Cela ne marchait pas avec eac3to version 2.46 il semble que la libav n'était pas capable de faire la conversion:
- Code: Tout sélectionner
eac3to v2.46
command line: "H:\Logiciels\HDvideo\eac3to\eac3to.exe" "L:\f2hdqaa.track_231.ac3" "H:\f2hdqaa.track_231.ac3"
E-AC3, 5.1 channels, 0:00:39, 256kbit/s, 48khz, dialnorm: -25dB
The Nero decoder doesn't seem to work, will use libav instead.
Removing dialog normalization...
Remapping channels...
Loading white noise (needed for dithering)...
Encoding AC3...
[libav] Spectral extension is not implemented. If you want to help, update your FFmpeg version to the newest one from SVN. If the problem still occurs, it means that your file has extension which has not been tested due to a lack of samples exhibiting this feature. Upload a sample of the audio from this file to ftp://upload.mplayerhq.hu/incoming and contact the ffmpeg-devel mailing list.
[libav] error parsing the audio block
The last (E-)AC3 frame is incomplete and thus gets skipped.
Creating file "H:\f2hdqaa.track_231.ac3"...
eac3to processing took 13 seconds.
Done.
j'obtenais un fichier de 10s.
Donc j'ai mis à jour eac3to en v 3.15 et surtout installé Nero 7.10 et le Plug-in HDDVD
eac3to v3.15
command line: "H:\Logiciels\HDvideo\eac3to v3.15\eac3to.exe" "H:\f2hdqaa\Timeshift_04-26_12-04-37_France_2_HD_qaa.track_231.ac3" "L:\f2hdqaa\Timeshift_04-26_12-04-37_France_2_HD_qaa.track_231.ac3"
E-AC3, 5.1 channels, 0:00:39, 256kbps, 48khz, dialnorm: -25dB
Disabling DRC for Nero (E-)AC3 decoding...
Removing E-AC3 dialog normalization...
Decoding with DirectShow (Nero Audio Decoder 2)...
DirectShow reports 5.1 channels, 24 bits, 48khz
Encoding AC3 <640kbps> with libAften...
Creating file "L:\f2hdqaa\Timeshift_04-26_12-04-37_France_2_HD_qaa.track_231.ac3"...
[b]The last (E-)AC3 frame is incomplete and thus gets skipped.[/b] <WARNING>
eac3to processing took 12 seconds.
Done.
Il y a juste une petite erreur à la fin mais ça marche.
Merci encore à Chilly de HDFrance pour son aide!!
PS Tout conseil pour acquérir une carte PCI ou une clé USB permettant d'enregistrer (le visionnage étant réalisé avec ma popcorn a100) la TNT HD avec le DD+ et pouvant tourner sur une machine Intel CPUDual core 1.8 Ghz 512 Mo de RAM est le bienvenue!
