Pioneer SC-LX 83
•Input Connections
• 6 x HDMI (1080p upscaling) (1 Front Input)
• 4 x Composite In
• 3 x Component In
• 2 x Coaxial In
• 3 x Optical In
• 1 x USB / iPod/iPhone
• 1 x Ethernet
• 1 x Bluetooth adapter port for AS-BT100 (included)
•Output Connections • 2 x HDMI
• 1 x Composite
• 1 x Component
• 1 x Optical
•Tuner Pre-set Stations 63
•Internet Radio Yes
•DLNA Certified (+) Yes (1.5)
•THX Certified (+) Yes
•HD Digital Film Direct 24 (+) Yes .
•MCACC (+) Yes (Advanced, 9-band)
See how MCACC works
•HD Audio Formats Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution
•Control with HDMI (+) Yes
•Deep Colour (+) Yes
•x.v.Colour (+) Yes
•HDMI Repeater (+) Yes
•3D Ready Yes
•On-Screen Display (GUI) Easy-to-use GUI, available in English, French, Italian, German, Spanish, Dutch and Russian
•Remote Control RF Remote
Surround Sound Formats
•Dolby Digital (+) Yes
•Dolby Digital EX (+) Yes
•Dolby Digital Plus (+) Yes
•Dolby Pro Logic II (+) Yes
•Dolby Pro Logic IIx (+) Yes
•Dolby Pro Logic IIz (+) Yes
•Dolby True HD (+) Yes
•DTS (+)Yes
•DTS-ES (+) Yes
•DTS Neo: 6 (+) Yes
•DTS 96/24 (+) Yes
•DTS-Express (+) Yes
•DTS-HD High Resolution Audio (+) Yes
•DTS-HD Master Audio (+) Yes
•WMA 9 Pro (+) Yes
•DTS Neural Surround (+) Yes
•Surround Modes (+) 13 + 1 (Action, Drama, Sci-Fi, Mono Film, Entertainment Show, Expanded Theater, TV Surround, Advanced Game, Sports, Classical, Rock/Pop, Unplugged, Extended Stereo + Phones Surround)
Power Output
•Power output per channel 190W
•Condition 1kHz, 1% THD, 6Ω
•Rated Power Output 190W per channel
•Input (Sensitivity/Imp.): LINE 400 mV / 47 kΩ
•Frequency Response: LINE 5 Hz - 100 kHz +0/-3 dB
•Signal-to-Noise Ratio: LINE (DIN) 103 dB
•Power Requirements AC 220 - 230 V / 50/60 Hz
Construction
•ICEpower Yes
•Pioneer Hybrid Amplification (+) Yes
•Digital Signal Processor Freescale
Amplifier Specifications
•Direct Energy HD amplifier Yes
•Front L & R Bi-Amplifier Function (+) Yes
•D/A Converter 192 kHz / 32-bit
•A/D Converter 192 kHz / 24-bit
Input & Output connections
•Bi-Amplifier Yes
•Bluetooth Adapter Port (+) Yes
•Component Video Input/Output 3/1 (assignable)
•Composite Input/Output 4/1
•Digital Optical Input/Output 3/1 (assignable)
•Digital Coaxial Input/Output 3/- (assignable)
•Ethernet (+) 1
•HDMI Input/Output 6 (assignable)/2
•Headphone Yes
•IR In/Out (+) 2 in / 1 out
•Large speaker terminals Yes
•Pre-amp Output Yes (SW)
•Speaker A/B Yes
•USB Host (Front) (+) Yes
iPod Compatibility
•iPod Ready Yes, via digital direct USB connection (included)
•Works with iPhone Yes
•Compatible Generations 5th Generation, Nano and above, iPhone (including 3G)
•Supported Functions Audio & Video (Video with the supplied iPod/iPhone Video + USB Audio cable), On-Screen Album Art
•iControlAV iPhone Application (+) Yes
•iPhone Control Button (+) Yes
Audio Features
•Auto Level Control (+) Yes (Multi-channel)
•Auto Surround Yes
•Bass/Treble Tone Controls Yes
•Dialogue Enhancement (+) Yes
•Digital Noise Reduction (+) Yes
•Dynamic Range Control Yes
•Front Stage Surround Advance (+) Yes
•Jitter Reduction Yes
•Loudness (+) Yes
•Midnight Listening Mode (+) Yes
•Multizone Function (+) Yes (3)
•Phase Control (+) Yes
•Full Band Phase Control (+) Yes
•PQLS (+) Yes (Multi-channel, bitstream & LPCM)
•Sound Delay (+) Yes
•Sound Retriever (+) Yes
•Advanced Sound Retriever (+) Yes (Multi-channel)
•Sound Retriever AIR (+) Yes
•Standing Wave Control (+) Yes
•Stream Direct (+) Yes
•Symmetric EQ (+) Yes
•Virtual Surround Back (+) Yes
•X-Curve (+) Yes
http://www.pioneer.eu/eur/products/42/98/405/SC-LX73/index.html
http://www.pioneer.eu/eur/products/42/98/405/SC-LX83/index.html
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: jeanluc90, kamuel, LE PIRATE et 305 invités
on revient au noir satiné !!
et bien sur le "truc" indispenssable pour se la petter devant les copains !!!!???? the iphone control !!!
houps !!! j'ai po de ifone
djé
djé
- passatdjé49
- Inscription Forum: 09 Juil 2008 21:56
"1080p video upscaling via Anchor Bay Technologies video processing"
Quelles puces ? Et pourquoi n'utilisent-ils pas le Marvell QDeo qu'ils mettent sur le VSX 2020 et qui vient du BDP-LX 91 ?
Idée du prix et de la dispo ?
- s9rStef
- Inscription Forum: 08 Jan 2004 18:39
SCLX-83 2299 €.... à confirmer... et 1625€ le SCLX-73.... pour 10W d'écart par canal...
....je trouve que ca coûte cher... non ?
http://areadvd.de/hardware/2010/highend_pioneer_sclx83.shtml
je sais pas s'il est pourvu de plusieurs sorties sub....
- lolo63
- Membre HCFR Contributeur
- Inscription Forum: 30 Mai 2005 21:55
En meme temps, les précédents modeles (82 & 72) etaient lancés aux prix de 2500 et 2000 €.
Donc si on a les meme pref. precedentes avec des nouveautés en plus (HDMI 1.4), cela reste correct tout de meme (d'autres marques rajoutent habituellement qques centaines d'euros à chaque évolution: ex Denon)
JVC-DLA-X7900+Lumene Coliseum Premium 270C/LG-OLED55GX6LA/OPPO-UDP-203/Dune HD Pro Vision 4K Solo/Nas Synology DS2411(21To)/Denon-AVR-7200WA/Accuphase-E-408(DAC30)/Focal-Electra 1028Be+CC1008Be+Chorus IW-706V/Velodyne-SPL-1500R/Logitech-Harmony Elite
ashday - Membre HCFR
- Inscription Forum: 14 Jan 2007 17:23
Je n'aime pas le noir laqué mais là il me plait.
Ne reste plus qu'à l'écouter: mais j'ai un peu peur avec mes jmbal/focal
(association ampli numerique et HP medium un peu en avant ??)
lolo63 a écrit:SCLX-83 2299 €.... à confirmer... et 1625€ le SCLX-73.... pour 10W d'écart par canal...
Sur les LX-82 et LX-72, ce n'était pas le seul point d'écart. Les DAC changeaient et le suréchantillonage audio n'était que sur le 82 (au moins).
- s9rStef
Je ne pense pas que ce soit les seules modif entre les modèles (surtout que parler de puissance pour un intégré n'a aucun sens, mesurez celle de chaque canal sur vos intégrés).
N'y a t-il pas de différence au niveau du DAC? Nombre d'entrées/sorties? Scaler? Possibilités de calibration? Gestion du nombre de canaux?
- nahkmos
- Inscription Forum: 20 Oct 2007 22:55
s9rStef a écrit:"1080p video upscaling via Anchor Bay Technologies video processing"
En principe, il devrait sortir en août au PPI de 2299 €
- jmcara
- Inscription Forum: 29 Nov 2009 12:06
jmcara a écrit:En principe, il devrait sortir en août au PPI de 2299 €
oui c'est déjà écris plus haut.
Ce qui serait interessant, c'est d'avoir plus de détails sur les specs...
- lolo63
c'est comme l'annonce l'année dernière pour le LX82 le prix risque fort d'être le même, soit 2499€ en ppi pour la sortie c'est fin aout, voir tout début septembre
je sens que lolo63 l'attend avec impatience
- haribo
- Inscription Forum: 01 Jan 2009 23:52
- lolo63
Je suis surpris qu'il ne soit pas prévu avec la puce Marvell. Ca sent le changement à venir dans les specs !
- s9rStef
Le noir satiné, ça va pas aller avec le reste de mon installation.. faut tout changer alors?
ampli Pioneer sc-lx801 lecteur bd Sony 4k UBP-X800 lect. enreg. dvd Panasonic DMR-BWT700EC télé Samsung 55QN95A HP Triangle ZAYS 222 caisson mosscade titan 11.4 déco uhd G9 Canal Lect Mult. Dvico 6632
Cordialement, Michel.
tndtnd - Membre HCFR
- Inscription Forum: 19 Oct 2006 11:53
+1passatdjé49 a écrit:et bien sur le "truc" indispenssable pour se la petter devant les copains !!!!???? the iphone control !!!
djé
