HTC Butterfly : 5", 1920*1080, 2 Go RAM, 16 Go ROM, slot micro SD, quad-core S4
http://www.htc.com/www/smartphones/htc-butterfly/
http://www.eprice.com.tw/mobile/talk/45 ... m/4843526/
HTC Butterfly d'origine > sortie numérique >> câble USB OTG >> DAC USB/ampli-casque iBasso D12 Hj >> écouteurs Westone UM-3X
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Dominique-Tanguy, Hoian, jl.dudu, lotofoof46, rotB, Vynz100, XavierP56 et 199 invités
Smartphone + DAC, question d'un beotien...
- DanBa
- Contributeur HCFR 2024
- Inscription Forum: 16 Oct 2007 17:46
hoo encore un Ibasso
- Gandalflux
USB audio & mini PC Android Minix Neo X5 à 99 us$ (Android 4.1 Jelly Bean, ARM Cortex A9 dual-core CPU à 1.4GHz, quad-core Mali 400 GPU, 1 Go RAM, 16 Go ROM, slot SD, port USB 2.0 x 3, port micro USB OTG, SPDIF optique, HDMI, Ethernet, Wi-Fi, Bluetooth, IR, prise jack pour microphone, prise jack pour casque)
http://www.minix.us/products/NEO-X5.html
http://www.squidoo.com/android-mini-pc-buying-guide
http://forum.audiogon.com/cgi-bin/fr.pl ... enflup&5&4
Minix Neo X5 > sortie numérique >> câble USB >> Valab DAC
"SB Touch...buh bye. Hello Android Media Box…
Plug and play USB audio support - no drivers, no snap crackle pop, no dropouts. Wow. The sound was absolutely fantastic. What a great way to consolidate my favorite streaming apps and have my ripped collection just a click away as well. All controlled remotely from the comfort of my easy chair and viewed on my big screen TV. I AM Slothman!
In summary, this was all an exercise in music listening convenience for me and obviously NOT an audiophile quest. However, I do believe that devices such as these and the applications being developed are on the verge of further revolutionizing this hobby in a big way soon. After my initial experience with this (basic) media box, I can certainly see why Logitech decided to kick the SB Touch to the curb. I hope this thread may spark a little more discussion and interest in these Android media boxes/ mini PC's. I haven't seen much mentioned about them here or on computeraudiophile."
- DanBa
ça ne remplacera pas une système SqueezeBox et encore moins une Touch ton bidule là
- Gandalflux
Apparemment les HTC One X tournant sous Android 4.1 Jelly Bean peuvent fonctionner avec les DAC USB standards.
http://forum.lowyat.net/index.php?s=0d3 ... =57944246&
HTC One X > sortie numérique >> câble USB OTG >> DAC USB Stoner Acoustics UD100
"UD100 work on HTC One X with Jelly Bean (kernel 3.x) original from HTC"
- DanBa
DanBa a écrit:Apparemment les HTC One X tournant sous Android 4.1 Jelly Bean peuvent fonctionner avec les DAC USB standards.
Attention, il y a 3 versions du HTC One X : Le X, le XL et le X+.
Sont 'ils tous compatibles ???
- Ottomobil
- Inscription Forum: 18 Oct 2011 22:35
A priori, c’est un HTC One X version internationale à SoC Nvidia Tegra 3, puisque l’info provient d’un Malaisien.
Il est probable qu’un HTC One X+ disposant du même Soc soit aussi compatible USB audio.
Mais, il est probable que dorénavant comme le HTC Butterfly tous les HTC tournant sous Jelly Bean, dont le HTC One X version américaine et le HTC One XL à base de SoC Qualcomm Snapdragon S4, le soient aussi.
http://en.wikipedia.org/wiki/HTC_One_X
- DanBa
Bien vu, je vois que tu t'es documenté pour répondre à ma question.
On te sens impliqué dans ce sujet qu'est l'usb audio pour android.
Je viens de relire le fil et j'aimerai que tu me confirmes une chose :
Avec l'application USB Audio Recorder PRO, est ce que tous les appareils fonctionnant sur android sont compatible avec tous les dac USB ?
Ou y a t il des limitations ??
- Ottomobil
Je suis amateur et voudrais acquérir un de ces joli petit boitier (dac/amp).
Un produit m'intéresse, le hrt microstreamer:
http://www.audioanalogdistribution.com/ ... rostreamer
http://highresolutiontechnologies.com/microstreamer
http://positive-feedback.com/Issue65/microstreamer.htm
Ce modèle est tout récent et donc pas beaucoup d'infos à son sujet sur le web, de plus assez cher :s.
Il a retenu mon attention à cause de sa taille et des retour positif que j'ai lu en général sur cette marque.
Le problème est qu'il est préconisé pour une utilisation avec un Pc(mais compatible tablette, smartphone),
il n'a pas de batterie or je voudrais l'utiliser avec un smartphone.
Il est alimenté par le port usb mais je me demande ce que ça va donner avec un smartphone?
Est ce que les capacité de l'ampli seront diminuées ?
J'utilise actuellement des Ultimate ears 700 qui ne requiert que peu de "jus" mais pour l'utiliser avec un casque cela peut-il poser problème ?
j'ai déja pu lire que le modèle hrt headstreamer mobilE aussi alimenté par l'usb fonctionne avec un galaxy note 2 (il est dans la liste des dac compatibles android):
http://www.computeraudiophile.com/f6-da ... ase-14029/
J’espère que vous pourrez me conseillez merci d'avance.
- cedou97yon
- Inscription Forum: 08 Nov 2011 12:31
Si le HRT microStreamer peut fonctionner avec un smartphone Android
http://www.head-fi.org/t/595071/android ... st_9107016
il doit donner son maximum lorsqu’il est alimenté proprement par une petite batterie externe.
http://www.head-fi.org/t/595071/android ... st_8540151
- DanBa
Ottomobil a écrit:Avec l'application USB Audio Recorder PRO, est ce que tous les appareils fonctionnant sur android sont compatible avec tous les dac USB ?
Tous les appareils Android utilisant l'application USB Audio Recorder PRO ne fonctionnent pas avec tous les DAC USB.
Il faut que les appareils Android 3.1+ disposent d'une USB host fonctionnelle.
Il faut aussi que les logiciels USB audio des appareils Android et les DAC USB ne soient pas trop stricts quant à leur interprétation du protocole USB.
Le concepteur du DAC USB HeadAmp Pico a récemment effectué des modifications afin que son DAC puisse dorénavant fonctionner avec le Samsung Galaxy S3 version internationale.
http://www.head-fi.org/t/595071/android ... st_9037872
C'est aussi le cas du DAC USB VentureCraft Go-Dap X.
http://www.head-fi.org/t/595071/android ... st_8753554
Comme l'USB audio d'Android est relativement jeune, il y a eu peu de tests d'interopérabilité entre les 2 mondes Appareils Android et DAC USB.
Après tout, le driver USB audio standard de Windows a du mal à piloter le DAC USB FiiO E17:
http://www.head-fi.org/t/595071/android ... st_8807747
- DanBa
DanBa a écrit:Si le HRT microStreamer peut fonctionner avec un smartphone Android
Merci de ta réponse Danba je surveillais aussi ce forum pour avoir plus d'info.
J'ai pausé directement le question
http://www.head-fi.org/t/647693/sonic-s ... st_9091996
- cedou97yon
Merci pour ta réponse.
C'est un peu la loterie alors.
- Ottomobil
Pour Usb audio recorder pro, il suffit de télécharger la version d'essai et de la tester sur le smartphone avec un dac USB.
- robob
- Inscription Forum: 21 Mar 2007 19:23
Sur leur site, il indique que leur application ne fonctionne pas avec le galaxy note 1. Je me dis que je ça peut fonctionner avec des version plus récente du firmware du note. Je n'ai pas de DAC, mais J'ai quand même telechargé la version trial. Ça me dit qu'il n'a pas réussi à initialiser le périphérique USB. Normal puisque que j'en ai pas. Je m'attendais à ce qu'il me dise si mon note pourrait fonctionner avec un DAC avant d'en acheter un. Est ce que quelqu'un ici peut me dire si un note avec une version d'Android récente fonctionne avec USB AUDIO RECORDER PRO ?
- Erax
- Inscription Forum: 18 Mai 2005 20:15
