Ajout en 1ère page SVS AS-EQ1.
Hugo
Modérateurs: Modération Forum Installations, Modération Forum Haute-Fidélité, Modération Forum Univers Casques, Le CA de l’Association HCFR • Utilisateurs parcourant ce forum: divx971, fandehomecinema, HOGDante, LeBob et 13 invités
Onkyo, for example, calls a speaker "Full Band" if MultEQ reports a rolloff point of 80 Hz or lower. But their default setting for speakers called "Large" is to not bass manage them. So, in this example, all the bass below 80 Hz would be lost and not sent to the sub. This is probably the number one question that we get: what did Audyssey do with my bass??
AVS Forum "Audyssey a écrit:Originally Posted by jek88 a écrit:
Chris,
Do you now if there is any plans to create a DSX 11 channel system(wide, height,and rear). And if there is are there any products that are planning on supporting this.
DSX already supports 11 channels (and beyond--it is fully scalable), but the first products with that configuration have not yet been announced.
__________________
Chris
Audyssey Blog:
Small vs. Large
miaouzz32 a écrit:Ma première impression de l'Audyssey est que ça fonctionne plutôt bien, c'est d'ailleurs le premier système de calibrage que je teste que je trouve crédible.
En revanche, il faut retoucher un peu (relever de quelques dB toutes les enceintes, mettre les fréquences de coupure à 80Hz, mais ça ne pose aucun problème)
