Guy59 a écrit:Bonjour,
Je possède une X-Rite i1 Display Pro achetée chez Graphic Réseau, quelqu'un pourrait-il confirmer que les soft Calman sont compatibles.
Elle est compatible, mais sur la version CALMAN DIY il te faut un ADD ON Spectro.
Modérateurs: Modération Forum Home-Cinéma, Modération Forum Installations, Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Mikycoud et 1 invité
CEDRICLOUIS a écrit:Guy59 a écrit:Bonjour,
Bobor a écrit:J'ai édité mon post avec des copies d'écran pour mieux apprécier mon problème
CalMAN 4.6.1 Release Notes
Released April 25, 2012
Updates
Fixed issue where CalMAN after connecting to a meter, could not connect to another of the same meter without deleting the settings file. Meters affected were the Spyder3, Spyder4, i1D3, C6, and i1Pro.
Added PDP table to the Spyder4 meter
Added OLED table to the K-10
Added watchdog timer to the Sharp Elite when connected over IP
Fixed localization issue when profiling meters
Fixed issue where CalMAN was not calculating targets when Black Light Compensation was enabled
Fixed issue where CalMAN was not calculating targets when Colorfacts RGB Absolute Correction and Black Light Compensation were both enabled.
Fixed issue where CalMAN would crash when Black Light Compensation and Colorfacts RGB Absolute Correction were both enabled on some international versions of Windows.
CalMAN v4.6.2 build 384
Notes:
- Resolved incorrect DeltaE values
- Resolved issue where downloadable calibration tables were not being applied to meters. This affected the Spyder3, X2, i1Pro, and ColorMunki meters.
- Resolved a sync issue with the C6/D3 meters at extremely low luminance levels which would cause a Read Sync error message
- Resolved issue with incorrect pattern sizes with the QD802.
Retourner vers Les logiciels de calibration
