Modérateurs: Modération Forum Installations, Le CA de l’Association HCFR • Utilisateurs parcourant ce forum: Malran et 42 invités
Salle sur chevron bois- Petites Nouvelles
Message » 05 Oct 2023 14:20
en modifiant: C:\Program Files\Kodi\system\playercorefactory.xml
exemple:
Code: Tout sélectionner
<?xml version="1.0" encoding="UTF-8"?>
<playercorefactory>
   <players>
   <!-- External Player -->
      <player name="ExtPlayer" type="ExternalPlayer" audio="false" video="true">
         <filename>C:\Program Files\MPC-BE x64\mpc-be64.exe</filename>
            <args>"{1}"</args>
            <hidexbmc>true</hidexbmc>
               <hideconsole>true</hideconsole>
               <warpcursor>none</warpcursor>
            <playcountminimumtime>180</playcountminimumtime>
      </player>
    </players>
    <rules action="prepend">
      <rule filetypes="mkv|avi|bdmv|mp4|wmv|mpg|ifo|ts|m2ts"  player="ExtPlayer" />
      <rule filetypes="mp3|flac|wav|wma" player="ExtPlayer" />
      <rule name="htsp/pvr" protocols="htsp|pvr" filetypes="pvr" player="VideoPlayer" />
      <rule name="https" protocols="https" player="VideoPlayer" />
     </rules>
  <rules name="system rules">
    <rule name="mms/udp" protocols="mms|mmsh|udp" player="VideoPlayer" />
    <rule name="lastfm/shout" protocols="lastfm|shout" player="PAPlayer" />
    <rule name="rtmp" protocols="rtmp" player="VideoPlayer" />
    <!-- VideoPlayer can play standard rtsp streams -->
    <rule name="rtsp" protocols="rtsp" filetypes="!(rm|ra)"  player="PAPlayer" />
    <!-- Internet streams -->
    <rule name="streams" internetstream="true">
      <!-- flv -->
      <rule name="flv/aacp/sdp" mimetypes="video/x-flv|video-flv|audio/aacp|application/sdp" player="VideoPlayer" />
      <rule name="mp2" mimetypes="application/octet-stream" filetypes="mp2" player="PAPlayer" />
    </rule>
    <!-- DVDs -->
    <rule name="DVD" DVD="true" player="ExtPlayer"  />
    <rule name="dvdfile" dvdfile="true" player="VideoPlayer"  />
    <rule name="dvdimage" dvdimage="true" player="VideoPlayer"  />
    <!-- Only VideoPlayer can handle these normally -->
    <rule name="sdp/asf" filetypes="sdp|asf" player="VideoPlayer" />
    <!-- Pass these to VideoPlayer as we do not know if they are audio or video -->
    <rule name="nsv" filetypes="nsv" player="VideoPlayer" />
    <!-- pvr radio channels should be played by VideoPlayer because they need buffering -->
    <rule name="radio" filetypes="pvr" filename=".*/radio/.*" player="VideoPlayer" />
  </rules>
</playercorefactory>
Enceintes : JBL Pro (3677*3/8330*2/8320*4/3635*2) ; Ampli AV : Denon 6700, Yamaha P3500S, 12*UCD400
Lecteurs : DVL909 - OPPO 103EU - Xbox One X - PCHC-madVR - Projecteur : EPSON QB1000 - Stockage : Netgear RN316 23To
.... Le tout piloté par Jeedom :-)
Patou100
Inscription Forum: 16 Juin 2001 2:00
Message » 05 Oct 2023 15:43
merci :thks:
Patrick-HC
Inscription Forum: 27 Déc 2009 15:43
Message » 10 Mar 2024 20:08
Hello tout le monde ,
Quelques nouvelles :
-Arrivé d’un nouveau PCHC demain qui sera le centre névralgique, je m’explique , il va remplacer mon PCHC actuel ainsi que mon Mac mini M1 ( qui me sert à la bureautique et la compo musicale actuellement ) et seras utilisé également pour mon nouveau simulateur de course ( SIMRACING ) tout cela en écran partagé . Le PC bureautique et studio se trouvant actuellement dans une pièce avec le simulateur , par contre la salle HC se trouve à une vingtaine de mètres de distance , j’ai donc testé deux câbles afin de pouvoir piloter à distance , un câble HDMI optique de 20m et un câble USB alimenté avec plusieurs répétiteurs sur les 20 mètres afin de pouvoir juste brancher un dongle USB pour le clavier et tout fonctionne parfaitement .
-la venue prochaine de mon ami CDGG afin de refaire une calibration complète de la salle , il y a eu tellement de changement depuis 2017 , Pré amplis, source , VP etc … que se ne seras pas inutile .
Je vous ferais un CR évidement .
A bientôt
stephblues57
Inscription Forum: 25 Nov 2011 17:01
Message » 10 Mar 2024 20:54
:bravo:
Polopretress
Message » 10 Mar 2024 21:03
Attention, si CDG vient, il faut vérifier les polarités :lol:
dr rotule
Contributeur HCFR 2024
Message » 10 Mar 2024 21:24
dr rotule a écrit:Attention, si CDG vient, il faut vérifier les polarités :lol:
Ouais !!! Bientôt chez stef ! Je vais ne faire qu’une bouchée des 3 cornets ! :ko:
CDGG
Pro-Divers.
Pro-Divers.
Message » 10 Mar 2024 21:35
Laisser les cornets chez le marchand de glaces :mdr:
HC Tonius ici
Anthem avm 70 . Yamaha dme24n . Zidoo z2000pro . Yamaha pro . Jbl pro 3677-8320-4641diy . Sony Bravia 7 XW5100es . Nas Synology 1815+ . Madvr Envy pro
Tonius
Inscription Forum: 03 Avr 2010 10:45
Message » 10 Mar 2024 22:31
Le retour des cornets :ane:
Hâte de lire ton retour.
Tochiro
Inscription Forum: 21 Nov 2004 18:47
Message » 12 Mar 2024 22:19
Alors voici la config reçu hier et franchement mise en route ce jour avec quelques difficultés quand meme :
-Boitier grand tour Corsair 7000X Blanc
-Intel Core i9 12900KF
-Carte Graphique Asus Rog Strix Geforce RTX 3090 OC White Edition 24GB
-Carte Mère Asus rog Z690 Maximus Formula Watercooling Blanc
-RAM Corsair Dominator Platinum RGB DDR5 5600mhz en 4X16 (64Go) Blanc
-SSD Samsung 980 PRO, NVMe M.2 (un de 250Go)+(un de 1To)+(un de 500Go)
-Allimentation Corsair RM1000X
-Watercooling custom .
Etc…
J’ai pour le moment :installer Win 10 proprement , mise a jour de tous les drivers , installer les application de base et les application de chez CORSAIR afin de gérer la boite de nuit :lol: . J’ai également commencer a configure le simulateur .
Demain je devrait connecter le HC ( distant de 20m ) et installer les programmes Madvr etc …
Donc a suivre
stephblues57
Message » 12 Mar 2024 22:50
J’espère que tu avais gardé une licence Windows 10 car ce n’est plus vendu microsoftne vend plus que le 11
Ragnarsson
Inscription Forum: 25 Mai 2016 20:15
Message » 12 Mar 2024 22:53
Oui oui j’ai pris une licence Win 10 , on trouve aujourdhui des clé pour 15 euros environ .
stephblues57
Message » 12 Mar 2024 23:07
stephblues57 a écrit:Image[/url]
Joli, :lol: Tu es prêt pour Abyss en 4K :ane:
Fre.Mo
Inscription Forum: 19 Déc 2002 10:42
Message » 12 Mar 2024 23:26
:ane:
stephblues57
Message » 13 Mar 2024 8:32
La vache, il y a du ventilo, j'en compte 12, plus celui de l'alim. :o
Herve71
Inscription Forum: 21 Jan 2010 19:56
Message » 13 Mar 2024 9:30
Salut Stef !
Très classe, tu dois avoir hâte de voir la bête en fonctionnement avec Madvr
BRAVO ^_^
Doubs25
Inscription Forum: 12 Oct 2013 21:29
