Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: bienvenu, jeanluc79, philb et 33 invités
Pre Ampli Arcam FMJ AV 888
Message » 23 Juin 2009 12:45
Suite au succes de l'integre 666, Arcam sort donc la version pre ampli. L' AV 888 qui sera disponible cet été 2009. Il va remplacer L'AV9 qui a eu un gros succés outre manche.
Le site du constructeur
ARCAM
Quelques photos :
Puis les Spec :
Analogue Audio
Audiophile quality components for best sound quality
Multi-channel 7.1 analogue input for DVD-A or SACD sources
Stereo direct mode bypasses and disables all digital processing for 2 channel analogue sources
9 stereo analogue inputs (including one MM phono input & front 3.5mm AUX input)
Zone 2 stereo audio, from analogue inputs (Source and volume control independent from main zone)
Zone 3 stereo audio, from analogue inputs, linked to Zone 2, volume control independent
Support for iPod via Arcam rLead / rDock (independent of RS232 connection)
Digital Audio
State of the art Analog Devices ADSP-21366 & ADSP-21367 DSPs for surround decoding
Wolfson 8471 high end 24bit 192kHz audio DACs
Crystal Semiconductor stereo ADC and precision electronic volume controls
Burr Brown DRV134 Balanced line drivers
Dolby TrueHD, Dolby Digital+, Dolby Digital EX, Dolby Pro Logic IIx, DTS HD Master Audio*
DTS High Resolution Audio, DTS-ES Discrete, DTS-ES Matrix, DTS96/24, DTS Neo:6**
Dolby Volume gain management and Tonal correction processing*
Dolby Volume processing for balancing of program material gain and tonal balance
Adjustable crossover switching 40Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz
8 digital inputs 4 rear optical, 3 co-axial, 1 front 3.5mm optical AUX input
Global audio delay, adjustable from 0-1000 milliseconds, to compensate for video processing delays in digital displays and sources with auto lip-sync for compatible displays
Video
5 HDMI inputs (up to 1080p, Deep Colour)
2 HDMI outputs (up to 1080p, Deep Colour)
5 Component inputs, one monitor output (up to 1080i)
5 S-video inputs, one monitor output, 2 tape outputs
5 Composite video inputs, one monitor output, 2 tape outputs
Full video up/down conversion & frame rate conversion of all inputs where technically allowed
Video enhancements (per input): Edge enhancement, Mosquito noise reduction, Random noise reduction, Block noise reduction
Custom Install Features
Independent Zone 2 (audio & video), with fixed/variable volume
Zone 3 audio with fixed/variable volume (follows Zone 2)
Balanced audio outputs (XLR) for long cables or active speakers
RC-5 remote input jacks for all three zones
IP control over Ethernet
IR pass through for source components
Full suite of discrete IR RC-5 codes, including separate on / off etc
12Volt triggers, on / off for zones 1, 2 and 3
Full duplex RS232 control input for more complex control systems
Audio streaming and Internet radio via Ethernet port
General
Supplied with back-lit CR102 learning remote
control with support for up to 7 other components and a huge on-board code library
Large, high contrast dimmable VFD front panel display
User switchable between 120 & 230 volt
mains supplies
Size – 435mm (17.1in) wide, 415mm (16.3in)
deep, 185mm (7.3in) high
Weight 12kg (26.5lbs) nett, 17kg (37.5lbs) packed
Download the owners manual
Arcam have pushed the boundaries for combined music and movie reproduction
gil2b
Inscription Forum: 28 Déc 2003 19:52
Message » 23 Juin 2009 13:09
J'aime bien son look minimaliste, ça fait "pro" :mdr:
bouda1976
Inscription Forum: 25 Fév 2008 18:54
Message » 23 Juin 2009 14:21
Puis sur la face arriere, tout est a sa place, tout est en ordre, bien aligné 8) avec en plus des sorties XLR
Gil
gil2b
Message » 23 Juin 2009 14:28
sinon tu pense que le P 777 qui est le blocs de puissances de arcam serais meilleurs que mon bloc cherbourn 5210A ou bien !!!
car je pourrais prendre le 888 en pres et le bloc 777 comme cela tous arcam :P mais j'ai de gros doute sur le bloc 777 il na pas lerre d'êtres du niveaux du cherbourn enffin faux voire
une photos du 600 intégrer pas mal l'infrastructure interne :P
je cherche pour les photos internes du 888 :wink: :wink: mais tres harde deja pour le 600 pas faciles :cry:
loki100
Inscription Forum: 31 Oct 2007 17:19
Message » 23 Juin 2009 18:06
BON SINON SA CE PRECICE JE VA
loki100
Message » 23 Juin 2009 18:10
bon ca ce précise je vais pouvoir teste in situ dans mon instale le arcam AV 600 :P et voir surtout écouter se que ça donne en sonoriter musicale avec les D7 je serais fixe une foie pour tous :wink:
et si tous se passe bien achats du 888 quand il sortira
a très bientôt pour teste alors
loki
loki100
Message » 23 Juin 2009 18:47
+1 pour l'ouverture de ce post. :wink:
Arcam vient de mettre en ligne le AV888, donc c'est bon signe, il devrait arriver rapidement.
Voici le lien pour le AV888 : http://www.arcam.co.uk/products,fmj,AV- ... ,AV888.htm
et le lien pour le P777 : http://www.arcam.co.uk/products,fmj,Pow ... s,P777.htm
hamster
Inscription Forum: 21 Avr 2007 19:27
Message » 23 Juin 2009 19:00
Et une idée des prix ?
karyboue
Inscription Forum: 02 Aoû 2001 2:00
Message » 23 Juin 2009 19:08
+1
david555
Administrateur Suppléant de l'Association - Vice-Président & Superviseur Forum Univers TV
Inscription Forum: 02 Oct 2005 18:13
Message » 23 Juin 2009 19:22
A priori, même prix que l'AVR600, soit environ 4000 euros en France.
PingouMasqué
Inscription Forum: 07 Déc 2007 10:14
Message » 23 Juin 2009 21:24
oui il arrive très très très bientôt :P :P :P :P
loki100
Message » 23 Juin 2009 21:25
PingouMasqué a écrit:A priori, même prix que l'AVR600, soit environ 4000 euros en France.
exsactes 4000 euros
a++ les amis loki
loki100
Message » 24 Juin 2009 9:55
Vivement les 1ers Essais. Avec un peu de bol la revue du Son va s'en occuper....
Gil
gil2b
Message » 24 Juin 2009 10:00
Il y a quelque chose que je ne comprends pas.
Si le préampli HC AV888 est issu de l'ampli intégré HC AVR600 ( les étages d'amplification en moins ) il devrait être moins cher et pas au même prix.
sonatine
Inscription Forum: 28 Jan 2002 2:00
Message » 24 Juin 2009 10:51
sonatine a écrit:Il y a quelque chose que je ne comprends pas.
Oui mais il vont justifier cela par les sorties Symetriques :mdr: ...
Peut etre sera il un poil moins cher, pour l'instant nous supputons sur le prix.
Gil
gil2b
