Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: kamuel, polo2121 et 393 invités
MARANTZ 2015-2016 : SR-5010/SR-6010/SR-7010
Ben vu qu'il a ce souci d'enceinte mais qu' il est encore sous garantie, je l'ai revendu à un magasin pour 400 euros.
- oli40000
- Inscription Forum: 25 Juin 2012 0:26
bonjour,
mon ampli m' a proposé une mise a jour ce soir quelqu'un a t il une info sur le contenu de cette maj ?
- 6gex
- Inscription Forum: 26 Déc 2010 10:22
Le changelog des versions:
Changelog of SR7010
last updated:- 21/07/2017
Firmware Vers: 0992-9380-9220-04 (MZ16-031,SR7010/ N1B, N1SG, T1SG, N1SG)
21/07/2017
1) The next song set to Cue does not automatically play even if the customer plays
Spotify Connect and then sets the next song to Cue.
1-1) Playback the one song.
1-2) Add the next song title to Que.
1-3) The playback of music stops after finishing Playback of 1st title.
The symptom is a problem that the next song set to Cue does not automatically
play.
2) The video from the PlayStation 2 connected to the component input of the AV
receiver becomes invisible when activating the menu of the PlayStation 2.
The symptom is that the picture disappears when the PlayStation 2 menu is
activated.
Filename:- USB_SR7010N_CY920_100100430200-0006.zip
24/11/2016
Firmware Vers: 0992-5370-9251-04
1) Add the Cross up-mixing feature.
2) The customers not being able to login to the Pandora service from the product.
3) When the language setting of the unit is of Polish, the erroneous information is displayed in the Information screen OSD if the Dynamic EQ is set to ON.
4) German-specific text characters are not displayed correctly when the customer plays a specific IR station (Fritz vom rbb 102,6 "Fritz - Und das hört man") in Germany.
Filename:- USB_SR7010N_CY920_100100430200-0004.zip
19/07/2016
Firmware Vers: 0882-7271-9225-04
1) When customer connects the AV receiver with the specific BD player (Sony BDP-CX960 and Sony CX-7000 Blu-ray Jukebox) via the HDMI and playback the contents of "DTS-HD", the AV receiver doesn't recognize the audio of "DTS-HD". Therefore, the specific BD player outputs the audio signal with Multi ch PCM.
The symptom is a problem that the "DTS-HD" format signal is not output.
2) In a network environment in which AV receiver is connected, the network module of the AV receiver reboots when Netflix APP starts on the iOS device.
The symptom is a problem that the network module of the AV receiver reboots when Netflix APP starts on the iOS device.
3) The audio intermittently becomes interrupted when HD cable TV program switches from DD with DSU to PCM based commercial using Dolby Surround.
The symptom is a problem that the audio intermittently becomes interrupted when HD cable TV program switches from DD with DSU to PCM based commercial using Dolby Surround.
4) When the customer receives a specific Internet radio station (Radioeins), the product does not display (German letters) on the display.
The symptom is a problem that the product do not display (German letters) on the display.
5) The Test tone sound of Height/Wide/Back are output to the SubWoofer1 when the customer executes Manual Test Tone with specific Sound mode (Dolby Surround).
The symptom is a problem that the Test tone sound of Height/Wide/Back are output to the SubWoofer1.
6) When the customer plays a specific file by USB Memory device, the track name is changed one after another in 25 seconds. (File that the number (01 and 02, etc.) are recorded at the beginning of the name.)
The symptom is a problem that the track name is changed one after another in 25 seconds.
7) When the customer inputs the 2ch audio signal with the following specific condition to the AV receiver, the Center channel output signal is distorted.
Sound mode: DTS Neural:X
Input signal: amplitude = over 440mFFS (40% vs full scale) and frequency= 720Hz / 2.7~4.1kHz
The symptom is a problem that the Center channel output signal is distorted by the specified condition.
When the customer switches the sound mode from the marantz Remote App, the following failure occurs in the AV receiver.
Example:
The sound mode becomes the "Dolby Surrouds" even if the customer selects the "DTS Neural:X" in the sound mode.
The sound mode becomes the "DTS Neural:X" even if the customer selects the "Dolby Surrouds" in the sound mode.
The symptom is a problem that the sound mode is not correctly selected even if the customer selects the sound mode.
9) When the black hole router was present between the Internet environment of the AV receiver and DPMS server (including the Internet service provider side equipment), the AV receiver might fail in the firmware update. (The black hole router is a router that destroy it when the divided IP packet cannot be forwarded.)
10) Only when 4K contents (UHD BD) are played, the image becomes a striped pattern in the tone of brightness and darkness.
UHD BD title:
The Revenant:scenes where Tom hardy grabs gun of young lad.
Miyakojima-Beach of healing-VUB-5702: the sunset scene.
The symptom is a problem that the image becomes a striped pattern in the tone of brightness and darkness.
11) The unit playback the same track a number of times during random playback of WAV files from the USB memory device.
The symptom is a problem that the unit playback the same track a number of times.
Filename:- USB_SR7010N_CY920_100100430200-0003.zip
03/03/2016
Firmware Vers: 0772-9111-9231-04
1) Add the "DTS: X" sound mode feature.
2) When the customer connects the AV receiver to MAC Book laptop PC and then the specific MP3 music file (Album art size is bigger than 1000 x1000 pixels) is played on the iTunes via AirPlay, the AV receiver reboots before starting the playback of the MP3 file.
The symptom is a problem that the AV receiver reboots before starting the playback of the MP3 music file.
Filename:- USB_SR7010N_CY920_100100430200-0002.zip
Changelog of SR7010
21/07/2017
play.
activated.
24/11/2016
19/07/2016
Example:
UHD BD title:
03/03/2016
- patoun
- Inscription Forum: 11 Sep 2002 0:21
Je possède un Marantz SR6010 (que j'adore), a toujours fonctionné en 5.1.2 sans souci.
Puis je me suis dit que j'allais passer à l'étape supérieure en passant au 7.1.2 ... et me rends compte que pour en profiter il faut que j'ai un amplificateur de puissance pour les 2HP Atmos ?
En faisant des essais avec les modes "VIDEO", soit j'ai du 7.1 (sans Atmos) soit 5.1.2 (avec Atmos), donc à priori d'origine il ne permet pas le 7.1.2 si j'ai bien compris.
Je trouve dommage d'avoir un 2ème ampli nécessaire pour ces petits HP Atmos qui ne demandent pas grand chose ...
J'ai bien compris qu'il faille brancher en RCA un amplificateur sur les "heights", mais quel ampli me conseillerez-vous ?
Merci d'avance
Merci d'avance
- Jayce68
- Inscription Forum: 10 Mar 2014 18:59
Ben bah...Voila...Adieu Marantz...J'ai eu un avoir pour mon ampli après 3 retours SAV infructueux.
Je suis passé à la concurrence...Un Onkyo RZ810.
Adieu mes amis!! Et bon courage.
- Nexys
- Inscription Forum: 08 Juil 2016 20:27
Jayce68 a écrit:Bonjour à tous,
Merci d'avance
L'ampli supplémentaire n'est pas forcement branché sur les enceintes Atmos
Tu peut tout a fait prendre un bon ampli de puissance adapté a tes frontales puis les alimenter, les Atmos seront alimentées par l'ampli
Juste un reglage a faire dans le menu ...
- pasender
Nexys a écrit:Ben bah...Voila...Adieu Marantz...J'ai eu un avoir pour mon ampli après 3 retours SAV infructueux.
Moi j'ai changé mon 6011 par un 7011 depuis quasi 1 mois et aucuns soucis.
- oli40000
Merci d'avance
prends toi un bloc de ce style et tu vas passer dans un autre monde!!!
achat-ampli-blocs-home-cinema/bloc-rotel-rmb-1077-7-canaux-ice-power-2-cadeaux-t30080776.html
- oolivier
- Inscription Forum: 18 Fév 2006 17:43
Merci Oolivier
Malheureusement c'est hors budget.
Sinon autre question avec le SR6010, est-ce qu'il n'est pas possible de gérer la puissance de 4 sorties (genre Atmos + Surround back) par un amplificateur intermédiaire en Pre-out, et le reste + bi-amp des fronts avec le SR6010 ?
Je suis en configuration 7.1.2 (7.1 + 2 atmos)
- Jayce68
alors déja tu dis hors budget et après tu parles de rajouter un ampli intermediaire, cad ????, et plutot que de passer tes enceintes en biamp que t entendras meme pas la diff surtout avec la partie ampli du 6010 , prends toi un ampli 5 canaux d occaz pour les 5 enceintes principales y en a à 500 e dans les pa ,
par exemple!!!!
achat-ampli-blocs-home-cinema/rotel-rmb-1565-t30080122.html
pas trop gros consomme rien ne chauffe pas et une patate d enfer, je sais j ai le meme
par exemple!!!!
- oolivier
oolivier a écrit:alors déja tu dis hors budget et après tu parles de rajouter un ampli intermediaire, cad ????, et plutot que de passer tes enceintes en biamp que t entendras meme pas la diff surtout avec la partie ampli du 6010 , prends toi un ampli 5 canaux d occaz pour les 5 enceintes principales y en a à 500 e dans les pa ,
par exemple!!!!
Oui désolé j'ai oublié de préciser. Il me restait un intégré 6.1 Yamaha RXV459 qui du coup me sert d'ampli externe (Pre-Out), pour mes 2 Atmos, en attendant de trouver mieux.
- Jayce68
Bonsoir a Tous. Voilà un petit moment que je n'ai pas posté sur le forum. Je voulais juste vous signaler que j'ai réussi a me faire échanger un SR 6010 suite a mes problèmes de diminutions de sons sur mes enceintes.
Bilan pour Marantz:
*SAV inexistant car pour faire du fric cette marque délègue le tout a des prestataires.
*Panne non franche sur l'appareil mais vraiment frustrante ( très difficile a faire reconnaitre lors d'envoi a des SAV car les magasins test avec des enceintes bas de gamme)
*interface des APPLIS ou menu dépassé de 20ans
C'est vrai que les caractéristiques des appareils ne laisse pas de futur client indifférent mais je vous aurais prévenu la fiabilité n'est pas au rendez vous.
Aujourd'hui je m'oriente vers un Yamaha RX A 3060
Bye bye Marantz et bon courage a tous ceux qui ont le même default.
Bilan pour Marantz:
- Golgoth_Valhalla
- Inscription Forum: 08 Déc 2016 10:15
rassure toi : mon ex Yamaha a été réparé par un prestataire, et c'est presque mieux, s'il n'habite pas trop loin. Mon Marantz a aussi eu un pb de hdmi, il était sous garantie, il a été correctement réparé, mais peut-être un détail qui explique le "long fleuve tranquille" : je l'ai acheté par une grande enseigne. Hors enseignes ... il se peut que les clients en bavent!
- Mpeg
- Inscription Forum: 15 Avr 2005 13:47
Aucune marque n' est épargnée malheureusement .
- Chewee Levelu
- Inscription Forum: 25 Aoû 2010 9:38
Pour le souci de perte de son sur une enceinte, je me demande si au final ça ne viendrait pas d'un problème de chauffe de l'ampli.
Mon 6011 chauffait pas mal, et mon 7011 chauffe encore plus.
Le 7011 chauffe plus car plus haut que le 6011 donc moins d'espace dans mon meuble. Du coup j'ai fait sauter une tablette et j'ai agrandi l'ouverture à l'arrière. Maintenant c'est moche mais l'ampli chauffe beaucoup moins.
Je suis surpris que de telles "machines" ne disposent pas d'un refroidissement performant.
- oli40000
