Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 10 invités
Discussion sur les amplis et blocs de puissance multi-canaux pour le HomeCinéma
avis ampli t.amp s150 mk2
C'est quand même dingue que le fabricant sabote à ce point la fabrication de cet ampli!
- aurel
R125,R179,R180,R126
These resistors are too hot.
These resistors look like the current limiting resistors in the power supply circuit
that make positive and negative 12V from the positive and negative 50V of the output stage.
It is a waste to convert the power of the power stage into heat and throw it away, so
I removed these resistors and tried to supply power independently with a regulated power supply
composed of LM317 / LM337. Then, the sound quality became very good.
The sound quality has entered a new stage due to the synergistic effect of adjusting the bias current and changing the internal speaker wiring,
which we learned from the Forum here.
thank you everyone!!
paysage de travail. https://youtu.be/w_mXAEDKspc
- nightwish_daisuki
- Inscription Forum: 12 Mai 2021 18:06
If a resistor is added to prevent hum noise, it is better to increase the capacity of the electrolytic capacitor.
However, it is difficult to work with because removing it will break the through hole.
I soldered both the front and back of the board.
The electrolytic capacitor in this place has a great influence on the sound quality.
The withstand voltage of this electrolytic capacitor must be 63V or higher.
The distance between the terminals of the electrolytic capacitor is 5 mm.
The thickness of the lead wire of the electrolytic capacitor is 0.6 mm.
The blue electrolytic capacitor in the picture has a withstand voltage of 50V, which is a bad choice.
https://youtu.be/yd1P7zKhcnQ
- nightwish_daisuki
Hello ici
J’ai craqué !!! je me suis pris enfin ce fameux s 150 MKII. Et ben il est pas dégueux du tout !!! On l’a branché sur mes Triangle Antal, en H.C ça dépote, en hifi il sait se tenir. Je ne lui demande non plus d’être aussi précis que du haut de gamme faut pas exagérer mais pour le tarif, c’est top.
En revanche, j’aurai besoin de conseils pour son petit frère le s 75 MKII. On l’a mit en bridge pour la voie centrale et comme ça j’ai 150w sur chaque canal. Sur le 75 j’ai beaucoup de souffle. Auriez-vous des solutions pour enlever ce maudit souffle ?
Je vous remercie.
Je vous remercie.
- nealite56
- Inscription Forum: 16 Nov 2008 13:14
nealite56 a écrit:Hello ici
Je vous remercie.
D’après les retours lus ça et la, il serait déconseillé de bridger ces amplis pour la centrale, laisse ta centrale branchée sur une des 2 sorties et voit si cela résoudra le problème
- damdam95
- Inscription Forum: 26 Sep 2005 22:20
damdam95 a écrit:nealite56 a écrit:Hello ici
Je vous remercie.
Merci de ton conseil. Quand je pourrais je ferais l'essai.
- nealite56
If the yellow led comes on and there is no sound, you may have misconnected the speakers.
In the bridge connection, the two black terminals of the speaker terminal do not connect anywhere.
Do not use bridge mode with speakers with an impedance of 4Ω or less.
This is because the speaker impedance is equal to half in bridge mode.
The S-75mk2 does not support driving 2Ω speakers.
Never connect the outputs of two amplifiers. The amplifier will fail.
(I've heard reports that both 'AV amplifier' and 'Pure audio amplifier' were connected to the same front speakers.)
If the red led turns on and there is no sound, the amplifier is in sleep mode.
If you do not want to use sleep mode, set the ERP switch to the OFF position.
The ERP switch is located on the back panel of the amplifier. This did not exist in the early models.
- nightwish_daisuki
nightwish_daisuki a écrit:If the yellow led comes on and there is no sound, you may have misconnected the speakers.
Do not use bridge mode with speakers with an ipedance of 4Ω or less.
Merci. J'ai remis en 8 ohms mon Marantz.
- nealite56
Bonjour, je vais en acheter 3 pour mettre sur préampli marantz. Est ce qu on peut superposer les blocs ? Il y a des pieds qui les espaces ? Merci
Image : LG G1 77 pouces,
Son : marantz 8015, 2 kef ls50, 1 kef r2c meta, 2 surround cabasse Eole4, 1 sub rel 1508 predator, un arendal 1961 1s
Source panasonic 820
- fredz1432
- Inscription Forum: 04 Fév 2011 10:13
fredz1432 a écrit:Bonjour, je vais en acheter 3 pour mettre sur préampli marantz. Est ce qu on peut superposer les blocs ? Il y a des pieds qui les espaces ? Merci
Oui, mais certains les ont remplacés pour augmenter un peu cette hauteur afin d'améliorer la dissipation de chaleur.
- téachix
- Inscription Forum: 12 Déc 2003 12:37
téachix a écrit:fredz1432 a écrit:Bonjour, je vais en acheter 3 pour mettre sur préampli marantz. Est ce qu on peut superposer les blocs ? Il y a des pieds qui les espaces ? Merci
Merci pour ta réponse.
- fredz1432
Ceux-ci devraient être parfait :
https://www.amazon.fr/perfk-Caoutchouc- ... 08&sr=8-46
- téachix
Une autre question, est ce qu il y a intérêt à passer sur le 100 en le bridgeant. Trois 100 sur mes avants au lieu de deux 150. Je me dit si en cas de panne je peut me dépanner en debridgeant les deux autres, je vais peut être gagner en pêche tout en sollicitant moins.
C est pour alimenter un pack d500 jamo, donc couper a 80 et dans une pièce de 20m2.
- fredz1432
J’hésite à remplacer mon atoll av500 par se bloc pensais vous qu’il y aurai un gain?
Je trouve un peu mou l’atoll sur ma centrale et pas envie pour l’instant de me ruiner dans un gros bloc.
J’utiliserai les bloc juste pour la centrale et les surround.
- kenpachi672
- Inscription Forum: 07 Avr 2013 19:16
kenpachi672 a écrit:Bonjour,
Slt, tu peut en acheter un, l essayer sur ta centrale, ça va tu le garde sinon tu le renvoi. Tu as 30 jours sans justification chez Thomann.
- fredz1432
Retourner vers Amplis de puissance HomeCinéma
