LOL la fiche étudiant; mais c'est très bien, t'es organisé!
pour les retards, hormis la méthode RJB, en plus précis, celle de notre modo kro:
http://www.justdiyit.com/mesure-des-cen ... impulsion/avec arta (point 4.5 de l'aide du programme):
4.5 System Delay Estimation
The fixed delay in a measured system, for example the delay of sound wave from loudspeaker to microphone, or delay in digital processing systems, can be easily estimated (to accuracy of one sample), from the position of maximum of the cross-correlation function of system excitation and measured response. The estimation of delay can be obtained automatically by the menu command 'Recorder->Crosscorrelation/delay estimation' in ARTA Fr2 mode, after initial measurement of the frequency response. That opens dialog box 'Input Channels Cross-correlation' shown in Fig. 4.14
The graph in dialog box shows the cross-correlation function of left and right channels. A zero time (also a zero delay delay point) is positioned in the centre of the graph. On the top-right of the graph there is a label that shows the estimated delay in number of samples and in ms. It is obtained from time position of the maximum of the cross-correlation function. The same value is shown in edit box Delay (ms). By pressing the button Accept, this value can be automatically transferred into Fr2 Window, as a system delay value. Only a positive value of delay can be accepted. If delay is a negative value, input channels have to be exchanged. The other controls on the right toolbar and menu commands have same functions as controls and menus of the Time Record Window that is described in Section 2.5.
et enfin, un conseil de wakeup2
publié sur le site de kro mais également membre hcfr:
"wakup2"
Une bonne méthode, j’utilise toujours Arta pour caler les delay entre HP, mieux vaut mesurer en 96000 Khz, on réduit par 2 l’imprécision, et au final je vérifie toujours en modifiant la position du micro en hauteur, 10cm plus bas, 10cm plus haut…. ça permet aussi de relativiser cette imprécision et de valider le bon calage, a comparer également à la longueur d’onde a la fréquence de raccord ^^
On peut aussi vérifier a la toute fin, une fois l’enceinte filtré, avec le CSD de Arta en mode sonogram, et ne pas hésiter a bouger le micro en verticale. ça permet de bien valider le filtrage et le calage des delay qui fait partie intégrante de la mise au point du filtre.
