Effectivement c'est pas idiot, dans la mesure où on a la perche qui est déportée, je n'y avais même pas pensé
Modérateurs: Modération Forum Installations, Modération Forum Haute-Fidélité, Modération Forum Univers Casques, Le CA de l’Association HCFR • Utilisateurs parcourant ce forum: cyril.edge, fred-ql, Patrick-HC et 30 invités
Surelym we’d be happy to help.
- Channel mode is to basically “hardcode” OR " let the automatic mode of HDMI" kick in. Here is an explanation on how it works:
- HDMI works as a chain. i.e. you’ve got source defining to all devices downstream what happens.
- On a nanoAVR, it could be an issue for those using the nanoAVR HD for active speaker (i.e. 2.0 to say 4way setup). If we weren’t “forcing” the nanoAVR to output 7.1 (i.e. 8ch), the 4way setup wouldn’t work.
On a nanoAVRDL it’s not as much of a need than a HD/HDA since it’s a fixed structure. i.e.IN1 goes to OUT1. So If Channel Mode = stereo, 2) 7.1 → input NanoAVR DL → Dirac Live on 7.1 → output 7.1 but only two channels active (and the fifth others channels diseapper?) ?
So in most cases, keep it on Auto, it’s the easiest I guess.
Hoping this info helps
If Channel Mode = stereo, what becomes a 7.1 signal?
1) 7.1 -> input NanoAVR DL -> conversion of 7.1 in 2.0 -> Dirac Live -> output 2.0 ?
2) 7.1 -> input NanoAVR DL -> Dirac Live on 7.1 -> output 7.1 but only two channels active (and the fifth others channels diseapper?) ?
3) 7.1 -> input NanoAVR DL -> Dirac Live in 7.1 -> conversion of 7.1 in 2.0 -> output 2.0 ?
4) something else?
