J'ai la possibilité d'acquérir un vp Marantz vp-12s2 d'occasion (lampe de 410h d'utilisation) pour environ 650 euros.
Du très haut de gamme certes mais qui date quand même de 2003...
Je rappelle les caractéristiques :
Marantz - High-Definition DLP™ Front Projector
Specifications
Digital Light Processing Texas Instrument Digital Light Processing™ Technology
DMD Type 1280 x 720 HD2 "Mustang" Chipset
DMD Size 0.85 Inch 16:9
HD Formats Compatible with all 18 ATSC formats
Lamp 150 watt SHP
Lens Structure Custom Optics by Minolta specifically designed for Marantz
Seal Cabinet Structure No Light Leakage (Double Sealed Cabinet Structure)
Construction Diecast chassis with completely sealed light path
Long Life Lamp Average 2000 Hours
Aspect Ratio 16:9
Contrast Ratio 2600:1
Brightness 700 ANSI Lumens
Lens Throw Distance Short (~2.6 to 3 x Pic height), Long (~4 to 5.5 x Pic height)
Projection Size 40 to 250 inches
Light Output 700 ANSI LUMENs (MAX)
Operating Temperature 5°C to 35°C
Operating humidity 30% to 85%
Features
3:2 Pull Down Yes
Progressive Scan Yes
Gamma Processing 10-Bit
Keystone Correction Yes
PC Signal VGA, SVGA, XGA, SXGA
Picture Modes Theater, Standard, Dynamic, User
Picture Memories 12
Aspect Modes 4x3, 16x9 anamorphic, 16x9 letterbox, pixel for pixel (thru)
Color Temperatures Low, Middle, High
Black Level Selection 0 IRE, 7.5 IRE
System Control RS232C or RC-5
Connectivity
Composite Video In 1 (RCA)
S-Video In 1 (4-pin mini DIN)
Component In 1 (3 x RCA)
RGB/HD In (VGA D-Sub 15)
AUX DV i.link In DVI w/HCDP replaces IEEE1394
RS232C 1 (D-Sub 9)
DC Trigger Out 2 (3.5 mm mini jacks)
RMC In 1 (3.5 mm mini jack)
RMC Out 1 (3.5 mm mini jack)
Accessories
Lens Cap 1
Control Adaptor Cable 1 (Mini Jack To RCA)
Ferrite Cores 2
General
Color Charcoal Grey/Violet
Chassis Diecast Metal
Remote Control RC-12VPS2
Power Requirement AC 100-120 V/ 220-240 V, 50/60 Hz
Power Consumption <250 W
Standby Consumption <3.3 W
Dimensions Inch (W x D x H) 15 15/16" X 18 9/16" X 5 3/16"
Feet Adjustment 5/8" x 2 7/16"
Weight 26.1 lbs.
De l'autre cote, je me suis penché sur les appareils neufs pour comparer les prix et on peut trouver de bon produits dans les 700-900 euros (donc pas une énorme différence face au Marantz) tel que Sanyo PLV-Z5, Epson EMP-TW680 et 700, Panasonic PT-AX200, Optoma HD75...
Donc question : Que choisir ? Le matériel haut de gamme de 2003 est-il mieux que du milieu de gamme actuel ?
Si oui, est-ce que 650 euros est un bon prix ? si non, combien ?
Si non, quel modèle choisir entre les vp HD ready ?
Merci d'avance
