Modérateurs: Modération Forum Univers TV, Le CA de l’Association HCFR • Utilisateurs parcourant ce forum: agadoc, Bepo_83, Brest29, dlel95, dreamdavid, elbarto75, evolution06, fatalitas, Flyingboy, GeantVert, julien goutret, lcdmen, Le gabian, lionel1975, methodman, mojinto21, Mumakil, Ordinadim, popel75, Seb38230, seba5920, snakeout, youbewt, Zappy Bibicy et 172 invités
Message » 05 Aoû 2019 22:18
DanBa
Contributeur HCFR 2024
Message » 11 Aoû 2019 19:46
Le disque UHD Blu-ray "The Shining" de Stanley Kubrick sera disponible en Dolby Vision et HDR10+ (et HDR10).
https://www.blu-ray.com/news/?id=25112
https://forum.blu-ray.com/showthread.ph ... st16712961
DanBa
Message » 11 Aoû 2019 19:49
Mais pas de Dolby Atmos ou de DTS:X pour le son !!
Oasis
Inscription Forum: 19 Oct 2011 17:50
Message » 15 Aoû 2019 22:24
Apparemment, TCL sera le 1er fabricant de TV qui permet à un utilisateur de lancer un calibrage automatique à partir de certains smartphones Android et iPhones.
L’application de calibrage de TCL sera disponible cet automne sur Google Play store et Apple store.
"in 2019, TCL is expanding the capabilities beyond an algorithm running on the TV, adding functionality that allows an app for select mobile phones to improve the performance even more. This new concept will allow customers to apply a simple, automatic TV color calibration to deliver more color accuracy than ever before. In the fall of 2019, the new iPQ Engine Mobile app will be available in the Google Play store for Android devices and in the Apple store for iOS devices."
https://www.prnewswire.com/news-release ... 02304.html
Même si une caméra de smartphone n’est pas aussi sensible qu’une vraie sonde d’étalonnage, n’importe quel calibrage est mieux que rien.
"Now for our headline that spotlights phones and calibration, it appears that TCL is the first manufacturer to crack the door to actual in-home customized panel performance using a handheld device. And this is seriously exciting because the masses deserve truly impactful automated setup features that put a television in its best-operating state. Of course, TCL’s top-line TVs carry onboard processing that attempts to optimize color, contrast, and clarity for various sources, but a forthcoming app (iPQ Engine Mobile app) for both Android and iPhone devices appears to allow a TV to analyze itself using a phone’s camera. The would-be intent (assumptions, here) is to dial-in color beyond what the eye can achieve. And while a camera on a device isn’t nearly as sensitive as that found on high-end calibration gear, anything is better than nothing, especially if it can analyze and apply some effective change to grayscale performance.
Hats of to you, TCL, and let's hope the calibration app works. Fingers are certainly crossed."
https://www.avnirvana.com/threads/tcl-a ... dels.5312/
DanBa
Message » 16 Aoû 2019 0:19
Très intéressant si ça fonctionne correctement ! Les chinois mettent la pression sur les japonais et les coréens...
hyperspace
Message » 18 Aoû 2019 16:43
Le gagnant du HDTV Test Shootout 2019 est le LG C9.
https://www.avsforum.com/forum/40-oled- ... st58439368
post179984310.html#p179984310
Best Living Room TV: Panasonic GZ2000
Best Home Theater TV: Panasonic GZ2000
Best HDR TV: LG C9
Best Gaming TV: LG C9
Best Overall TV of 2019: LG C9
Les TV LG C9, Panasonic GZ2000, Samsung Q90R et Sony AG9 de 65 pouces lors des tests en aveugle du HDTV Test Shootout 2019 (le petit écran est le moniteur professionnel de référence) :
https://www.avsforum.com/forum/40-oled- ... ssion.html
DanBa
Message » 19 Aoû 2019 13:55
DanBa
Message » 19 Aoû 2019 21:09
Merci pour cette news.
Mais le gagnant pour le "Motion" me surprend vraiment. Car le compensateur de mouvement de l'AG9 ne fluidifie pas grand chose... :roll:
Fafa
Message » 19 Aoû 2019 23:41
Tu as quand aime l AG9 dis moi ?
Ou ton jugement va être influencé par le résultat lors de ton compte rendu?
Masterwarzombie
Message » 20 Aoû 2019 10:47
On n'est plus des enfants à avoir des avis extrêmement tranchés (j'aime / j'aime pas). :wink:
L'AG9 pêche, à mes yeux, pour sa compensation de mouvement. Mais elle m'a également montré moultes qualités.
De plus, le CR qui va être publié vers la rentrée ne sera pas un jugement en soi mais plutôt un avis.
Ca ne change peut-être pas grand chose dans le contexte d'une discussion (puisque l'avis peut avoir valeur de jugement s'il est parfaitement suivi par l'auditoire), mais il faut savoir qu'on accorde de l'importance, sur HCFR, à ce qu'un CR soit fait à plusieurs voix, et si possible des voix discordantes.
Ainsi, pour le CR de l'AG9, ce dernier comportera 3 avis :
- le mien, amateur de TV haut de gamme et de fluidité "60hz"
- celui d'un amateur de TV d'entrée de gamme
- et celui d'un amateur de VP et de fluidité "cinema".
Cela permet ainsi à l'auditoire de tempérer l'avis de chacun en fonction de ses propres attentes.
Qui plus est, je vois que tu as toi-même la 77AG9. Tu es donc le plus à même de savoir si cette TV te plaît ou pas. :wink:
Fafa
Message » 20 Aoû 2019 11:05
Cool :D
Masterwarzombie
Message » 20 Aoû 2019 11:45
Fafa a écrit:On n'est plus des enfants à avoir des avis extrêmement tranché (j'aime / j'aime pas). :wink:
Il y en a sur ce forum qui aiment les TV d'entrée de gamme ? :mdr:
hyperspace
Message » 20 Aoû 2019 11:48
Non, j'ai mal formulé. Disons qu'il y en a qui s'en fichent un peu du niveau de gamme de leur TV...
Fafa
Message » 20 Aoû 2019 11:59
Ah oui, je vois mieux. Comme la plupart du grand public en somme :wink:
hyperspace
Message » 20 Aoû 2019 13:04
DanBa a écrit:Le gagnant du HDTV Test Shootout 2019 est le LG C9.
Best HDR TV: LG C9
c'est un shootout pour des écrans d'ordinateur et je parle même pas du téléviseur de référence ? car les mecs sont au moins à 10 mètres du bordel :bravo:
Comme à la maison en fait .
c'est tellement à l'aveugle que les mecs à 10 mètres ont des jumelles :mdr:
surtout faut pas franchir la ligne jaune hein . On devrait faire de même chez nous avec les femmes et les enfants :ane:
Masterwarzombie
Retourner vers Ecrans UHD 4K
