j'ai lu à gauche et à droite (surtout ds la NRDS) que Kef va proposer prochainement de nouveaux caissons. est ce que qq'un a des infos ? le PSW4000 va t il etre bientot changé ? si oui, quand ?
j'ai deja vu qu'il y avait le PSW2010 (remplaçant du PSW2000) et le 3010 ou 3500 (remplaçant du PSW3000). merci de me repondre !
2 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: julien0810, petesburne et 136 invités
besoin d'info sur les nouveautés Kef...
- Terry
J'ai trouvé ceci mais ce n'est pas récent
"Following is the brief press release from KEF on two of its new subwoofers...
”KEF has announced the introduction of two all-new subwoofers; the PSW2500 and PSW5000. Both speakers will integrate perfectly into KEF's existing product range or will perform impressively and stylishly as stand-alone powered sub-woofer systems in any audio-video set-up.
The moderately priced PSW2500, designed with the highly acclaimed KEF Q Series in mind, has a distinctive curved shape (to match the Q range) and comes in matching finishes. The larger PSW5000 lends itself easily to KEF's mighty Reference Series, being a solid and very powerful performer in its own right. It is also available to match the Reference Series finishes.
KEF PSW2500
Powered Subwoofer
Closed Box
Ground lift switch
Music/Cinema switch
12dB/24dB selectable low pass filter
Variable Frequency, Phase and Level
10" (250mm) Bass Unit
30Hz - 140Hz (freq response)
250Watt (on-board amplifier)
108dB (maximum output)
Weight - 14.5kgs (31.9lbs)
Available in Maple, Dark Apple and Black
PSW5000
Powered Subwoofer
Reflex Design
Ground Lift facility
Music/Cinema switch
Balanced and phono inputs
Dedicated LFE input (balanced and phono)
Class 'D' High efficiency amplifier section
Switch mode power supply
RF remote controlled Frequency, Phase and Level
15" (380mm) Bass Unit
18Hz - 250Hz (freq response)
1000 Watt (on-board amplifier)
118dB (maximum output)
Magnetic shielding
Weight - 60kgs (132lbs)
Available in Maple, Cherry and Black Ash real wood veneers
Prices
PSW2500 (INCLUDING VAT): £349.99 EACH
PSW5000 (INCLUDING VAT): £2499.99 EACH
Thierry
KEF PSW2500
Powered Subwoofer
Closed Box
Ground lift switch
Music/Cinema switch
PSW5000
Powered Subwoofer
Reflex Design
Music/Cinema switch
Magnetic shielding
Prices
Thierry
- Thierry Wautelet
- Inscription Forum: 29 Juil 2000 2:00
2 messages
