Follow the below steps to improve your performance on Windows 10 using Virtual Memory.
◾Open up Control Panel
◾Type in Performance into the search field
◾Click Adjust the appeareance and performance of Windows
◾Open Advanced tab and click Change button
◾Select Custom size
◾Set Initial Size (MB) and Max size (MB) to the value Recommended by Windows.
◾Click Set and OK to close the window
◾Restart your device and you're done
Hope this helps someone out there.
Source:
http://www.winmatrix.com/forums/index.p ... al-memory/
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: gastms et 130 invités
Windows 10 "RTM" 10240 en test
- lcdmen
- Contributeur HCFR 2024
