish-silver remote
    After upgrade, region is 1 and remote is blueish. so eject press stop 5 seconds and see "old rc" for region 0 eject> setup> 9210 > 0 > setup
    You are all set now, enjoy this firmware with your FAT remote.
03/03/06
    LC a sorti le Fw 0220_3 pour la téléc Black FAT Cee
    C'est un patch du Fw 0220 de Oppo US
26/02/06
23/01/06
21/01/06
    Les nouveauxBBK/Oppo CEE OPDV971H-E livrés après le 17 janvier 206 par LC NL sont désormais livrés avec la télecommande noire bleutée (Bloack Blue-ish) introduite par Oppo USA
    Le firmware installé dans les lecteurs livrés est désormais le OPDV971H-E-1226_4 qui est une évolution CEE du 1226, avec adaptation à cette télécommande
    La version du Fw affichée est : 1226
    Confirmation par un forumeur de LC : la nouvelle téléc livrée est bien le modèle US , "black blu-ish, silver back", avec le Fw 1226 version 4, adapté à cette télec.
    La télécommande noire "fat black Oppo/bbk Cee" semble abandonnée, dans le but d'une unification de la gamme
19/01/06
    [color=darkblue]
    Post Posted: Thu Jan 19, 2006 12:35 pm
    Post subject: BBK OPDV-971H-E remote specific firmwares 12-26-2005
    The 1226 firmware has been around for some time giving the next change list:
    1. Added ID3 tags for MP3 files.
    2. Improved explorer support: 20 supported characters.
    3. Added text scrolling (14 shown; 6 scroll)
    4. Audio Delay up to 120ms.
    4. DVI syncronization error fixed. Image no longer shifts at 720p/1080i.
    5. PAL settings are now remembered.
    We call the original Firmware 1226.
    We changed the original firmware to fix the Turelife text to Truelife. And adjusted the remote options for each remote available.
    Since the original 1226 Firmware from BBK we have made releases for:
    Silver BKK Remote Firmware OPDV971H-E-1226_2
    Black Oppo Europe Fat Remote Firmware OPDV971H-E-1226_3
    Blu-ish Oppo USA style Remote Firmware OPDV971H-E-1226_4
    Your player will show 1226 when you check the firmware number.
    All Oppo OPDV971H-E players shipped after 17 Jan 2006 have 1226_4 firmware installed.
    There is no use of using any oppo firmware as all firmwares from oppo before 1226 are worse, forgetting settings and no PAL optimisation.
    We will make these firmwares available here.
    Again if your firmware is running ok or you do not know what to do, don't fix it. Dead players need to be revived by us in the factory, so it is not covered by warranty and costs need to be covered by the customer.
11/01/06
    Le dernier Fw pour BBK à telec grise est retiré du download car Bug
05/01/06
    Le nouveau Fw BBKDV971H-2-1226 (silver rc) va être très bientôt dispo en download ; Revo a fini les tests qui sont OK
02/01/06
    Revo, l'admin de livingCinema NL a reçu le nouveau Fw pour la telec grise BBK , bénéficiant des derniers upgrades (PAL etc.); ce Fw est en test avant publication
31/12/05
    Nouveau Fw 1226 pour les OPDV971-H E à nouvelle telec noire CEE (Fat Black)
27/12/05
    Il se confirme qu'il n'y a plus que 2 modèles en vente sur le marché, tous pays confondus:
    - Oppo US OPDV971-H sans Scart, avec cordon US, nouvelle télécommande noire (arrière gris), firmware adapté,
    + bundle:
    1*cordon DVI/DVI 1,5m, 1*adaptateur DVI/HDMI, 1*cordon composite, 1 cordon stéreo RCA
    - Oppo CEE OPDV971-H E ("E" rajouté au nom) avec Scart, cordon CEE, nouvelle télécommande noire (mais différente de l'US), firmware adapté d'origine BBK; ce dernier modèle est vendu avec la marque Oppo mais correspond en fait, à ce que vendait la semaine dernière, LivingCinema sous la marque BBK
    + bundle :
    1*cordon DVI/DVI 1,5m, 1*cordon composite, 1 cordon stéreo RCA
    Source :LivingCinema NLPosted: Sat Dec 24, 2005 11:50 am
    Hi Jean Max,
    There a currently 2 models,
    1: the oppo from oppo usa, usa plug black silver remote, available from USA only.
    2: the oppo from bbk europe. We call it the opdv971h-e, it has scart and euro plug, and a bit bigger new remote.
    Unfortunately it has a different remote key mapping. BBKOppo production facility in china has promised to release the next firmware for both models!
Jean-Max
Inscription Forum: 06 Sep 1999 2:00
Message » 23 Déc 2005 11:31
allez, j'ais pas encore reçu mon Oppo alors je me permet de participer :wink:
Le BBK vous pouvez l'acheter chez Livingcinema pour un prix de 225 euro (à la date de ce post) hors frais de port et sans taxe supplémentaire pour une livraison en Europe.
Surflife
Inscription Forum: 08 Juil 2005 15:08
Message » 30 Déc 2005 18:11
La nouvelle télécommande Oppo, la noire, que vous pouvez vous procurer sur le site Oppo moyennant 9 dollars, est compatible avec les firmwares Oppo 1111. J'ai donc fait la maj sur mon BBK et cela fonctionne parfaitement pour le dvi (je n'ai pas testé les autres sorties :oops: ). Cela a d'ailleurs été confirmé par Sam Laibriz :wink: .
Cela va vous permettre de bénéficier des dernières mises à jours d'OPPO sur votre BBK.
Cordialement.
cano
Inscription Forum: 15 Aoû 2003 22:33
Message » 31 Déc 2005 15:26
Source : http://www.livingcinema.nl/phpBB2/viewtopic.php?p=95#95
Pour les OPPO/BBK OPDV971H-E recus après le 19 décembre 2005 :
Livrés avec le Fw 0917 et la nouvelle télécommande noire CEE (modèle un peu plus gros que le nouveau modèle de la téléc OPPO US)
> Nouveau firmware 1226
C'est une évolution du Fw 1111b de Oppo US
avec :
Support de la nouvelle télécommande noire CEE
Support de base des Tags MP3
Amélioration du PAL (2:2 pulldown fluide)
Amélioration du scaling en 1080i et 720p
Allongement à 120ms du Delai Audio
Qq trucs en plus..
ISO firmware image 1226 for BBK OPDV971H-E new black remote
Nero firmware image 1226 for BBK OPDV971H-E new black remote
Black remote only:
Image[/quote]
Jean-Max
Message » 02 Jan 2006 14:07
Ceux qui ont le premier BBK avec telco grise, ne peuvent pas faire l'upgrade, même avec la manip ?
Han Solo
Inscription Forum: 28 Jan 2002 2:00
Message » 02 Jan 2006 15:41
Han Solo a écrit:Ceux qui ont le premier BBK avec telco grise, ne peuvent pas faire l'upgrade, même avec la manip ?
A priori, non :cry: . Un nouveau firmware est attendu d'aprés Revo, l'admin de livingcinema.
What we mean Jean Max is that BBK and LivingCinema are working to release firmwares for all models. No need to order new remotes.
So this is the first one for black bbk remotes, the silver remote support will release soon, use 1022 in the mean time.
cano
Message » 02 Jan 2006 18:17
Juste un Bravo à Jean Max pour l'aspect très complet du premier post de ce sujet ...
Peut-être ajouter à la rubrique "Divers" qu'il faut bien mettre le mode vidéo sur "vidéo2" (à moins que le BBK/Oppo européen soit déjà réglé dessus en sortie usine contrairement à l'Oppo US ?) pour la qualité d'image ...
Surflife
Message » 02 Jan 2006 18:20
cano a écrit:Ceux qui ont le premier BBK avec telco grise, ne peuvent pas faire l'upgrade, même avec la manip ?
Hello,
Revo, l'admin. de LivingCinema NL m'a contacté pour un user test du tout nouveau Fw pour telec grise
Comme tout mon matos est retourné en caisse pour le moment, si un BBKiste du forum, à telec grise, veut se manifester auprès de **Revo**, cela pourrait l'aider à valider ce nouveau Fw
Merci :)
Jean-Max
Message » 02 Jan 2006 18:28
Surflife a écrit:Juste un Bravo à Jean Max pour l'aspect très complet du premier post de ce sujet
Merci pour tes encouragements :)
Je vais suivre ton idée pour cette rubrique "Divers"
Je regroupe les elements pour çà :)
(mais ce sont des elements communs avec l'OPPPO, que l'on trouve déjà sur la
**FAQ de l'OPPO**
alors, que fait-on ??
AVIS GENERAL
Pour le plan POLMAR 2006, toute idée pour le fil du BBK :
Merci de la poster sur ce fil BBK et pas sur le fil OPPO ;) ;) ;)
Jean-Max
Message » 02 Jan 2006 19:11
Question naïve : qu'est-ce que le plan POLMAR ?
RL
remedylane
Inscription Forum: 07 Sep 2005 14:41
Message » 02 Jan 2006 19:35
remedylane a écrit:Question naïve : qu'est-ce que le plan POLMAR ?
RL
Les BBKistes ont étés taxés de Pollution en postant sur le thread du Oppo..
Rappel : Le plan POLMAR est le plan anti Pollution pour marée noire..
Jean-Max
Message » 02 Jan 2006 19:50
RL
remedylane
Message » 02 Jan 2006 20:58
une tres faible minorité (qui à dit une personne? :mdr:) ont traité de pollution les BBKistes...
Je ne suis pas pour une séparation des topics...
Mais bon, je viendrais aussi glaner des infos ici.... ;)
cedbh
Inscription Forum: 10 Aoû 2005 20:11
Message » 02 Jan 2006 23:46
Hello,
Merci :)
J'ai fait une demande à revo, j'attends sa réponse :wink: .
cano
Message » 03 Jan 2006 9:43
Jean-Max a écrit:Comme tout mon matos est retourné en caisse pour le moment, si un BBKiste du forum, à telec grise, veut se manifester auprès de **Revo**, cela pourrait l'aider à valider ce nouveau Fw
Merci :)
ben moi je veux bien, pas de problème, c'est sur quel post (ou bien faut absolument le contacter en mp ?) ?
Pour le plan Polmar je pense que vous connaissez mon avis sur le sujet :roll:
Han Solo
Retourner vers Lecteurs DVD / HD-DVD / Laser Disque
