Du Velleman:
préampli:Features
no-compromise high-end design
4 inputs
exclusive finish, solid aluminium enclosure
high-quality ALPS volume potentiometer
full valve design
activation delay with automatic muting
input selection through highly reliable reed relay
separate left and right input section
programmable level adjustment +6dB for each input
regulated DC filament supply
output with mute function
switchable monitor output (for tape, CDR, MD,...)
also available in kit version: K8020
Specifications
input sensitivity for 0dB (0.775Vrms) out: approx. 200mV / 50Kohm
maximum output level: 35Vpp
output load impedance: 10K or higher
signal-to-noise ratio (A-weighted ref. 0dB out): 100dB
total harmonic distortion: <0.04% @1kHz / 47K load
gain: x2 or x4(+ 6dB on)
frequency response: 7Hz to 150kHz (-3dB) @ x2 gain / 18Hz to 55kHz within 0.3dB
channel separation: 85dB @ 0dB in
input crosstalk: < -100dB @ 0dB in
AC power: 115Vac (100V to 120V) or 230Vac (220V to 240V)
consumption: 16W max.
dimensions: 290 x 165 x 68mm (11.4" x 6.5" x 2.7")
weight (net): 2.7kg (6lbs)
Ampli:Features
ultra linear output transformers
switch-on delay of ± 1minute to protect the output valves
standby circuit
built-in bias current indicator
Specifications
version: chrome
voltage: 230VAC
output power: 2 x 95Wrms (class AB), 2 x 15Wrms (class A)
output impedance: 4 or 8ohm
switch-on delay for the supply transformer: 0.5 seconds
power bandwidth: 15Hz - 40kHz (-3dB, ref. 50W)
frequency range: 8Hz - 80kHz (-3dB, ref. 1W)
harmonic distortion: 0.1% (1kHz / 1W) ; 0.7% (1kHz / 90W)
signal-to-noise ratio: >105dB (A-weighted wrt 90W)
channel isolation: 75dB wrt 90W
input impedance: 34Kohm
input sensitivity: 1Vrms (0W)
damping factor: > 10 (100Hz)
dimensions: 425(W) x 130(H) x 350(D)mm
et en plus il est beau!!!
