alex_t a écrit:Le 2020 n'a pas de sortie coaxiale, ni le même boitier (plus petit), pour le reste il est identique en tout point au 2021.
D'après mes lectures sur les docs du 2021, il serait en 125 points alors que le 2020 semble être en 729 points.
Extrait "2021 manual" :Key Features• Proprietary Lumagen No-Ring™ scaling
• Darbee Digital Visual Presence™ (DVP™) enhancement technology
• 10-bit processing for deinterlacing plus a 12-bit calibration pipeline
• Support for HDMI® 1.4 “3D” including anamorphic lens scaling
• Convert common optional 3D formats to a required 3D formats supported by the display
• Each input has 4 user configuration memories
• Each input user configuration memory has 8 resolution sub-memories (for HD inputs)
• Each resolution sub-memory is linked to one of 8 output configurations.
• 2:2, 3:2 and 3:3 pull-down for SD/HD film sources
• Per-pixel SD/HD video de-interlacing
• Adaptive diagonal filtering
• MPEG mosquito and block artifact reduction
• Temporal noise reduction for SD and HD sources
• Output resolution from 480p to 1080p, plus 1080i
• User programmable non-linear-stretch (NLS) mode
• 4:3, LBOX, 16:9, 1.85, 2.35 and NLS input aspect ratios
• Programmable output aspect ratio from 1.10 to 2.50
• Extensive support for anamorphic lenses for both 2D and 3D video
• Large suite of test patterns
• Parametric grayscale and Gamma calibration
Full CMS (Color Management System) using a 125-point 3D linear-gamma RGB color palette• 21-point parameter grayscale and Gamma
• Programmable input/output color-space
• Y/C-delay calibration
• CUE and ICP filtering
• Eight channel audio up to 192 kHz, DD True-HD™ 5.1, and DTS Master Audio™ 5.1 Bitstream
• IR and RS232 control inputs (See Tech Tip 11 and 12 on the Lumagen.com support page)
• Wired IR format command input
• Universal, 100-240V, ~50/60Hz external 12 VDC power supply
• Optional rack mounting ears
