Bonjour a tous,
FW 1.2.7 disponible sur le site Zidoo pour le X9S, la version pour le X8 sera disponible demain.
http://forum.zidoo.tv/index.php?threads ... ased.3391/
Version 1.2.7 of Zidoo X9S
Updatelist:
System:
1,A download tool aria2 added in OpenWrt system.
2,The brightness of VFD can be adjusted now in the setting of system.VFD stands for vacuum fluorescent display which is in the front panel.
3,3D library of skia been improved,subsequently scores of Antutu exceed 40000.
4,Green screen appears occasionally when play 3D movie, this issue has been fixed.
5,RAW out of sync when play some TrueHD and DTSHD HRA movies, this issue has been fixed.
6,After HDR playback exit,HDR status don't back to normal status, this issue has been fixed.
7,The setting of Force downmix audio can't be saved after restart the box,this issue has been fixed.
8,Optimized audio option.If the settings is RAW and playing AAC audio,The audio output will be temporarily auto changed to PCM
9,Enable the statusbar
Launcher:
1,More tips added in the desktop interface.
2,The mouse cursor style changed into a better one.
Player:
1,The offset of subtitle will only valid for once.
2,AutoFrameswitch added 30fps and 60fps.
3,If the movie is paused,press the menu key will not resume the playback.
4,When searching the subtitles,the system will make it a priority to search the subtitles in default subtitle language setted in system advanced settings.The lower priority is system language.The lowest is English.
5,Removed Force SD audio setting.
6,Removed the auto-identify of MKV's MVC.(We now rewriting this part)
7,Bookmarking function is open as default.
8,Press OK to play from the beginning when resuming playback from bookmark.
9,3D playback tips added.
Filemanager:
1,Immediately sync after copy or delete.
2,A button to return to top added.
3,A wrong error report when add&remove the directory in Russian language fixed.
Full_OTA_Package:
Mediafire mirror: http://www.mediafire.com/file/7mwy1od8o ... v1.2.7.zip
Amazon mirror: http://ota-cloudfront.zidoo.tv/X9S/OTA/ ... v1.2.7.zip
MD5:92e75f35a30dac901cdb41058a4dddf6
How to upgrade:
http://www.zidoo.tv/Support/guide/guide ... z+dw=.html
This version will be test in forum for a week,then push it for OTA upgrade via online.
About ZIDOO X8,will release new version tomorrow
Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: alexins, balrog31, bvivien, lgarnier, papounay, parager, Poune, Ricou31530, tedkiller, touri85, vwinman et 99 invités
Zidoo X8/X9S/X10 RTD1295 (4K60/HDR/BD menu/Control4)
- OlivierQC
- Contributeur HCFR 2018
- Inscription Forum: 23 Avr 2003 14:01
Au faites ça marche chez toi le HDR en 24p ?
- BrokenPanda
- Inscription Forum: 06 Oct 2013 15:36
Alors ? Qui va tester le FW 1.2.7 ?
Je vais attendre quelques retours, sinon je le ferai vendredi.
- Mumakil
- Inscription Forum: 20 Juil 2014 18:07
Mumakil a écrit:Alors ? Qui va tester le FW 1.2.7 ?![]()
ayant le X8, il faut que j'attende demain pour l'avoir et il faudra quelques films pour valider que tout est correct pour le son HD et les flash vert entre autres.
il faut aussi que je verifie le CEC voir si c'est corrigé.
sur le forum Zidoo :
http://forum.zidoo.tv/index.php?threads ... 391/page-3
De fab0nymous :
DTS HD Input Lag seems to be fixed
- OlivierQC
@Olivier: ouais c'est long de tout tester...Apparemment le décalage audio serait résolu !
A tester quand même...
- Mumakil
je recois le mien normalement entre le 24 et le 28 (pas demain car la je vois qu'il a pas encore été expedié).
a reception vous me conseillez de faire quoi ? mise a jour direct au dernier firmware ? d'autres choses ?
je vais calculer certains de mes projets videos sous vegas en H265 pour voir ce que ça va donner le temps de le recevoir ! le temps d'encodage me fait peur a l'avance
- Martyprod
- Inscription Forum: 03 Juil 2005 22:34
@Martyprod,
oui premiere chose a faire passage en 1.2.7, si tu recois ton boitier fin novembre la mise a jour en OTA sera disponible, sinon hard reset avec le bouton reset a l'arriere du boitier.
- OlivierQC
olivierQC a écrit:@Martyprod,
oui j'ai vu l'info et la procédure. par contre, je pourrais pas aider pour le son. je sors que de la stereo via la sortie HDMI sur une télé qui 99.99999% a le son eteint (probleme d'oreille si tu te souviens) donc niveau decallage audio etc, je pourrais pas dire quoi que ce soit. de plus le son repart vers l'ampli en stereo via la sortie cinch stereo de la télé ! (pour d'eventuel invités qui ecouteraient au casque un truc qu'on regarde a la télé, mais j'ai jamais aucun invité lol...). idem pour la 3D j'ai pas de 3D. pour le reste oui par contre.
première fois que je vais essayer android (j'ai meme pas de smartphone). deja va me falloir un moment avant de piger comment tout marche
- Martyprod
pas de probleme, pour les retour sur le probleme du son hd, il devrait y avoir des avis dans les prochaines 24/48h sur les differents forums et aussi pour les autres correctifs.
- OlivierQC
Direct installé !
plus de soucis avec le son HD décalage audio (test du mkv "ant-man" ) ou "accroche" pour les pistes atmos et dts master audio .
Pour mon utilisation, cette box est juste parfaite maintenant
- xsi77
- Inscription Forum: 20 Oct 2004 13:40
Merci pour le retour xsi77
ca confirme ce que je pense de zidoo et de leur mise a jour.
Reste plus qu'a attendre la nouvelle version de leur lecteur Theater pour resoudre le probleme de framerate avec les MVC 3D, le probleme du mode video output AUTO et ca sera tout bon.
- OlivierQC
petit retour
-effectivement plus aucun décalage comme promis
- par contre il arrive que le son va décrocher sur ce genre de bande son si vous vous amusez a faire des avances ou recul je sais plus , un simple pause lecture règle le probleme
reste à test pour l'histoire des flashs vert ultra rare sur les iso 3d ,
en tout cas pour mon utilisation c est maintenant au dessus d'une shield .
on doit saluer leur réactivité en meme pas 2 mois j'ai encore jamais vu une box arrivée à ce niveau avec en plus l'utilisation d'une toute nouvelle puce realteak
- piou
- Inscription Forum: 05 Sep 2006 20:15
xsi77 a écrit:Direct installé !plus de soucis avec le son HD décalage audio (test du mkv "ant-man" ) ou "accroche" pour les pistes atmos et dts master audio .
c'est ça qu'est bon
pour la 3D je m'en fiche
P.S: Reste plus qu'elle serve de la bière et elle sera parfaite
- Mumakil
Petit CR du 1.2.7
+ Plus de prob de desynchro son
- l'auto display ne fonctionne toujours pas ( en 4k il est en 1080p )
- Des bug avec le HDR :
DeepCOlor OFF = aucun prob de décrochage HDR
DeepColor ON + 60p = OK
DeepCOlor Auto + 24p en YUV 422 = OK ( mais étrangement les info video de mon ampli ne comprennent pas le bits de couleur )
Par contre dès que je mets ,yuv420, yuv444, en 24p l'HDR fait n'importe quoi
- BrokenPanda
BrokenPanda a écrit:Au faites ça marche chez toi le HDR en 24p ?
Ca a l'air, toutes mes demos sont fluides et ma TV switch a la bonne frequence
Perso avec le Z8 je laisse les parametres suivants sans jouer avec les autres.
a bientot
- OlivierQC
