Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: blackadder68, doffff, GHK92, JohnSmith0106, Solitaire555, steve71, Tenryo91, vwinman, zorros et 89 invités
Zidoo Z9S/Z10 RTD1296
Message » 11 Sep 2018 12:21
Bonjour a tous,
Un nouveau topic pour vous presentez la serie Z de chez Zidoo, elle utilise le nouveau RTD 1296DD de chez Realtek, ce sont les Z9S et Z10 sous Android 7.1.
Specifications:
OS – Android 7.1 + OpenWRT(NAS) dual system run simultaneously
CPU – Realtek RTD1296 ARM Cortex-A53 Quad-Core
GPU – Mali T820 MP3
Memory – 2GB DDR
Internal Storage – 16GB eMMC
Connectivity – Wifi IEEE 802.11 a/b/g/n/ac 2×2 MIMO 867Mpbs, Gigabit Ethernet – RJ-45 Ethernet Jack (10/100/1000Mbps), Bluetooth BT4.1
HDMI Port Output HDMI 2.0a / Input HDMI 2.0, Support 4K@60fps, HDR10
Video decode – HDR, 10-bit HEVC/H.265 up to 4K@60fp, VP9 up to 4K@60fps, H.264 up to 4K@24fps
Audio decode – Support HD audio multichannel pass through and stereo decoding
USB Port 2x USB3.0, 2x USB2.0
Power – DC 12V/3A
HDD Bay – 3.5″ HDD Bay with SATA 3.0
Other interfaces: 3.5mm RS232, IR receiver, RCA Cvbs, RCA Audio L/R OPTICAL (2CH, 5.1CH), RCA coaxial, Key Recovery, SATA3.0 (To connect Serial ATA ), VFD display (with LED light)
Dimensions – 302 x 240 x 100mm
Weight – 2.38 kg
Zidoo X9S
Specifications
CPU – Realtek RTD1296DD ARM Cortex-A53 Quad-Core
GPU – Mali T820 MP3
Memory – 2GB DDR
Connectivity – Wifi 802.11 a/b/g/n/ac 2×2 MIMO 867Mbps, GIGABIT LAN RJ-45 Ethernet Jack (10/100/1000Mbps), Bluetooth BT4.1
HDMI Port HDMI2.0a Output / HDMI 2.0 Input, Support 4K@60fps, HDR10
Video decode – HDR, 10-bit HEVC/H.265 up to 4K@60fps, VP9 up to 4K@60fps, H.264 up to 4K@24fps
USB Port – 2x USB3.0, 2x USB2.0
Power – DC 12V/3A
Other interfaces 3.5mm RS232, IR receiver, 3.5mm Cvbs Audio R/L, OPTICAL (2CH, 5.1CH), Key (Recovery, 2x SATA3.0 (To connect Serial ATA ), VFD display (with LED light), LED (Shutdown of red)
Dimensions – 245 x 201 x 81mm
Weight – 1.20 kg
Dans la boite se trouve les accessoires suivant : le Media Player (Z9S ou Z10), la telecommande, un cable HDMI, le Power Adapter et un manuel d'utilisation.
Telecommande retro éclairée similaire au modele X10
les 2 boitiers utilise HT 2
How to flash ZIDOO Z9S
Si vous etes tenté par l'aventure du downgrade de votre boitier a cause d'un probleme avec votre boitier ou tout simplement pour repartir sur une base saine, voila le FW .IMG necessaire pour le faire et il suffit de suivre les instructions. ICI
A la fin du download il faudra accepter de finir de telecharger le fichier car Windows le prendra pour un fichier malvaillant.
Download Download ZIDOO Z9S v1.7.8
Guide
Un grand merci a McBluna pour son travail.
Clicquer sur les vignettes de votre choix
A bientot
OlivierQC
Contributeur HCFR 2018
Inscription Forum: 23 Avr 2003 14:01
Message » 11 Sep 2018 13:22
C'est pas un peu inquiétant le décodage du h.264 en "up to 4K @ 24 Hz" ?
Jacky67
Inscription Forum: 14 Fév 2011 20:14
Message » 11 Sep 2018 13:44
Ce qui est inquiétant c'est facturer la couche de peinture 20% plus cher
droiter
Inscription Forum: 19 Aoû 2016 19:27
Message » 11 Sep 2018 17:47
Ils les sortent uniquement en Silver ? Pas de Black ?
LePousson
LePousson
Inscription Forum: 04 Fév 2007 19:53
Message » 11 Sep 2018 21:39
LePousson a écrit:Ils les sortent uniquement en Silver ? Pas de Black ?
LePousson
Bin si, en noir ils s appellent X... et en métallisé Z... :ane:
nnay07
Inscription Forum: 05 Mar 2006 22:23
Message » 11 Sep 2018 21:55
LePousson
Rassure moi, tu joke là ??
LePousson
LePousson
Message » 11 Sep 2018 22:30
:mdr:
nnay07
Message » 12 Sep 2018 1:36
Il y a pas juste l'esthetique du boitier les gars :D
Ils ont aussi 2x SATA , 4x USB (2x USB2 and 2x USB3), le BT 4.1, le Wi-Fi MIMO 867Mbps en plus du RTD1296...
et j'ai l'impression qu'on aura droit a un nouveau menu principal mais c'est juste une supposition de ma part.
OlivierQC
Message » 12 Sep 2018 4:04
olivierQC a écrit:Il y a pas juste l'esthetique du boitier les gars :D
Moi je le sais mais pas sur que l'autre personne l'ait remarqué ...
LePousson
LePousson
Message » 12 Sep 2018 9:42
Je suis curieux de connaitre les nouveautés niveau software à moins qu'il faille attendre la version "gold"...
evangelion77
Contributeur HCFR 2024
Message » 12 Sep 2018 10:40
Dans les faits, ça ne fait pas lourd:
- 1 SATA externe qui n existait pas sur le X10: je n utilise déjà que peu ou pas le HDD interne, tout est sur mon NAS
- 1 USB 3.0 de plus que le X10: je n utilise pas les USB ou alors rarement, le X10 a déjà de l USB 2.0 et de l USB 3.0, ce port en plus ne m apporte rien
- le BT4.1 au lieu de 4.0: pour l utilisation du BT avec un lecteur multimédia (connexion clavier et souris), je ne crois pas que ça apporte beaucoup
- un meilleur WiFi, c est vrai, mais perso je n utilise que le gigaEth pour éviter les problèmes de lag sur les fichiers à gros débits
- le RTD1296 n apporte que plus d entrée sortie (SATA...) que le RTD1295, il n est pas plus puissant, c est le même GPU
Donc effectivement, X10 et Z10 ne sont pas identiques, mais je trouve que les évolutions sont mineures, pour ne pas dire inexistante vis à vis de l utilisation que j ai de ce boîtier au jour le jour. D autres y trouveront sûrement leur compte, s ils ne peuvent pas utiliser l Ethernet ou s ils ont plus de 4 HDD externes à brancher, mais j intuite qu il doit s agit d une minorité.
Après, je comprends que d un point de vue marketing il soit très important pour zidoo d avoir la version de puce Realtek la plus avancée en apparence. Il faut aussi savoir briller sur le marché.
nnay07
Message » 12 Sep 2018 16:10
oui c'est une mise a jour (petite evolution) de leur Serie X avec le nouveau Realtek et le passage a Android 7.1, moi j'attend de voir si avec android 7.1, on va voir apparaitre quelques chose de nouveau concernant la qualitée d'image, fluiditée etc...
A bientot
OlivierQC
Message » 12 Sep 2018 16:20
Oliv', toi qui à l'air d'être bien vu par Zidoo, tu pourrais pas leur dire qu'il est (à mon avis) complètement stupide de mettre un tiroir sur le côté, et qu'ils feraient mieux de le cacher derrière l'afficheur... :oldy:
Jacky67
Message » 12 Sep 2018 17:00
Salut Jacky67,
il y a eu un leger refroidissement eolien avec eux depuis que je leur ai dit que le X20 etait plein de bugs et decevant pour le prix.
OlivierQC
Message » 12 Sep 2018 17:09
Ah, tabarnak ! C'est ben dommage là ! ;)
J'avais l'impression qu'ils t'écoutaient pas mal avant ça et que ça faisait vraiment avancer les choses dans le bon sens.
Jacky67
