Salut tout le monde,
D-750, une vraie centrale
PERFORMANCE
Recommended amplifier power 30 - 200 Watts RMS
Continuous power handling 125 Watts RMS
Sensitivity 90dB (2.8Volts @ 1 metre)
Nominal impedance 6 Ohms
Frequency response 45Hz - 30kHz +/- 3dB
DRIVE UNITS
Dual ConcentricTM high frequency 25mm (1") with Tulip Waveguide
Dual ConcentricTM low frequency 200mm (8") polypropylene cone
Supplementary bass unit 2 x 200mm (8") polypropylene cone
CROSSOVER
Frequency 1.7khz Dual midrange to Dual high frequency 400Hz supplementary bass unit to Dual midrange
Type 1st order Dual high frequency 2nd order Dual midrange frequency 1st order supplementary low frequency
CONSTRUCTION
Enclosure type Closed box
Dimensions: H x L x P 238 x 824 x 400mm
Weight 33kg (72.8lbs)
Finish American cherry
DOWNLOADABLE FILES
Range brochure <http://www.cortex.westhost.com/tannoy/files/ACF24BA.PDF> English language - PDF Format
FEATURES
Fully magnetically shielded loudspeaker for use as the centre channel in a home cinema system.
Cabinet is lined with heavy gauge steel plate to ensure 100% magnetic shielding.
Rigid cabinet construction internally braced and filled with acoustic wadding to eliminate unwanted panel resonance.
Real wood veneers are carefully selected to co-ordinate with the floor-standing models.
Differential Material Technology (DMT) is employed throughout the loudspeaker design to provide enhanced control of drive unit energy.
Utilises a 200mm (8”) Tannoy Dual ConcentricTM point source, constant directivity driver technology providing exceptional dynamics, high power handling and reliability.
Driver technology is the same as is used in Tannoy professional studio monitors ensuring the same level of accuracy and performance demanded by studio engineers.
Precision injection moulded, graded thickness, mineral filled cones provide optimum rigidity ensuring exceptional bass control.
Huge magnet assemblies provide increased efficiency with enhanced dynamic range.
Copper clad edge-wound voice coils optimise the speed of response to musical transients.
Cast chassis drive unit frame eliminates resonance even at high power output levels.
Tulip wave-guide on drive unit for improved high frequency dispersion and pinpoint imaging accuracy.
Two supplementary 200mm (8”) low frequency drivers provide deep extended bass.
Fully bi-wired crossover for improved bass and treble performance.
buss
