Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: albator91, bab1c, banjo65, Bidib, gallak, gamerone2008, Gaël, guillaumodore, gwendal55, jcre17, ludo3159, mirak, papounay, Patbon21500, Patoche21, patriceonkyo, Pilou57, rere130, rezoli, subsonic, sylvain-best, Tommyknockerz99, tony51, Wend, Yvounet et 249 invités
Zidoo X8/X9S/X10 RTD1295 (4K60/HDR/BD menu/Control4)
Merci pour l'info pacifico.
Salle dédiée 7.1.4 3D 4K :Onkyo TX-RZ50, Emotiva BasX A3, SVS Prime Bookshelf + Center + Satellite + Elevation, Ultra Surround, SVS PB-2000 Pro, LG Oled CX, BenQ W4000i, Oray cadre, Panasonic UB820, PS5, Xbox Series X, Zidoo Z9X, Shield TV Pro,M9702 V3
evangelion77 - Membre HCFR Contributeur
- Inscription Forum: 19 Oct 2010 23:15
merci pacifico,
on va mettre le changelog,
mumakil, as tu vu ceci, on va peut etre sortir du tunnel :
System
1. Fixed the problem that the bluetooth will turn on automatically when starting up
2. Fixed the color exception of HDMI IN recording
3. Fixed random crash problem when playback video
4. Repairing playback 4K HDR and 10bit output, some TVs have minor color banding problems
5. Fixed the original blu-ray audio drop problem of individual special playlists (Seamless Branching )
6. Optimized system stability
Wall poster
1. Added children lock dynamic locking function
2. Modified child lock description
3. Fixed the problem that the rating of individual films cannot be obtained
4. Added the mandatory password change function (set - child lock interface, focus on the unlock button, and then press "menu 21000" to page out password change interface)
5. Optimization matching (for example, speed and passion 1 match to 10)
6. Added the "mark as seen" function
7. Added batch operation functions for collection, viewing records and unwatched categories
8. Solved the problem that douban cannot get stills photos
9. Adjust the welcome screen UI
10. The main interface does not match the classification to increase the batch deletion function
11. Fixed the problem that whether the network equipment is connected or not and judge the error
12. Repair the problem that the equipment cannot be connected normally after starting up occasionally
13. Optimized memory footprint and improve fluency
14. Added edit mode
15. Fixed the problem that the poster interface of the children's zone was not refreshed
16. Added page turning function (page turning key or number 2 and number to the main interface
17. Video number and matching success data information are added to the device interface
18. Device management interface adds scanning progress prompt
19. Fixed the problem of missing unmatched video caused by manual stop scanning
Player
1. Fixed the problem that video did not close when playing, press the HOME button video
2. Download the subtitle interface to add the film name prompt
3. The default mode of playback is all cyclic playback
4. Optimized subtitle display
5. Optimized subtitle download and increase the matching success rate
6. Optimized the subtitle adjustment interface
7. Optimized playback stability
Blu-ray navigation
1. Synchronized the subtitles of local players
The control center
Fixed some translations
Music player
1. Modified the issue of SACD audio crash in the playback part
2. Modified and open the music player when starting up the machine to play SACD music, and the problem of playing SACD music needs to be selected twice
3. Increased the playback SACD audio sampling rate to 176.4Khz
File manager
1. Solved the problem of too long loading time into the list interface
2. Fixed the flash back problem of SMB password with special characters
3. Selected video file to open by default
Quick settings
1. Added SACD audio processing switch
System
Wall poster
14. Added edit mode
Player
Blu-ray navigation
The control center
Music player
File manager
Quick settings
- OlivierQC
- Contributeur HCFR 2018
- Inscription Forum: 23 Avr 2003 14:01
Hello,
Oui je vois très bien ta phrase en gras.
Il ne reste plus qu'à prier que cela soit résolu !!!
Si j'ai le temps ce soir, je ferai l'essai....
Sinon je suis en FW 2.0.15 et j'ai cru lire que certains avaient des problèmes avec zdmc et le FW 2.0.25.
Je voudrais savoir si c'est toujours le cas. Et que ce New FW, n'est pas le même problème....
- Mumakil
- Inscription Forum: 20 Juil 2014 18:07
Comment ça tu fais l'essai ce soir ???Mumakil a écrit:Oui je vois très bien ta phrase en gras.
T'as un lien pour DL le FW en question ?
- Jacky67
- Inscription Forum: 14 Fév 2011 20:14
Jacky67 a écrit:Comment ça tu fais l'essai ce soir ???Mumakil a écrit:Oui je vois très bien ta phrase en gras.
Sur la page précédente, tu as le lien vers le forum de zidoo avec l adresse ou télécharger cette nouvelle bêta: http://apidl.zidoo.tv/X9S/v2.0.32/ZIDOO ... 13-ota.zip
Attention, ce FW n est valable que pour les X9S.
- nnay07
- Inscription Forum: 05 Mar 2006 22:23
Bonsoir
J'ai fait la maj, pour les sous-titres, ils ont amélioré le truc mais je trouve que c'est pas encore ça
Maintenant c'est écrit la langue en entier, et l'extension si c'est du PGS, mais pas de distinction entre les forcés et complets :/
- Yomeee
- Inscription Forum: 29 Mar 2018 10:07
Yomeee a écrit:Bonsoir
J'ai fait aussi la MàJ. On est d'accord . Elle sont ou les améliorations ?
L'effet de banding (bandes que l'on peut voir sur les fonds bleu du ciel) est toujours présent .
Il suffit de prendre la démo 4k hdr Wonderland de Samsung pour s'en rendre compte immédiatement.
L'AppleTv 4k avec Muse ou MrMc sort des images sans banding pour la même vidéo.
Le Zidoo X9s par contre est parfait pour les vidéos 2k .A suivre.
- roromimi
- Inscription Forum: 06 Juin 2008 19:23
Hello,
Un petit retour sur ce new fw.
Il y a une nette amélioration sur les problèmes de banding (ce n'est que mon avis)
Testé sur John wick, demo wonderland et seul sur mars.
Ce n'est pas la perfection, mais c'est acceptable. Si on se focalise sur l'image entière et non seulement sur les zones sensibles
Bah c'est correct.....
Après je n'ai pas testé toutes les combinaisons possible.
Je suis réglé en 10 bits, Hdmi range en auto et le space color en auto.
- Mumakil
Bonjour a tous,
Selon Mirror, Zidoo prevoit d'inclure cette option dans un prochain FW :
Hi, We will be adding 2160P@24,25,30 fps 4:2:2 10bit and 12bit option in the next version.
A bientot
A bientot
- OlivierQC
Quelle est cette option dont tu parles?
- nnay07
roromimi a écrit:Yomeee a écrit:Bonsoir
J'ai testé cette démo 4K sur mon Panasonic EZ950. Je suis peut-être miro mais je ne vois vraiment pas de bandes comme tu dis.
- Christobald1971
- Inscription Forum: 24 Fév 2011 19:13
Je ne suis pas le seul à constater cet effet de banding .
Mukamil (quelques post plus haut) constate ces bandes même s’il les trouve atténué avec le dernier FW.
Tv Samsung 49MU 7055 + ampli pioneer VSX 933.
- roromimi
Les gars, si vous voulez on peut rappeler piou pour qu il vous mette d accord....
- nnay07
Malgré la dernière mise à jour, j'ai toujours ce problème d'effet "négatif"
- bakaman
- Inscription Forum: 16 Juin 2018 22:53
