Bonsoir ,
Je possède également un halo a-52 et j'en suis très satisfait . Un test en anglais de cet ampli qui est toujours dans le coup :
http://hometheaterreview.com/parasound- ... -reviewed/
Cordialement.
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 29 invités
Discussion sur les amplis et blocs de puissance multi-canaux pour le HomeCinéma
Amplificateurs de puissance Parasound
- Callahan
- Inscription Forum: 26 Nov 2005 11:15
Une petite info concernant le futur C3 sortie si tout va bien 1er semestre 2010
http://www.parasound.com/pdfs/C3.pdf
Et une petite lettre du patron de Parasound :
Update on Parasound’s New 7.1 Channel Surround Processors and Receiver.
From Richard Schram
December 8, 2009
Thank you for your patience. We’re moving forward steadily on the new C 3 and HDP-70 hi-def surround processors and the HDR-77 receiver. Their performance is already stunning. Many of you have asked why they are taking so long. To be blunt, we underestimated the technical challenges of getting HDMI 1.3 performance 100% correct and we apologize for the delays and frustration this has caused.
We will also subject our new 7.1 processors and receiver to a vigorous search and destroy mission for bugs and glitches. We’ll spend as much time as necessary until we’re satisfied that our customers won’t be involuntary guinea pigs and encounter faults we should have found. With this in mind, we’ve moved back our anticipated deliveries until the first quarter of 2010.
We’re taking advantage of the longer-than-expected development and refinement process to include a useful new feature into our new 7.1 channel models.
Dolby Volume
Dolby Volume addresses several annoying problems. First, Dolby Volume "evens out" the volume differences between channels or between programming and commercials. It also enhances your listening experience at low listening levels.
Dolby Volume
The Preferred Volume - All the Time
Wouldn't it be nice if you could set the volume on your TV once and never have to worry about it for the rest of the evening? Even commercials that normally blast you out of your seat would be toned down. And when you switch from watching TV to watching a DVD, the volume would stay the same. Impossible? Think again.
Dolby® Volume delivers a consistent volume to all your entertainment. It eliminates annoying volume differences, whether between TV shows and commercials or between different pieces of home theater gear. No more up and down with the volume control, no more frustration - just a more enjoyable, more immersing experience. Dolby Volume - you'll wonder how you ever lived without it.
Dolby Volume Benefits
Maintains the same volume level across all content, programs, and audio/video sources
Reproduces sound that's true to the original recording - at any volume level
Customizable to suit your personal preferences and listening conditions
Improves surround perception, even at low volume levels
Produces clear audio, with no unwanted noise
Dolby Volume Demo
Check out our Dolby Volume demo. For the best experience, make sure you are wearing headphones.
© Dolby Laboratories, Inc. Dolby Laboratories, Inc. Used with permission.
From Richard Schram
December 8, 2009
Dolby Volume
Dolby Volume
Dolby Volume Demo
- Mod2
- Inscription Forum: 28 Juil 2007 19:02
Où est-ce que l'on achète du Parasound en France ? Accessoirement en Europe, enfin en Euros ?
Je serais intéressé par un Halo P7 : http://www.parasound.com/halo/p7.php => un pré-ampli 7.1 entièrement analogique avec tout tout ce qu'il me faut !
Magnetar UDP800 / Lumagen Radiance Pro 4242 / JVC DLA-N7 / MicroPerf'Oray HD 4K / Anthem AVM90 / 9 x Focal SM6 Be & 1000 Be + 4 x Focal 300 / 2 x Subs DIY Beyma 18LX60 V1 / Amplis HPA / Etudes, traitements & calibrations pros
SYLEX - Membre HCFR Contributeur
- Inscription Forum: 11 Oct 2002 13:47
C'est la société AVgénération qui importe la marque. tu peux te renseigner auprès d'eux pour connaître un revendeur près de chez. il revendent peut-etre directement au particulier d'ailleurs.
http://www.avgeneration.com/
- LeCaribou007
- Inscription Forum: 20 Sep 2007 14:45
Que pensez vous du module PARASOUND ZHD, qui à priori ouvre les processeur de la marque au joies du HDMI!!!
- LINK1976
c'est un switch contrôlable par les processeurs de la marque. ca permet de brancher plusieurs produit hdmi sur un récepteur n'ayant qu'une seule entrée HDMI (projecteur video) ou alors de ne plus avoir a faire de sélection d'entrée sur une TV... etc... perso j'en pense pas grand chose si ce n'est qu'au moins il est au catalogue pour les possesseur de la marque qu'il veulent un switch. ca fait une télécommande de moins!
- LeCaribou007
Ok, je viens juste de me prendre un HALO C1, je ne connais ps du tout, je vais donc découvrir ce preampli, en ampli de puissance je cherche de preference un A51 pour mes ELECTRA, je vais voir, s'il y en a qui ont des retour concernant ce preamp je suis preneur!
- LINK1976
C1 + A51, tu vas avoir une belle config de ouf! bienvenue au club!
- LeCaribou007
Normalement , je ferais decoder les bandes son HD par la MARANTZ UD9004!
- LINK1976
Avgeneration n'est plus l'importateur de la marque en France.
Parasound a confié l'importation des ces produit à BMB electronics. (http://www.bmbelectronics.eu)
Olivier
B&W 804, 805, HTM1
Parasound C2/A52
Olivier
B&W 804, 805, HTM1
Parasound C2/A52
- tagh
- Inscription Forum: 27 Déc 2009 12:38
Re-bonsoir,
Je peux fournir les coordonnées mail du commercial de bmb en charge de la France par mp.
A votre dispo.
Olivier
B&W 804, 805, HTM1
Parasound C2/A52
A votre dispo.
Olivier
B&W 804, 805, HTM1
Parasound C2/A52
- tagh
Une idée sur la sortie du C3. Peut être que l'importateur BMB en sait un peu plus.
- Mod2
A mon avis Génération a fermé ses portes
http://www.avcesar.com/actu/id-3888/Scr ... z-B&W.html
c'était AVGénération qui importait ces produits aussi...
Je veux bien que tu m'envoie les coordonnées par MP de BMB.
- LeCaribou007
effectivement je viens de retrouver l'annonce:
http://www.bmbelectronics.eu/news_item.php?id=295
- LeCaribou007
En fait j'ai racheté du matériel Parasound appartenant à Avgeneration.
Olivier
B&W 804, 805, HTM1
Parasound C2/A52
Olivier
B&W 804, 805, HTM1
Parasound C2/A52
- tagh
Retourner vers Amplis de puissance HomeCinéma
