Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Patrick.L, vévé et 13 invités
Tout sur les écrans de projection (fixes, déroulants, ouvrants, motorisés...)
Ecran Telon 120" PET Crystal UST (Alibaba)
Message » 11 Jan 2020 22:35
Je suis en contact avec le vendeur de cet écran sur Alibaba :
https://www.alibaba.com/product-detail/Telon-120-4K-PET-Crystal-ust_62313256897.html?spm=a2700.12243863.0.0.471b3e5fw5Om51&bypass=true&bm=cps&src=saf&pid=269979&tp1=17943_1578774046_29173f8873d3792acea32bf0a68b853d&awc=17943_1578774046_29173f8873d3792acea32bf0a68b853d
J'ai posté ces infos sur Dealabs pour un éventuel achat groupé, mais on m'a conseillé de vous en faire part, pour éventuellement des retours, ou si d'autres personnes étaient intéressées.
Voici les réponses du vendeur à mes questions :
What is the price for 120' screen, shipping included, to France ?
The total amount for 1 pc is $480+$191 by TNT
603 euros environ
How about the fees ?
We will fill out the value of the screen $150 in the commercial invoice for custom. it is ok for other countries,I don't know If any problem for your country.
Can we pay by paypal ?
Yes, but there will be an extra charge of paypal : 4,5%
What is the difference between "Telon" and "XY" Screen ?
Our fabric and XY fabric are from the same supplier in Taiwan and we are bigger factory to manufacture projection screen for 11 years. All of parts are produced by ourself even paper carton.
Is it level A or level B ?
We didn't sell the level B as it's not good.
See video, level A is on the right :
https://clouddisk.alibaba.com/file/down ... KRYhe4AWNY
Dimensions of the screen :
120' : 2.66*1.49m
If you want 100' : 2.21*1.24m (the price for 100inch is $298/pc and shipping fee is $165 by TNT)
What about edge around the screen ?
Our buyers like narrow edge frame screen,the edge is 1cm as video.you can choose the edge for 6 cm.8 cm also and 10cm,15cm is for large fixed frame screen.
Can you use other shipping services to reduce its price, because delay is not a problem ?
We suggest use TNT or Fedex as the fabric for PET Crystal is easy broken.If we used the cheaper shipping,it couldn't make sure to protect it good.
What are our recourses if there is a quality issue ?
Our warranty is one year and we will take responsible for it if any damage during the shipping. No worries !
Actually you don't need to worry about the quality as none of our customer unsatisfied with it after received. You can check our buyer reviews. If quality issue,we will pay for the returned shipping fee.
Des gens qui auraient déjà acheté ce type de matériel ?
Des intéressés pour une commande groupée (on aura un prix si > à 5 personnes) ?
benj63540
Inscription Forum: 11 Jan 2020 18:26
Message » 12 Jan 2020 13:05
Moi, ça m'intéresse, j'avais prévu un 100 pouces.
En regardant les caractéristiques du packet, je trouve la longueur de celui-ci un peu petit pour un 120 ".?
-> Je me corrige : les rails sont démontés.
Par contre, je ne trouve pas sur Dealabs ton post .?
loulou400
Inscription Forum: 10 Déc 2009 14:05
Message » 12 Jan 2020 13:48
benj63540
Message » 12 Jan 2020 15:33
Ok merci, je pense plutôt partir sur un 100 ", je vais solliciter une offre auprès du revendeur. :mdr:
loulou400
Message » 16 Jan 2020 22:27
Je suis potentiellement intéréssé, car je suis en contact avec XYSCREEN pour leur 120" ALR UST, mais c'est 1300 € annoncé hors FDP, donc le double. Si c'est la même toile ALR UST, çà vaut le coup.
Mais je suis embêté, je ne trouve d'infos sur le gain : 0.6 ? 0.8 ?
De plus, leurs bords ne fond que 1,8 cm, alors que je souhaite des bords plus grands (mon UHZ65UST a une zone autour de l'image de 2 cm en 100", et peut être 3 en 120") donc je voudrais un cadre de 4 ou 5 cm max
Tu penses faire çà quand ? ou plus à quelle date max tu décides ?
emmfau
Inscription Forum: 22 Mai 2019 11:03
Message » 16 Jan 2020 22:42
J'ai remesuré mes marges en 120", c'est 2.6cm, donc çà colle avec leur frame width de 6cm pour moi ( s'il y avait 4cm ce serait idéal , mais on va pas chipoter )
Le gain j'ai trouvé 0.8 ou 0.85 selon les autres produits alibaba avec les mêmes photos,, donc ok pour moi ( par exemple 8.5 avec https://www.alibaba.com/product-detail/ ... 1900oNodsJ )
Dans mes échanges avec XYSCREEN, j'avais eu 2 devis pour des toiles PET Crystal : lines et grid. Faudrait être sûr que c'est une toile PET Crystal lines.
Dans la description, je vois " The curve design for curved frame projector screen "... L'écran est légèrement incurvé ? Moi je suis pour un 100% plat :)
emmfau
Message » 16 Jan 2020 23:16
Pour ma part, pour l'instant, je vais finalement tenter de faire sans écran.
Je vais essayer directement sur mon mur, une fois que j'aurai enlevé la TV actuelle et que j'aurai rebouché le trou des chevilles et que je aurais lissé.
Mais je ne m'interdis pas d'acheter cet écran dans un deuxième temps en fonction du rendu sans !
Dans tous les cas :
- pour l'instant, ce sont les vacances du nouvel an chinois là bas, et ils ne pourront pas faire d'expédition avant début février
- les tarifs que j'ai indiqués ne sont pas forcément liés à une commande groupée. Tu peux commander chez eux tout seul, sans forcément passer par moi (je peux bien sûr te donner le nom du contact !)
Pour répondre à tes questions, je sais qu'ils font différentes tailles de bordures, voilà ce qu'ils m'avaient répondu :
"Hi Benjamin,As for the dimension of the screen,100inch is 2.21*1.24m and 120inch is 2.66*1.49m and our buyers like narrow edge frame screen,the edge is 1cm as video.you can choose the edge for 6 cm.8 cm also and 10cm,15cm is for large fixed frame screen. But few of buyers like large edge"
Pour les détails techniques, sur le bon de commande, c'est indiqué :
Gain 0.8
Angle 160
Pour tes autres questions, je demande !
benj63540
Message » 17 Jan 2020 4:12
Voilà :
Is it Crystal grid or Crystal lines ? In the description, it is written "the curve design for curved frame projector screen "... is the screen curved, or totally flat ?
Hi,our screen fabric is PET crystal LINES,and it's flat not curved
benj63540
Message » 17 Jan 2020 9:40
Classe la réactivité : thx !
emmfau
Message » 17 Jan 2020 9:42
J'ai viré mon écran 100" kimex blanc de gain 1.1 pour projeter sur le mur direct également depuis 3 semaines. J'ai testé un mi écran mur / écran.. Même si c'est du blanc je préfère l'image sur la toile, donc je m'oriente vers un écran c sûr :)
emmfau
Message » 17 Jan 2020 9:54
De rien ! Je ne dormais pas cette nuit, donc j'en ai profité pour poser la question alors qu'en Chine ils étaient aussi réveillés :)
Et tu t'orienteras vers 100 pouces ou vers 120 pouces pour le nouvel écran ?
Quel est ton utilisation du projo, c'est une salle dédiée et ce sera uniquement pour voir des films, ou tu t'en sers au quotidien pour voir la TV ?
Je te pose la question car ce qui me freine aussi, c'est que sans écran, en décalant + ou - le projo du mur, je pourrai être soit en 80 ou 100 pouces quand je voudrai voir la TV, soit en une + grande taille quand je voudrai voir des films... alors qu'avec un écran, ce sera toujours 100 ou 120 pouces...
benj63540
Message » 17 Jan 2020 11:57
Mon utilisation du projo = au quotidien et pour toute la famille, "comme un tv" = l'unique écran dans le salon, écran à tout faire : j'ai un PCHC branché dessus avec carte double tuner TNT, et une switch. Pour moi perso, ce que je préfère c'est plutôt le soir avec un petit rituel "cinéma" :
extinction des lumières, des volets, l'ampli 5.1, le petit café, et des films ou séries HD, 4K, HDR.. :)
Cà fait 3 semaines qu'on essaye en famille les 2 tailles d'écran sur le mur : 100 et 120. A 4m de distance des yeux, normalement c'est le 100" qui est l'idéal "en théorie" p/r à l'angle de vision. Mais en pratique ... plus le temps passe, plus on le laisse en 120" et on a envie d'un 120.
Et avec un écran 120, tu peux toujours projeter plus petit dedans : 80 ou 100
Au final chez moi : " L'envie l'emporte sur la raison " :)
emmfau
Message » 17 Jan 2020 12:17
Moi aussi, souvent l'envie emporte la raison, mais c'est encore la raison qui me fait hésiter :wink:
Et je vois qu'on a exactement la même utilisation : écran unique dans la pièce à vivre, qui sert pour regarder la TV, jouer à la Switch et regarder occasionnellement des films.
Pour la TV, je passerai par Molotov TV.
Si c'est pas indiscret, tu aurais des photos de ton installation ? Avec l'affichage en 100 pouces et 120 pouces ?
Et puis ça serait intéressant une photo, dans les mêmes conditions de luminosité, quand tu auras l'écran, histoire qu'on voit la différence !
Je sais pas si tu as vu mon post sur Dealabs, mais de mon côté j'ai simulé ce que ça donnerait chez moi :
Actuellement, plasma 50 pouces :
Si 100 pouces :
Si 120 pouces :
benj63540
Message » 17 Jan 2020 21:56
Voici l'affichage en 120" de ce soir avec un petit mario kart ( qualité de photo médiocre depuis mon smartphone dans le noir ), je n'ai pas encore d'installation, tout est posé par terre ou sur des tables ikea de base à 45cm de hauteur pour l'instant.
Mon mur est "taupe" = une espèce de marron qui tire sur le rouge, donc l'image projetée sur le mur est délavée et rouge
L'image en 120" est très proche de mon plafond de 2,45m (10cm).. mais çà passe :)
Je vais étudier un peu ce week end, et je verrais si je franchis le pas, car 600 € c'est un tarif "acceptable" pour mon budget :) Mais on a peu de retour sur cet écran .. ( et les autres de XYSCREEN testés sur le net sont plutôt en gain 0.6... il est bizarre ce 0.8)
PS : Molotov ne marche pas sur le UHZ65UST pour info (pb de DRM en cours de correction chez Optoma à priori).
emmfau
Message » 17 Jan 2020 22:40
Merci pour le partage :)
Effectivement c'est ce que je me dis aussi, 600 euros ça pourrait passer dans mon budget, mais pas au delà... Mon mur est gris clair donc je pense que les couleurs seront moins dénaturées...
benj63540
Retourner vers Ecrans de projection
