Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Jeyaan, jpvoit, kaminka, kamuel, MB-Premier, mikematrix, pasender, roonie, sgtbauerfr, zeh et 408 invités
Denon AVR-1912
Manifestement, la nouvelle collection d'ampli Denon arrive selon quelques informations glanées sur les forums de nos amis nord américains.
Parmi les nouveautés, on peut noter l'arrivée d'un port ethernet sur la gamme 19xx.
DENON AVR-1912. 529$
90 watts per channel x 7 channels 8 ohms
6 HDMI inputs, 1 output, HDMI 1.4a includes 3D pass-through compatibility and ARC
Decoder that supports Dolby TrueHD, the audio format of Blu-ray disc players, and DTS-HD Master Audio, another high-grade digital audio format
Direct play for iPod and iPhone via USB
GUI overlay on HDMI Source
Internet Radio and network audio / photo streaming via Ethernet
Supports “Denon Remote App” to simplify operation by an iPhone / iPod touch
Supports AirPlay
Pandora, flickr, Napster and Rhapsody online support
Audyssey MultEQ® and Auto Setup
Fully Discrete, Identical Quality and Power for all 7 Channels (90 W x 7 Channels)
- To reproduce the original surround sound, each of the AVR-1912's 7 channels is equipped with the same power amp of equal power
- Power amps also use discrete circuits configured with parts strictly selected for their contribution to high sound quality, rather than with low-cost integrated circuits (ICs), the surround sound playback is of impeccably high quality
Featuring 3D Pass-Through Technology
- By connecting a 3D-complaint Blu-Ray disc player and 3D-compliant TV to the AVR-1912, you will have a 3D home theater where you can enjoy high-definition sound and video on a level you've never experienced before
High-Definition Audio Support
- The AVR-1912 has a decoded that supports Dolby TrueHD, the audio format of Blu-ray disc players, and DTS-HD Master Audio, another high-grade digital audio format
Dolby ProLogic IIz
- Dolby ProLogic IIz processor provides an even richer spatial expression
- Connecting front height speakers and suing Dolby Pro Logic IIz playback, you will be able to enjoy surround sound in the vertical as well as horizontal direction
Minimum Signal Path for Clear Audio and Video Signal
- "Simple and Straight" design concept has been thoroughly implemented in the single paths to contribute to immaculately clean audio and video playback
- Signal paths are as short as possible to keep signal degradation in the audio and video circuitry to an absolute minimum
Direct Mechanical Ground Construction, Embodying Concepts for Thorough Vibration Resistance
- Vibration-Resistance Construction has been reviewed has been reviewed to thoroughly suppress the adverse influences of vibration on sound quality
- The power transformers, a source of vibration, have been securely mounted on the highly rigid bottom chassis
- Direct mounting of feet to the radiator in near proximity to each other serves to suppress mutual vibration with the power transformers and other sources of vibration
Direct Play for iPod and iPhone via USB
- Listen to music files from iPod by connecting it to the AVR-1912's USB port with the iPod's USB cord
- To begin play, press iPod "Play" button on the AVR-1912 or remote control
- Digital signals from the iPod are transmitted as is to the AVR-1912 where they pass through the compressed audio restorer and processed by advanced audio circuitry to produce a clean, high-quality sound
Internet Radio and Network Audio/Photo Streaming via Ethernet
- AVR-1912 can play audio files and still images such as photographs that are stored on a computer
- Listen to internet radio and a host of other on-line music sources that use network technology
- AVR-1912 also supports AirPlay that lets you stream your music library from an iPhone, iPad, iPod touch or iTunes
Power Amp Assign function, for Versatility in Using the AVR-1912 for Different Purposes
- AVR-1912 Supports up to 7.1 Channels (FL/FR/C/SL/SR/SBL/SBR/SW) for surround playback designed by Blu-ray disc format
- Surround playback with Dolby Pro Logic IIz provides the ability to reassign power amp from the two surround back channels, to the front height channels
- Assign SBL/SBR power amp to Zone 2 for multi-room audio playback or to achieve higher-quality sound for 2-channel stereo playback
- AVR-1912 can be configured for front bi-amp operation
Ease-of-Use
- Setup Wizard provides easy-to-follow setup instructions
- Easy operation with Graphical User Interface
- GUI overlay on HDMI source
- Pre-memory remote control handset with Glo-Key
- Remote Setup guidance
- Auto surround more
- Sleep timer function
- Audio Delay function (max 6 frames for 200 msec)
- Muting level settings
- Audio level memory capable of correcting different signal levels for each input device
- Variable subwoofer crossover switching
Supports AirPlay
Dolby ProLogic IIz
Ease-of-Use
- Lo.
- Inscription Forum: 20 Juin 2010 20:53
j'aime bien sa tronche
plus classe je trouve....
529$ cela va faire un bon 600/700€ nan??
- le-chouby
- Inscription Forum: 24 Avr 2010 11:32
le-chouby a écrit:j'aime bien sa tronche
Euh c'est pas des livres mais des dollars, donc 371,6585 euros au dernier cours, mais de toute façon, comme d'hab on payera surement 600 euros à son arrivée
c'est vrai qu'il a une belle gueule
on a rien sur la puce toujours ABT 2015 ?
- redcarla
- Inscription Forum: 01 Juin 2009 14:06
faudrait un bon death match entre lui et le 609 de chez Onkyo
tous les deux résaux,
- le onkyo embarquant carrement l'interface spotify ( mais faut l'abo a 10€/mois merci !!)
par contre le Denon couvre l'Airplay ( immense !) on peut lire notre biblio Itunes directement sur le denon ou encore balancer la sauce de l'iphone/ipod sans fil !
- meddyb
- Inscription Forum: 31 Oct 2007 10:43
TARIF PROBABLE 699 EUROS COMME LE 609
- hdphile94
- Pro-Commercant.
- Inscription Forum: 26 Avr 2010 14:31
On trouve déjà le 609 à 529, 00 liv ré
- redcarla
Je ne connais pas la puce présente dans le 1912 mais la QDEO du 609 apparait au dernier test incroyable
- redcarla
le DENON AVR1912 est annoncé en France pour juin
- hdphile94
- Pro-Commercant.
Je reviens sur la QDEO, apparemment, premiers essais du 609 et premiers bugs, ça parle sec de mise à jour
- redcarla
Bah.....Onkyo................................ ...........bof
- pheno
- Inscription Forum: 30 Déc 2009 0:49
ah pheno et son prosélytisme DENON
- redcarla
Voilà les petits nouveaux :
http://usa.denon.com/us/Product/Pages/P ... aae60e0bdd
- gab2006
- Inscription Forum: 11 Avr 2006 16:23
redcarla a écrit:ah pheno et son prosélytisme DENON
C'est trop bon Red !
- pheno
M'enfin, je tiens à préciser que Pheno n'a rien à voir dans mon choix d'un DENON, on pourrait croire que j'ai adopté un certain mode de pensée que je qualifierais d'unilatéral manquerait plus que je je me "focalise"
- redcarla
