Modérateurs: Modération Forum Haute-Fidélité, Le CA de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 122 invités
DAC Mc Intosh D100 & D150
Message » 11 Jan 2013 22:11
Mise à jour avec l'arrivée du D150
Un nouveau venu qui arrive ce mois ci. J espère le prendre en test pour voir si la signature se rapproche d'un MCD 1100.
http://www.mcintoshlabs.com/us/Products ... 100900.pdf
ELECTRONIC SPECIFICATIONS
ULTRA LOW DISTORTION
0.002%
FREQUENCY RESPONSE, +0, -3DB
4Hz to 68,000Hz
VOLTS OUT, BALANCED / UNBALANCED MAX
16/8 V RMS
INPUT IMPEDANCE BALANCED / UNBALANCED
44K ohm, 22K ohm
PHONO VOLTAGE GAIN
N/A
HIGH LEVEL VOLTAGE GAIN
N/A
SIGNAL TO NOISE RATIO
110dB
DUAL MONO POWER SUPPLY
No
DUAL MONO, FULLY BALANCED
Digital, Fully Balanced
CONNECTIVITY
HEADPHONE OUTPUT
Yes 1/4"
INPUTS UNBALANCED
No
INPUTS BALANCED
No
VARIABLE OUTPUTS UNBALANCED
1 Stereo
VARIABLE OUTPUTS BALANCED
1 Stereo
DIGITAL USB INPUT
One, 2.0, 32/192 Asynchronous
DIGITAL SPIDIF INPUTS
2-opt., 2-coax, 24/192
PHONO MOVING MAGNET
No
PHONO MOVING COIL
No
RECORD PROCESSOR LOOP
No
INPUT LEVEL MATCH
No
HOME THEATER PASS THROUGH
No
CONTROL
TONE CONTROLS
No
TONE BYPASS AND INPUT ASSIGN
No
RS232 CONTROL INPUT
No
POWER CONTROL OUTPUT
Yes, 1
REAR PANEL DATA PORTS
Yes, 1 in
REAR PANEL IR SENSOR INPUT
Yes
GENERAL SPECIFICATIONS
MULTI-CHASSIS OR SINGLE
Single
OUTPUT METERS
No
TUBE OR TRANSISTOR
Transistor
ON, POWER CONSUMPTION
20 watts
WEIGHTS & DIMENSIONS
DIMENSIONS (W X H X D)
17.5" (44.45cm) x 3-7/8" (9.8cm) x 16" (40.64cm)
WEIGHT
13.5 lbs (6.1kg)
SHIPPING WEIGHT
28 lbs (12.7kg)
Arrivé du D150, il lit les formats DSD
DescriptionSpecificationsDownloads
The D150 digital stereo preamplifier expands McIntosh's digital music capabilities by supporting many of the newest digital audio formats such as DSD and DXD. A USB input accepts up to 32-bit/384kHz signals and supports DSD64, DSD128, DXD 352.8kHz and DXD 384kHz. Two coaxial and two optical inputs accept up to 24-bit/192kHz signals. It is a simple solution to add the latest digital music formats to your existing system.
Balanced and unbalanced connections are available for both variable and fixed volume audio outputs, providing flexibility in setting up and connecting your system. Or simply add an amplifier, a pair of speakers and a digital source for a complete digital based stereo system. For enjoying SACDs, the unique DIN input connects to select McIntosh models with a DIN output - like the MCT450 SACD/CD transport​​ - to deliver the purist possible sound quality. It's also flexible enough to be used as a headphone amplifier; just connect your digital sources and a pair of headphones, such as the MHP1000​ (not included), for a personal listening experience.
The D150 uses the same revered DAC as the D100, featuring an 8 channel, 32-bit, 500kHz D/A converter with wide dynamic range and extremely low distortion. Eight channel D/A converter is used in stereo Quad Balanced mode. Music at all levels is reproduced with extreme precision and elegance. A 1/8” mini jack is provided for control data from the data output jack of a McIntosh preamp or A/V Control Center​. It shares the classic façade, knobs and handcrafted black-glass front panels as all other McIntosh components in a small form factor of just under 4" in height.​
Please see Downloads tab for required driver that must be installed on Windows based computers (if an Apple based computer is used, no additional driver is required). See Owner's Manual for driver instructions.
Electronic Specifications
Ultra Low Distortion0.0015%
Frequency Response+/-0.5dB from 4Hz to 20,000Hz
+0.5/-3dB from 4Hz to 68,000Hz (Source dependent)
Maximum Volts Out (Balanced / Unbalanced)16/8 V RMS
Input Impedance (Balanced / Unbalanced)44K ohm, 22K ohm
Phono Voltage GainN/A
High Level Voltage GainN/A
Signal To Noise Ratio110dB
Dual Mono Power SupplyNo
Dual Mono, Fully BalancedDigital, Fully Balanced
Connectivity
Headphone OutputYes 1/4", High Drive
Inputs UnbalancedNo
Inputs BalancedNo
Variable Outputs Unbalanced1 Stereo
Variable Outputs Balanced1 Stereo
Digital USB Input1 (2.0, 32/192 Asynchronous)
44.1kHz to 384kHz, 32-Bit (PCM) DSD64, DSD128, DXD352.8kHz, DXD384kHz
Digital Coaxial Input2
Digital Optical Input2
Digital DIN Input1
Phono Moving MagnetNo
Phono Moving CoilNo
Record Processor LoopNo
Input Level MatchNo
Home Theater Pass ThroughNo
Control
Tone ControlsNo
Tone Bypass and Input AssignNo
RS232 Control InputNo
Power Control OutputYes, 1
Rear Panel Data PortsYes, 1 in
Rear Panel IR Sensor InputYes
General Specifications
Multi-Chassis or SingleSingle
Output MetersNo
Tube or Solid StateSolid State
On, Power Consumption30 watts
Weights & Dimensions
Dimensions (W x H x D)17.5" (44.45cm) x 3-7/8" (9.8cm) x 16" (40.64cm)
Weight13.5 lbs (6.1kg)
Shipping Weight28 lbs (12.7kg)
Product Literature
User Documents
Software Updates
McIntosh USB Audio Windows Driver C v1.0 (compatible with Windows 7, 8, and 8.1) (4.39 MB) (1/5/2015) Download
D100
D150
D150
gil2b
Inscription Forum: 28 Déc 2003 19:52
Message » 11 Jan 2013 22:42
Belle initiative Gilles :wink:
choky
Inscription Forum: 07 Mai 2010 22:14
Message » 11 Jan 2013 22:47
Je ne vois pas le prix.
Gort'h
Inscription Forum: 25 Juin 2004 14:36
Message » 12 Jan 2013 0:12
3350€ Ttc.
choky
Message » 12 Jan 2013 9:07
choky a écrit:3350€ Ttc.
il font des soldes chez mac? :D
bobtheveinard
Inscription Forum: 15 Sep 2010 7:57
Message » 13 Jan 2013 11:48
Idem, ça m'a surpris aussi quand Christophe m'a annoncé le prix... Je ne regrette pas de m'être séparé de ma MCD500 début décembre ... surtout si c'est aussi bon qu'une 1100. En tout cas, quelle belle inspiration cette revente :lol:
Je vais néanmoins tester chez moi le DAC30 Primare qui me convient plus au niveau de la tenue du grave (trop de rondeur à mon gout chez MC pour mes JBL). Je crains juste de ne pas m'y retrouver au niveau profondeur et détails, à écouter in-situ car c'était vraiment pas mal en audito face à un dCS Debussy 4x + cher ! :ko:
Rugbystick
Inscription Forum: 13 Jan 2007 14:50
Message » 20 Jan 2013 11:10
Pas de retour encore sur ce DAC ?
Rugbystick
Message » 20 Jan 2013 12:55
Test normalement mercredi matin chez Elecson :wink:
gil2b
Message » 24 Jan 2013 13:11
Quelles sont vos impressions après cette écoute ?
Bien cordialement,
Fabien
FabBrov
Inscription Forum: 19 Fév 2012 13:03
Message » 24 Jan 2013 17:19
Très rapidement. Le Dac est excellent. La partie pre ampli ne m'a pas convaincu.
Gil
gil2b
Message » 24 Jan 2013 18:01
On t'a connu plus bavard :hein: :hehe:
Rugbystick
Message » 24 Jan 2013 20:05
J'étais au boulot sur mon Telephone :oops:
En fait l écoute c est fait sur le matériel que souhaitais écouter Choky et je ferais un essai plus approfondi avec ma platine mais déjà face a un Atoll Cd400 le DAC est plus dynamique, meilleure tenue du grave et surtout une scène bien plus large. Face a une DP 510 c est plus tenu, le DAC gagne en Niveau de sortie du coup ca fausse l écoute.
L ensemble a été écoute sur B&W 800, ampli Mcintoch Mc 7000 et Accuphase DP 510 et Atoll Cd400 qui ont servit de drive à tour de rôle.
En tout cas la partie pre ampli ne m'a pas donné satisfaction, le DAC méritera une seconde écoute attentive, si possible chez moi.
Gil
gil2b
Message » 25 Jan 2013 20:02
petit HS, mais j'aimerais une réponse : un MC7000 (l'intégré donc hein ?!) tient des B&W 800Di ??
merci !
picola
Inscription Forum: 14 Oct 2000 2:00
Message » 25 Jan 2013 21:02
Slt
Pour moi, clairement non
(je ne partage pas l'avis de Papi, qui conclut le contraire suite lui aussi après écoute).
Mais son avis est autant valable que le mien, car nous n'apprécions pas forcément sur les mêmes critères, bien que nous avons une approche identique : la qualité de restitution.
Patrick a une approche plus détaillée, moi plus live. Forcément, à un moment on diverge ...
Pour autant, les 800D ont des boomers lourds. Et pour bien les faire bouger, le MA7000 n'est pas suffisant à mon goût. Sur les autres registres, il s'en sort correctement.
Comme j'écoute beaucoup de concerts, les 800D drivées par un 7000 ne bougent pas assez vite...
itofa
Message » 25 Jan 2013 23:21
itofa a écrit:Slt
Je me permets d'intervenir quand même pour ne pas polémiquer mais étant avec Gilles et Patrick lors de cette ecoute, car c'est moi qui initialement avait pris le rdv. J'ai été très surpris de voir comment le Ma 7000 marchait bien sur les 800 Di, donc +1 avec Patrick.
À titre comparatif ayant eu des 800 D ancienne génération avec 1 Mc 402, la combi Ma7000 Nv 800 DI marchait bien mieux et surtout, le critère qui m'intéresse est d'avoir le maximum de détails et d'émotion à bas volume.
Après que les puristes Mc Intosh puissent trouver la Solution Ma 7000 short why not mais le tout est de faire le test en direct sans à priori. À la base nous venions écouter des 802 Di sur Ma 7000 et Accuphase E560 avec le Mc D100.
Sauf que plus de 802 dispo mais que des 800, donc j'étais réticent à faire le déplacement d'aussi loin pour seulement 2h00 d'écoute.
Quelles surprises ces 2 intégrés nous ont réservés sur ces Grandes Dames que sont les 800 Diamond.
Moment mémorable !
choky
