When you connect this projector and a DVI-Digital device (such as a DVD player) via the HDMI terminal or DVID (HDCP) terminal, black color may appear dark and deep, depending on the type of the connected device.
This depends on the black level setting of the connected device. There are two kinds of methods to digitally transfer image data, in which different black level settings are employed respectively. Therefore, the specifi cations of the signals output from DVD players differ, depending on the type of the digital data transfer method they use.
Some DVD players are provided with a function to switch the methods to output digital signals. When your DVD player is provided with such function, set it as follows.
EXPAND or ENHANCED -> NORMALSee the users guide of your DVD player for details.
Set INPUT LEVEL of ADVANCED MENU in the IMAGE menu depending on the device to be used.
Quelqu'un comprend il exactement ce qu'ils ont voulu dire ? Perso j'ai du mal à comprendre exactement ce qu'ils veulent que l'on fasse, et j'aurais tendance à dire :
- quand le lecteur de DVD est en enhanced, il faut mettre le HC5000 en normal.
c'est tellement illogique que j'ai du mal à y croire.
Saleté de doc
