1.8.1.2 - 23/09/2008
* New: Support for Blu-ray playback with ArcSoft TMT
* New: Added hotkey to show the properties window (default is CTRL+ALT+SHIFT+R)
* New: Hotkeys can be modified (currently via regedit only, sorry)
* New: Config tool doesn't need to run under admin account
* New: Added option to accept SPDIF as input (disabled by default). This is important, because Windows Media player under Vista will always try to use SPDIF if possible, which isn't quite the right way when using ReClock.
* Change: Removed obsolete option to make ReClock the default renderer
* Change: uses proper OS function to register the hotkeys to avoid conflicts. As a side effect, this could cause slightly improved playback
* Change: logfile location will be the user's desktop
* Fix: Sync problems when using the real time AC3 encoder. Fixes startup problems with PowerDVD and TMT. Works fine now!
* Fix: Access rights for registry keys weren't set correctly (Windows Vista)
* Various fixes and improvements
