Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: castil laurent, indianajones, redwan78 et 203 invités
Marantz VP12S2 ou un produit recent ?
Message » 02 Fév 2009 11:57
Bonjour a tous,
J'ai la possibilité d'acquérir un vp Marantz vp-12s2 d'occasion (lampe de 410h d'utilisation) pour environ 650 euros.
Du très haut de gamme certes mais qui date quand même de 2003...
Je rappelle les caractéristiques :
Marantz - High-Definition DLP™ Front Projector
Specifications
Digital Light Processing Texas Instrument Digital Light Processing™ Technology
DMD Type 1280 x 720 HD2 "Mustang" Chipset
DMD Size 0.85 Inch 16:9
HD Formats Compatible with all 18 ATSC formats
Lamp 150 watt SHP
Lens Structure Custom Optics by Minolta specifically designed for Marantz
Seal Cabinet Structure No Light Leakage (Double Sealed Cabinet Structure)
Construction Diecast chassis with completely sealed light path
Long Life Lamp Average 2000 Hours
Aspect Ratio 16:9
Contrast Ratio 2600:1
Brightness 700 ANSI Lumens
Lens Throw Distance Short (~2.6 to 3 x Pic height), Long (~4 to 5.5 x Pic height)
Projection Size 40 to 250 inches
Light Output 700 ANSI LUMENs (MAX)
Operating Temperature 5°C to 35°C
Operating humidity 30% to 85%
Features
3:2 Pull Down Yes
Progressive Scan Yes
Gamma Processing 10-Bit
Keystone Correction Yes
PC Signal VGA, SVGA, XGA, SXGA
Picture Modes Theater, Standard, Dynamic, User
Picture Memories 12
Aspect Modes 4x3, 16x9 anamorphic, 16x9 letterbox, pixel for pixel (thru)
Color Temperatures Low, Middle, High
Black Level Selection 0 IRE, 7.5 IRE
System Control RS232C or RC-5
Connectivity
Composite Video In 1 (RCA)
S-Video In 1 (4-pin mini DIN)
Component In 1 (3 x RCA)
RGB/HD In (VGA D-Sub 15)
AUX DV i.link In DVI w/HCDP replaces IEEE1394
RS232C 1 (D-Sub 9)
DC Trigger Out 2 (3.5 mm mini jacks)
RMC In 1 (3.5 mm mini jack)
RMC Out 1 (3.5 mm mini jack)
Accessories
Lens Cap 1
Control Adaptor Cable 1 (Mini Jack To RCA)
Ferrite Cores 2
General
Color Charcoal Grey/Violet
Chassis Diecast Metal
Remote Control RC-12VPS2
Power Requirement AC 100-120 V/ 220-240 V, 50/60 Hz
Power Consumption <250 W
Standby Consumption <3.3 W
Dimensions Inch (W x D x H) 15 15/16" X 18 9/16" X 5 3/16"
Feet Adjustment 5/8" x 2 7/16"
Weight 26.1 lbs.
De l'autre cote, je me suis penché sur les appareils neufs pour comparer les prix et on peut trouver de bon produits dans les 700-900 euros (donc pas une énorme différence face au Marantz) tel que Sanyo PLV-Z5, Epson EMP-TW680 et 700, Panasonic PT-AX200, Optoma HD75...
Donc question : Que choisir ? Le matériel haut de gamme de 2003 est-il mieux que du milieu de gamme actuel ?
Si oui, est-ce que 650 euros est un bon prix ? si non, combien ?
Si non, quel modèle choisir entre les vp HD ready ?
Merci d'avance
Gwen_
Inscription Forum: 02 Fév 2009 11:26
Message » 02 Fév 2009 12:27
NON
prix de la lampe :(
etc...
2003 déjà :roll:
cricri67
Inscription Forum: 17 Jan 2003 1:01
Message » 02 Fév 2009 13:30
je sais que le sanyo z5 a pas une lampe beaucoup moins cher non plus... (pour les autres je pense qu'effectivement c'est moins cher mais je sais pas exactement de combien)
Gwen_
Message » 03 Fév 2009 14:33
Je tourne toujours avec mon VP12S2 de 2003 et j'ai toujours autant de plaisir. C'est certain qu'un HD350 ou d'autres font mieux mais je n'ai rien à lui reprocher pour une salle dédiée. Par contre à ta question de le prendre d'occasion sache qu'effectivement le prix de la lampe est monstrueux (750-800€) et que sa fiabilité (de la lampe) est toute relative. Mais ca reste un magnifique appareil (optique Minolta, construction solide...)
Surge
Inscription Forum: 10 Jan 2009 23:19
Message » 04 Fév 2009 16:53
Merci Surge
Et justement, selon toi, est-il meilleur qu'un milieu de gamme HD ready style Sanyo Z5 ou Epson TW700 ?
Quelle est la qualité de son rendu sur des sources SD ? (meme si ca depend aussi du lecteur bien sur)
Pour la lampe, il reste encore 1590h theorique de lampe soit grosso modo 4 ans... Je sais également que le prix de la lampe fait assez mal 770€ mais au final, aurai-je vraiment besoin d'en racheter une ? D'ici 4 ans, les produits auront évolués, les prix auront évolués, je me dis que pour 770€ j'aurai probablement un produit plus performant que ce Marantz (en espérant que la lampe ne claque pas à 1000h bien sur :D), non ?
Gwen_
Message » 04 Fév 2009 17:31
Je suis un peu dans le même cas que toi (Sharp XVZ1000, qui doit être de 2003 ou 2004), et je te garantis que l'image est sans commune mesure avec un entrée de gamme plus récent. L'optique de ces bestiaux haut de gamme fait une vraie différence en matière de piqué, et si les innovations électroniques se sont démocratisées (un Z5 par exemple doit être effectivement comparable en matière de traitement), un bon objectif reste toujours cher.
Après reste la question du prix de la lampe effectivement.
Mais pour moi le match ne se joue qu'avec un full HD, et il y a encore une grosse différence de budget (snif...). Ces gros projos d'il y a 5 ans sont a priori d'excellentes affaires pour leur prix.
Sur les DVD j'ai eu plusieurs echos comme quoi le mien restait supérieur à pas mal de full HD 1ère génération. Et sur les BR et HD-DVD même si je ne vois que la moitié des pixels il y a déjà une énorme différence avec les DVD (richesse des couleurs, contraste...) et sur une base de 2,40 c'est déjà magnifique avec une bonne source.
petitrex
Inscription Forum: 06 Avr 2005 21:31
Message » 04 Fév 2009 18:12
Gwen_ a écrit:Bonjour a tous,
Merci d'avance
N'hésite pas une seconde à ce prix. Ou plutôt si, car ça semble un peu trop beau... :wink:
Sinon comme l'on fait remarqué les autres forumeurs, le prix de la lampe est très élevé et la durée de vie théorique... toute théorique. Donc à prendre comme un VP jetable en quelque sorte. Mais tu auras une qualité d'optique sans commune mesure avec les VP à bas prix du moment. Si c'est un premier VP, c'est une bonne entrée en matière.
BradPitt
Inscription Forum: 15 Déc 2005 18:23
Retourner vers Projecteurs HD
