Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: AmazingHC, Becoach, BiancoXCV, BLOCKUS58, zen28150 et 99 invités
Dune HD Lite 53D
Message » 03 Sep 2010 16:57
Dune HD Lite 53D
- Emplacement pour HDD 2.5"
- Puce Sigma SMP8653
- Pas de compatibilité BD ISO
Dune HD Lite 53D
Introduction
Dune HD Lite 53D is an entry-level universal media player which allows to play back video of standard and high definition up to Full HD (1080p), and also can be used as a specialized set-top-box for digital TV programs reception.
The device is compact, looks attractive and, remarkably, is presented in four different colors: with black, white, pink and light-blue case.
The player features two high-speed USB 2.0 ports, SD memory card slot and SATA (in case the internal HDD is installed, the external SATA port is turned off) connector (together with SATA power connector) for connecting external storage. Set of video outputs is represented by one HDMI v1.3 port, composite and component analog outputs. Sound may be connected via HDMI, using the optical Toslink interface, or an RCA stereo connectors. A special feature is the capability to play back audio and video files over a local network. For this purpose an Ethernet port is offered, which allows to transmit data with a high rate of up to 100 M bits per second.
In terms of functionality, the Dune HD Lite 53D meets all requirements addressed to modern multimedia players of low-price segment, and in many points exceeds them. For example, it allows to install a 2.5" SATA HDD inside the case for recording and playback of different audio and video contents.
The Lite 53D is compatible with almost any modern audio and video format, supports IPTV and Internet Radio, and has an embedded torrent client. It also should be noted that the functionality of the Lite family players is continuously improving by regular firmware updates.
Key Features
The newest Sigma Designs 8653 media processor: enjoy excellent playback and performance of interactive features.
HDD player: connect an HDD to the player and play content directly from the HDD.
Network player: connect the player to a local network and play content directly from PC or NAS (UPnP, SMB, NFS).
MKV player: play HD and SD video in a popular MKV format and other modern video file formats, including top quality HD video with very high bitrate.
2 USB ports: conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices.
SATA port: connect an HDD via the most efficient SATA interface.
SD card slot: easily play media files on SD memory cards from your camera or other devices, or use an SD memory card as a local storage.
HDMI 1.3: ensure the best possible quality of HD video and audio.
A rich set of standard A/V connectors: use S/PDIF optical audio, stereo audio, component video, composite video outputs to easily connect any A/V equipment.
Video output flexibility: output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC).
Upscaling: high quality upscaling of DVD and any other SD video content to Full HD (1080p) or other HD resolution.
File browser: convenient file browser with powerful file management (copy, move, delete, rename, organize, sort).
Extra Functions
High-quality music playback: play very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey’s Audio APE, WAV/PCM, DTS, etc).
Playlists: build playlists from your folders, use your own playlists, use repeat and shuffle functions.
NAS function: access files on storage devices (HDD, optical drive, etc) attached to the player from the local network (using SMB or FTP).
BitTorrent: use built-in BitTorrent client to download files from P2P networks.
Customizable user interface: work with media collections using cover art and icon browsing (with Full HD graphics).
Internet radio: playback and record various Internet radio stations (HTTP/MP3).
IPTV: playback and record IPTV streams (multicast UDP/RTP) from your Internet provider (check availability of multicast UDP/RTP streams with your Internet provider).
Digital TV option: playback and record Digital TV channels using an optional Digital TV USB dongle (Digital TV USB dongle is not included; this option can be purchased separately).
Specification
Processor: Sigma Designs 8653
RAM: 256 MB
Flash memory: 128 MB, expandable with a HDD partition, USB flash drive, or SD card (2GB recommended)
Media sources: internal HDD (SATA 2.5”), external HDD (USB, SATA), external optical drive (USB, SATA), USB devices (USB flash drive, USB card reader, etc), built-in SD card reader (SD/SDHC), PC and NAS in local network (SMB, NFS, UPnP, HTTP), other Internet and local network media sources (HTTP, multicast UDP/RTP)
Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264; support for very high bitrate video (up to 50 MBit/s and higher)
Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, DVD-ISO, VIDEO_TS
Optical disc formats: data discs (CD/DVD/BD) (MP3, JPEG, etc), Audio CD (PCM/DTS), DVD-Video (retail and user-authored discs) (playback of optical discs requires an external optical drive).
Video output modes: wide range of supported output resolutions (up to 1080p) and framerates (including 23.976p, 24p, PAL, NTSC)
Video output framerate: automatic (according to the played content) and manual
Audio codecs: AC3 (Dolby Digital), DTS, MPEG, AAC, LPCM, WMA, WMAPro, EAC3 (Dolby Digital Plus), FLAC, multichannel FLAC, Ogg/Vorbis; support for very high quality audio (up to 192 kHz / 24-bit)
Audio file formats: MP3, MPA, M4A, WMA, FLAC, APE (Monkey’s Audio), Ogg/Vorbis, WAV, DTS-WAV, DTS, AC3, AAC
Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, external SUB/IDX), PGS (TS, MKV)
Picture file formats: JPEG, PNG, BMP, GIF
Playlist file formats: M3U, PLS
Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle
Audio playback functions: browse playlist, repeat, shuffle, ID3 tags, plasma TV burn-in prevention
Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3 (read-write), NTFS (read-write)
Ethernet: 10/100 Mbit
WiFi: optional 802.11n WiFi (via an external USB WiFi stick, D-Link DWA-140 recommended)
Dune Network Playback Accelerator: special optimizations ensuring best-in-class network playback performance for the Sigma Designs 864x platform and enabling smooth playback of any supported kind of media content via any network protocol (including NFS and SMB) even in 100 Mbit/s Ethernet networks.
Dimensions: 85 mm (width) x 145 mm (depth) x 160 mm (height)
Country of origin
China
Manuel d'utilisation
http://hdlandforum.fr/viewtopic.php?f=24&t=85
Forum officiel HDi :
http://dune-forum.com
Page officielle de téléchargement firmwares :
http://dune-hd.com/firmware/
Télécharger l'application iPhone/iPad :
http://www.hdlandblog.com/2010/12/dune- ... phone.html
Convertir un disque dur NTFS en EXT2 sans perte de données :
viewtopic.php?f=1182&t=29920078&p=173480119&hilit=ext2#p173480119
Faire monter le disque dur interne formaté en EXT2/EXT3 sur Windows :
http://www.hdlandforum.fr/viewtopic.php?f=26&t=54
Note : Les disques dur NTFS sont reconnus aussi bien en lecture qu'en écriture.
Sujet officiel du Tuner TNT HD optionnel
http://www.hdlandforum.fr/viewtopic.php ... 56&start=0
Vote pour les prochaines fonctionnalités :
http://hdi.co.il/features
Menus DVD désactivés :
Sur certains disques DVD, les menus ne sont pas actifs. Pour les activer, appuyez sur la touche "SELECT".
Navigateur Web de la Dune :
http://hdi.co.il/firmware/web_browser
Ajouter des Radios Internet :
http://hdi.co.il/firmware/inet_radio
http://www.nrj.be/webradios/erreur.php
Ajouter des IPTV :
http://hdi.co.il/firmware/iptv
Fonctionnalités supplémentaires :
http://hdi.co.il/firmware/misc
Configurer la platine avec un NAS :
http://www.homecinema-fr.com/forum/view ... p173332017
Tutoriaux de paramétrages réseau : (SMB, NFS, NAS, ...)
http://www.homecinema-fr.com/forum/view ... t=29908819
ATTENTION ! En SMB, il faut désactiver le "Fast SMB". Pou rune lecture fluide des gros fichiers (ISO Blu-ray, M2TS), nous vous conseillons vivement le protocole NFS.
La fonction Expérimental Gigabit n'est pas recommandée.
[Tuto] Accès à la Dune en réseau depuis un ordinateur (FTP)
http://www.hdlandforum.fr/viewtopic.php?f=25&t=984
[Tuto HDi Dune] Raccourcis réseau SMB
http://www.hdlandforum.fr/viewtopic.php?f=25&t=635
[Tuto] Astuce pour avoir du NFS sur PC Windows
http://www.hdlandforum.fr/viewtopic.php ... p=248#p248
Générer un M2TS à partir d'un ISO Blu-ray
http://www.hdlandforum.fr/viewtopic.php?f=44&t=724
[Tuto] Régler la fréquence d'image sur la Dune
http://hdlandforum.fr/viewtopic.php?f=25&t=1049
Jaquettes :
iDune
http://www.mpcclub.com/temp/IDune.zip
Dune Explorer
http://www.homecinema-fr.com/forum/view ... t=29935947
DuneX (Mac)
http://www.homecinema-fr.com/forum/view ... t=29941763
TViXiE
http://www.tvixie.com/
My Movies
http://www.homecinema-fr.com/forum/viewforum.php?f=1182
MyAllMovies
http://www.myallmovies.com
yaDIS
http://www.hdlandforum.fr/viewtopic.php?f=25&t=601
ZAPPITI
viewtopic.php?f=1182&t=29935483
http://www.hdlandforum.fr/viewtopic.php?f=25&t=605
Déplacer les sous-titres verticalement :
1. Presser la touche "SUBTITLES" (sous-titres)
2. Presser les touches fléchées "HAUT/BAS"
Fonctionnalité valable uniquement en mode fichiers. Pour l'instant la fonction de marche pas sur la lecture DVD/Blu-ray.
Dune Binaries :
http://www.lundman.net/wiki/index.php/L ... e_binaries
Clavier sans fil HDI Dune :
http://www.hdlandforum.fr/viewtopic.php?f=25&t=1074
Procédure de recovery après plantage de mise à jour firmware :
http://www.hdlandforum.fr/viewtopic.php?f=25&t=187
Christophe CHEREL
Pro-Fabricant
Pro-Fabricant
Inscription Forum: 06 Juil 2001 2:00
Message » 03 Sep 2010 18:57
super je vais enfin pouvoir me débarrasser de mon xtreamer de ma chambre :mdr:
si le prix de 169€ est maintenus, ce produit va faire des ravages .. la concurrence à du soucie à se faire :mdr:
wool
Inscription Forum: 13 Oct 2006 21:15
Message » 03 Sep 2010 19:09
Idem, je voulais remplacer l'Xtreamer de mon fils par une smart, c'est surement celle-là qui fera l'affaire :D
costaud
Contributeur HCFR 2019
Inscription Forum: 05 Oct 2004 20:51
Message » 03 Sep 2010 19:18
en tout cas pour moi c'est largement suffisant, j'en demandais pas plus .. :mdr:
wool
Message » 03 Sep 2010 19:41
ben dis donc ils se sont lachés cette année ....
j'avoue qu'a ce prix là , ça devient interessant
moi aussi je voyais pour remplacer mon xtreamer et il pourrait bien faire l'affaire
juste dommage qu'il lise pas les isos de bluray
sebacool92
Inscription Forum: 03 Mar 2009 1:56
Message » 03 Sep 2010 21:17
pour les isos de bluray, c'est pas trop grave, il te suffit d'extraire le fichier m2ts avec les sous titres, perso c'est du pareille au même sans les bonus.. enfin on va pas trop se plaindre à ce prix là ..
sinon pour 80 euros de plus tu as la solution qui lit tout, la DUNE HD SMART H1 ( 249 euros )
http://www.hdland.fr/boutique/fiche_pro ... g_fr&num=0
wool
Message » 03 Sep 2010 21:43
je pense que la hd lite suffira largement dans une chambre sur un lcd de 32 pouces
le bd1 qui lit les isos bluray est a 199 euro (bon ok son firmware est pas au point)
en tout cas ils ont toute une gamme
l'entree de gamme avec hd lite
la moyenne gamme avec hd base et les hd smart modulaire
le milieu haut de gamme avec la bd prime
la haut de gamme avec la hd max
le tres haut de gamme avec le hd pro
sebacool92
Message » 03 Sep 2010 21:53
Je n'ai pas trouvé de date de dispo! Quelqu'un a l'info?
Pompier
Inscription Forum: 05 Aoû 2003 20:58
Message » 03 Sep 2010 22:02
sebacool92 a écrit:je pense que la hd lite suffira largement dans une chambre sur un lcd de 32 pouces
idem pour moi sur mon 32 pouces une lite ira largement..
de plus j'utilise déjà une prime 1.0 avec une structure yaDIS via un server de stockage... ce qui veut dire que je pourrais rebrancher une lite pour y profiter pleinement depuis ma chambre.. et depuis mon salon en même temps !!
wool
Message » 03 Sep 2010 22:28
Pompier a écrit:Je n'ai pas trouvé de date de dispo! Quelqu'un a l'info?
Disponibilité : NC ( j'espère avant noël ) :mdr:
source :
http://dune-hd.com/hd_players/current/1 ... e-53d.html
http://www.hdlandblog.com/2010/09/ifa-2 ... e-53d.html
tout ce qu'on sait c'est que le produit va être présenté au salon IFA de ce moi-ci..
on sait aussi que la lite sera normalement le seul modèle sur toutes les nouveauté à être fabriquer en Chine...
et vu que c'est du lite, les firmware seront lite aussi, je pense que cela à été bien réfléchie et ce afin d'éviter les vols de firmwares. On l'a vu récemment avec l'affaire des firmwares volés Dune par eGreat en Chine.. ( source: Christophe )
Les autres nouvelles machines Dune seront donc fabriquées à Taïwan comme indiqué sur le site officiel ..
wool
Message » 04 Sep 2010 18:27
Noel!! Dommage, je cherche à m'équiper pour septembre...
Pompier
Message » 05 Sep 2010 10:05
je dis noël pour être large mais je pense que se sera avant..
et vu que c'est le seul produit fabriqué en Chine , ça va surement débiter
wool
Message » 06 Sep 2010 11:42
A priori il prend en charge les ISO BD.
Le lecteur parfait non ? qu'est ce qu il lui manque ?
arzo
Inscription Forum: 15 Oct 2003 11:27
Message » 06 Sep 2010 12:57
oui prise en charge limité quand même car comme toutes les platines multimédia à base de puce qui ne gère pas la licence BD.
En tout cas, elle est sur de remplacer l'Xtreamer de mon gamin :mdr:
costaud
Message » 06 Sep 2010 13:01
quel est le différenciateur entre une DUNE HD SMART D1 et le Dune HD Lite 53D ?
hormis l'evolutivité.
arzo
