Nouveau firmware Bêta pour le Z9S et le Z10:
Firmware 2.3.35 Zidoo Z9SFirmware 2.3.35 Zidoo Z10La liste des changements (incluant HT 4.0 et de nouvelles options, un économiseur d’écran enfin opérationnel et paramétrable dans les réglages, des infos ajoutées sur les fichiers en lecture quand on presse la touche concernée, le temps de visionnage d’une vidéo dans Media Center, etc)
System
1. Increase screen saver function
2. Add support for aiff music files
3. Optimize DLNA projection function
4. Add Czech language adaptation
5. Repair 3D seamless playback
Player
1. Add press the information button to display poster information
2. Fix the problem of pressing the function key to continue playing during pause
3. Optimize subtitle download
4. Optimize the function of forced subtitles
5. Optimize the display of player poster information
6. Fix the problem that the local player's bit rate gets wrong
7. Added file name display for local player information key
8. Fix the problem that the shortcut keys cannot switch chapters
9. Optimize frame rate switching
Picture manager
1. New revision of functions
2. Add custom folder function
3. Add the function of setting folders as screensaver pictures
4. Optimize the slideshow function
5. Fix the problem that the vertical screen picture is stretched in the slide show
6. Add the function of exclude folder
Poster wall:
1. Upgrade version 4.0
2. Optimize the sorting function of the navigation interface
3. Fix the problem that Douban cannot match
4. Solve the problem that the child lock will be ignored when playing directly
5. Fix the problem of incorrect data after sorting widgets
6. Optimize the ratio of local trailers
7. Optimize the sorting function
8. Optimize the details interface
9. Fix the problem of incorrect TV viewing records
10. Modify the problem that the detailed title is too long
11. When optimizing the list display, the letter navigation and the left side column prompt the picture at the same time
12. Optimize TV series matching
13. Fix the problem that Douban cannot match
14. Add the launch time setting of the trailer in the detail interface
Music player
1. Re-upgrade music version 6.0
2. Optimize album matching logic
3. Increase the folder function
4. Optimize the detailed interface display
5. Increase music setting function
6. Added support for multiple formats (aiff, nrg, etc.)
7. Increase CD interface information display
8. Optimize playback stability
Quick settings
1. Increase screen saver settings
4. Add input method selection settings
File manager
1. Optimize the display of playback records
2. Increase the playback record display switch
3. Fix the problem that the wallpaper of the file manager is not synchronized occasionally
Blu-ray navigation
1. Increase the function of the information button to display movie information
2. Fix the problem of not being able to navigate after entering the screensaver
Control center
1. Optimize connection stability
App installer
1. Optimize webpage installation function
Main interface
1. Optimize the boot display speed
2. Shortcuts add sorting function (press the menu key or long press the OK key)
3. Optimize animation fluency
Dans l’ensemble, tout semble fonctionner correctement. J’ai cependant trouvé un petit bug Dans HT 4.0: si on utilise le mur de jaquettes classique sans activer l’option affichant sur la droite le système de recherche alphabétique, la touche return de la télécommande ne nous ramène plus sur la jaquette du premier film du mur. Si on l’active, pas de soucis.
