themouloud a écrit:swords a écrit:Ouaiiiiiii
Je regarde tous les jours depuis 15 jours
1,46BL have just release 1.46.
Fix list (v1.46):
IMS21645: Add DTS Neural:X & DTS Virtual:X to mode list if incoming format is DD2.0
IMS21647: Zone 2 audio seems affected by zone 1 upmixer
IMS21653: DANTE JBL using DANTE no audio from any 44.1kHz input (NET, CD, etc)
IMS21843: Height C & S speakers play Atmos Height middle source audio in 9.2.6 setup
IMS22108: Unit freezing when installing Dirac filters
IMS22358: DANTE – very low level click during Dirac calibration
IMS22410: When volume is 0 sub still had low output
IMS22416: Podcasts longer than 100 minutes display “—“ instead of time
IMS22428: Casting to AVR through spotify no longer wakes unit from standby
IMS22433: Strange characters appear on screen when changing volume
IMS22442: Front panel volume control goes up before down and down before up with Dante enabled
IMS22445: DANTE Burst of noise through all Dante channels with Atmos (A Star Is Born - 4K)
IMS22471: Grey bar appears on the screen if changes are made to the speaker types with the web gui
IMS22475: When control is set to RS232, internal test tones from web gui will not work
IMS22482: Sub can rarely go to high volume on power on
IMS22486: Streaming audio changing MCH stereo > Virtual X then skipping 5-10+ tracks could cause lockup
IMS22501: DLCT gets incorrect gain value from AVR unless the master output level is adjusted
IMS22525: 3D - OSD missing background
IMS22545: RS232/IP sending command 0x0D while unit is in mute shows volume on OSD but not front display
IMS22546: RS232/IP erroneous character displayed on URC controller
IMS22550: No sub out on ch13-16 with Auro and Speaker Types > Subwoofer > Present
IMS22705: “Display On Time” still active during update
IMS22725: Add volume control to web client GUI
IMS22732: Internet radio timer on display will start counting in letters for longer listening times
IMS22733: DANTE – pop at start of Dirac measurement
IMS22734: RS232/IP – Command 0x43 returns Analogue Direct for DTS:X source
IMS22738: Front panel shows “Bluetooth Not Connected” after being powered up from standby on BT input
IMS22743: RS232/IP commands sometimes not ack’d
IMS22830: Unable to change wifi networks from web gui
IMS22832: 24/96 Auro +EQ loses Auro (gices just DTS HDMA)
IMS22835: Allow choice to reset or not after update
IMS22858: Sub gain in “Speaker Types” menu does not apply so subs attached to ch13/14/15/16
Ah la vache ils se sont passés le mot aujourd'hui j'étais avec mon fils toute la journée j'ai pas regardé et il est sorti
En même temps quand on lit les mises à jour vu le délai qu'ils ont mis à sortir cette version je trouve qu'il n'y a pas de révolution surtout pour ceux qui n'existe pas dante
Ce soir mise à jour apéro
